Goodyear Wrangler DURATRAC's
Discussion in 'Wheels & Tires' started by skistoy, Feb 11, 2010.
  1. Jul 3, 2014 at 5:21 AM
    #1861
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    It will be interesting to know for every comments who's running aftermarket wheels and model.
  2. Jul 3, 2014 at 3:04 PM
    #1862
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    +1
    I've never had balancing issues but now that I have ~30k miles on them, they are getting pretty noisy. They sound like an MT on the highway. I never really noticed the noise when I had a loud aftermarket exhaust, but now that I'm running the quiet factory muffler again they definitely roar on the highway.
  3. Jul 16, 2014 at 1:43 PM
    #1863
    ThatTallDude
    ThatTallDude Well-Known Member
    Jesse
    sf peninsula
    '01, 4x4, SR5, 2.7L, 5spd, 33x12.5x15
    Leer shell, bedliner, helwig helper springs, hid aux driving lights. UPDATE: 33x12.5x15 duratracs, buds skid plate & belly pan (delivered not yet installed); now need good bolt-on sliders... UPDATE: Ordered bamf sliders, LCA skids, & badlands rear bumper
    Sorry in advance for spelling, grammar, etc; did this on my phone during lunch...
    Went with 33x12.5x15 & 15x8 alloy wheels w/ 3.7" backspacing from tirerack.
    Kinda regret changing the backspacing so much from stock wheel at ~4.5" as these measure 3.5" and they have way more sidewall clearance to the uca then stock (my main concern was this clearance reducing significantly) and they seem to have plenty of frame clearance at full lock. They look like heavy negative offset wheels but aren't... Oh well...
    Did the pinch weld mod over the weekend and can make it out of driveway now with only a little rubbing going over bumps while turning (around town) on stock suspension; need a lot more work on that before even mild off road driving. Will do a 2" or 3 inch lift, but figure I deal with rubbing issue easier now without it. Looking for as much articulation as possible out of stock UCAs & LCAs (w/ swaybar disconnect, etc)
    Playing with tire pressure to see what it likes with the much larger tires over the stock 265/70r16.
    Happy with them besides the backspacing; only gained 10lbs per tire over stock wheels & M/S2s, from 60lbs up to 70lbs, & hum isn't too bad; about what I expected for an aggressive AT tire.
    For balancing, one of them only has 1/2 oz., but some took much more than the Michelins on the stock wheels; nothing like some things a saw here.
    Do notice the ratio change from the 6% taller tires but don't feel like they are working the 2.7L much and don't notice any big loss in power. If i was okay with the open diffs or already had LSDs or locker, I'd leave it the ratio as is, but i have stock 4.30s with 5 spd manual though. There is a dude on here running 35x12.5x15 KM2s on this setup; but 5th gear is useless for him (relentless taco or something; a fab guy in Reno I think)
    I do notice more drag, but am running them at a much lower pressure than the other tires, 28 up front but rears only have 22psi. I often run the M/S2s @ 30 psi; it helps the mpg a lot more than it hurts tread wear.
    Would have preferred 33x10.5x15s duratracs (if they made them) on 15x7, especially if they were significantly lighter...
    can get pics up soon, if people want them that is....
    UPDATE 7/20/14:
    Filled up the tank & set the tires to 28psi; drove it for couple days and when it got down to 1/2 a tank & filled up.
    I felt like I was pushing it a little harder than normal, but I that's not saying much; I accelerate really easy.
    Anyway lately I have been getting 21.5 mpg on the stock wheels/tire and got 20.5mpg with 33" duratracs. Mpg only dropped 5%. It's only based on half a tank so it could a couple compounding errors, but time will tell. Will update this as I get more data.
  4. Aug 26, 2014 at 1:34 AM
    #1864
    csayno
    csayno Well-Known Member
    Tulsa, OK
    2020 Cement TRD Off-Road
    Loving my duratracs, quiet, no problems, mpg is about the same, aggressive as heck. Love it.
