Goodyear Wrangler DURATRAC's
Discussion in 'Wheels & Tires' started by skistoy, Feb 11, 2010.
  1. Nov 5, 2013 at 3:41 PM
    #1661
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Depends on what most of you're driving is. I've had both tires, and they're both great. Duratracs are much better off-road and in snow, but you'll see better gas mileage out of the TG's if you're staying on the pavement.
    I'm on the pavement most of the time, but when I'm not, I like to have the traction the Duratrac's provide. Plus they just look way better IMO...
  2. Nov 5, 2013 at 3:46 PM
    #1662
    j0k3r1
    j0k3r1 Member
    Ontario, Canada
    24 TRD OffRoad with premium package because I like gadgets
    Went with the E's, needed tires as I hated the tires that were on it when I bought it.
  3. Nov 5, 2013 at 3:48 PM
    #1663
    zopperman
    zopperman LED & HID positive
    Zak
    Arlington, VA
    03 4Runner
    Lift, 32" Duratracs, sliders, LED light bar, interior LEDs, sweet tunes & sub, OBA, sliders, TRD 16" 6 spoke wheels, CB, HID spotlights, electrical mods, etc.
  4. Nov 5, 2013 at 9:00 PM
    #1664
    FawkQ
    FawkQ Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    Time for another "will these fit?" question/debate... I'm definitely buying Duratracs... the size is what I'm debating... I'm leaning towards the 285's (depending on your guys thoughts)
    2013 TRD Sport DC with 3" pro comp lift (coils and shocks, not the cheapy block lift sh!t) with stock 17" rims...
    Do I get the stock size 265's? or 285's? and why for either?
    Will I have back spacing / rubbing issues if I got 285? If so, will it just take some minor trimming and I'm good to go? Or pickup some spacers to go with?
    According to the "tire size calculator", 285's are only 1.1" taller and 0.79" wider... so I'm leaning towards the 285's. I don't think that 1" taller and not quite 1" wider would cause severe rubbing... nothing a potential trim job can't fix, would it?
  5. Nov 6, 2013 at 2:47 AM
    #1665
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    If you mount the 285s on stock wheels the tire will rub the upper control arm unless you get wheel spacers or a wheel with less backspacing. Even with the perfect offset you will still need to remove mudflaps and trim. If you offroad and depending on other factors like alignment specs your tires might rub the body mount and you will need to do the cab mount chop, some guys say they don't need to do it, i had to trim the shit out of the cab mount. One inch can make a big differnece (thats what she said :D)
  6. Nov 6, 2013 at 4:08 AM
    #1666
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    I have a 5-5.5" lift and just took my 285's off for 265's. I had minor rubbing with the 285's at full lock but nothing that I had to cut for and that was with aftermarket rims with a 4.5 offset. I would imagine you would probably have some issues with stock rims and a 3" lift with 285's.
  7. Nov 6, 2013 at 4:52 AM
    #1667
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    All I'll say is that I just swapped my Duratracs for Duratracs a few weeks ago. I simply could not find any reason not to go with another set. I'm putting the ones I took off on my son's Tacoma (First gen regular cab) because they are better than the big ole mud terrain tires he has on there now. The Duratracs got somewhat louder once they got over 50,000 miles on them but they still have plenty of tread left (7/16) and will be whisper quiet compared to the boy's mudders. I put new ones on since I plow with my truck and need the bite. FWIW I love these tires and can't imagine switching.
  8. Nov 6, 2013 at 4:57 AM
    #1668
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Wow ... ya'll are making me seriously consider going with Duratracs to replace my Blizzaks next fall (they've got one more season left on them). Then when I wear out my Silent Armors, I'd just run Duratracs year round. Can anyone tell me if there is a difference in snow/ice performance between P rated and E (LT) rated. I run LTs for fishing/hunting season due to quite a bit of time on gravel. I've had too many friends cut down P rated tires.
    OP: Sorry, not trying to thread jack here, started typing and submitted before I thought about it.:eek:
  9. Nov 6, 2013 at 6:27 AM
    #1669
    TACOlin
    TACOlin Well-Known Member
    Colin
    Marietta, GA
    2010 TRD Off Road 4x4 DC SB
    URD Short Shifter, TRD Shift Knob, Rear Leaf Spring TSB, Flowmaster Super 40 muffler w/ 2.5" pipe and 3" tip, Cobra CB radio, 2' Truck Spec antenna, under hood PA speaker, JVC KW AV71BT Headunit, Anti-theft tailgate protection mod, locking bed storage compartment mod
    WOOH a fellow Hawaii Taco! I obviously don't live there but the guy I bought it from lived on Kuwaii and I knew i recognized that bumper sticker becuase i kept it on mine haha
  10. Nov 6, 2013 at 7:25 AM
    #1670
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Haha! Gotta love Hawaii safety check!
    Not really...
  11. Nov 6, 2013 at 7:52 AM
    #1671
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I currently have 41K on my Duratracs. They have been the best all-season truck tire that I have ever owned. I plan on buying a new set next summer.
  12. Nov 6, 2013 at 1:11 PM
    #1672
    FawkQ
    Alberta, Canada
    Awesome, thanks gents!!!
    Cheers!
  13. Nov 6, 2013 at 6:51 PM
    #1673
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    You're welcome!
  14. Nov 8, 2013 at 1:02 PM
    #1674
    mikesfarm
    mikesfarm Well-Known Member
    Florida
    2025 4wd Tacoma SR5 DC
    Joined the Duratrac club 50 miles ago. 2011 4X4 AC no lift. 265/75/16s on stock rims fit great and look great. Thanks to this thread .
  15. Nov 8, 2013 at 2:35 PM
    #1675
    yota4Whelz
    yota4Whelz Well-Known Member
    Orange County NY
    2009 Tacoma DCSB TRD Sport 4x4
    -Removed mudflaps -Blacked out tail lights/ third brake light -Blacked out emblems -Truxedo truxport tonneau cover -Tailgate theft mod -Eyelids (Toyotaman) -Center console organizer (Salex) -WeatherTech Digital fit floor liners -BHLM -Wet Okoles fronts and backs -Homertaco satoshi grill -Pioneer h/u -Disabled seat belt chime -LED gauge swap (Jerez) -BAMF Light bar w/ 2 hella 500ffs -Old Man Emu 90000 front shocks, 885x coilovers, nitro sports and AAL in the rear -285/70/17 wrangler duratracs -1.25 Bora spacers (4) -Super 40 series Flowmaster -Differential breather mod -Blacked out bedsides -Method NV Race wheels -EGR in channel window visors -Interior/license plate/tails LEDs (Jumpers LEDs)
    Just got the new shoes on today! 285/70/17s
  16. Nov 8, 2013 at 2:41 PM
    #1676
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    Just threw on my second set of duratracs, this time in 285/75/16's...
  17. Nov 8, 2013 at 6:33 PM
    #1677
    nickberg
    nickberg Member
    Nick
    CA
    2012 MGM DCSB 4X4 TRD Off-Road
    Modest mods and lift
    I got Duratrac's 265/75/16 when I got my lift about a month ago.
    Question: How do the tires handle the sand or dunes? Im going to Glamis this weekend, and i'm aware that i'll have to air them down to ~15 PSI. Im just looking to take out some of the guesswork, and have some fun:)
  18. Nov 8, 2013 at 8:46 PM
    #1678
    bullaculla
    Da big big island!
    I have the same tires and pretty much same truck. Mine is probably a bit heavier tho ;) I've been in some really soft beach sand without airing down and have been fine. Never got stuck, and even pulled some stuck vehicles out of the sand without airing down.
    After pulling my buddy's stuck titan out of this, I drove around in the same spot with 40 PSI in the tires just to show him how :D
    Pulled TW member Luka out of the sand a couple times too :cool: He's currently working on converting his prerunner to 4x4.
    He loves when I post this pic :p
  19. Nov 14, 2013 at 12:08 PM
    #1679
    myamada1230
    myamada1230 Well-Known Member
    Greenacres, WA
    2021 TRD Offroad DCLB
    Anybody else's MPG drop ~3 when they put duratracs on? I just put on 265/70/17 load range C and my mpg dropped to ~14 and that's mostly highway.
  20. Nov 14, 2013 at 1:04 PM
    #1680
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I've had my Duratracs on my Tacoma for 2.5 years with about 23K miles total. They definitely get louder over time. My 3 year old noticed the road noise the other day and asked if I could make the noise stop. :laugh:
    Surprisingly the road noise doesn't bother me. Zero vibrations because the tires are balanced.
    In the two and 1/2 years I've had them I've had two tire punctures. But that does not speak to the quality of the tire... The shit I ran over would have punctured any LT tire.
    Overall I'm happy with them. I hope I get 2 more years and 25K more out of them. :)