  5. Aug 26, 2014 at 7:10 AM
    #1865
    pouyeux55
    pouyeux55 Member
    canada (QC)
    Can someone tell me if the duratrac in 265/75r16 will fit with no rubbing my 2010 ac 4x4 with stock wheel and suspension.
    I know that some tire in that size are rubbing and i don't want to lift the truck.
    Thx
  6. Aug 26, 2014 at 8:51 AM
    #1866
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    I had them on my regular cab 4wd and I couldn't make them rub.
  7. Aug 26, 2014 at 9:09 AM
    #1867
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    Had zero issues with my 33x12.50x15 on my 84 Toyota.... only parted with them cause I went to a bigger tire.
    Wanting to get a set of 265/75/16 for my Tacoma but not liking what I'm reading about balancing issues.
  8. Aug 26, 2014 at 9:10 AM
    #1868
    pouyeux55
    pouyeux55 Member
    canada (QC)
    That's a good thing to hear
  9. Aug 26, 2014 at 10:55 AM
    #1869
    Tackz
    Tackz Well-Known Member
    West Palm Beach, FL.
    '14 TRD Sport DC/LB 4x4
    Mine sound like a tank comin' down the road. Of course, I've got 62K on em', hehe...so, I figure I'm doin' pretty well. I will, however, be replacing them soon. They're goin' fast at this point. First 40K, loved em'. Not sure if I'm gonna' get em' again. I used to do a lot more off roading than now. And they're a bit aggressive for mostly street use. Pretty good tire imo.
  10. Aug 26, 2014 at 5:01 PM
    #1870
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    Wonder if those with no issues could post the DOT build code on theirs, and compare when they were made to those with the worst problems.
  11. Sep 16, 2014 at 7:07 AM
    #1871
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Real quick,probably stupid question.
    Discount Tire says duratracs in 265/75/16 C rated can only be had with the white lettered sidewall. Can I just have them rotate the white letters in to have the black sidewall?
  12. Sep 16, 2014 at 7:09 AM
    #1872
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Yep. That's the way mine are.
  13. Sep 16, 2014 at 9:24 AM
    #1873
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    x2, white letters in on mine
  14. Sep 16, 2014 at 11:06 AM
    #1874
    Mountainwolf
    Mountainwolf Well-Known Member
    N.GA mountains
    05 TRD OffRoad & 17 TRD Pro
    Yes. Many tires come that way. Just mount with white letters on inside.
  15. Nov 10, 2014 at 12:36 PM
    #1875
    Maximus Gradient
    Maximus Gradient Well-Known Member
    Sean
    East Bay
    Red Taco, OR
    Blacked out chrome, TRD exhaust, rear diff. breather, hood/engine bay LED light strip, 235/85R16 DuraTracs
    have some input on what PSI you're running on front/back for these? I'm curious since I just had 235/85R16s mounted a couple weeks back and haven't really found time to do the chalk test yet. I know I should be running them higher than what the doorjamb label says, but a good starting point would be appreciated (note: the techs who mounted them have them at ~39-40 PSI right now).
    Thanks!
  16. Nov 10, 2014 at 12:39 PM
    #1876
    itsmemattp
    itsmemattp Well-Known Member
    Ashland, Oregon
    06 Tacoma Access Cab 4x4
    I have these up at 40PSI and have no problems. I aired them up and went for a long (4 hour) highway drive and have had no problems. If I was doing a lot of fire road driving I would definitely air down for a softer ride.
  17. Nov 10, 2014 at 1:34 PM
    #1877
    busychild
    busychild Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
    i love mine so far. got them brand new 265/65/17 on 17" KMC Enduros. was out in in Banff clear perfectly fine weather Sat. Sunday AM big heavy dump, i felt very confident on the road no slippage, highway lots of grip and felt confident pulling away to pass on snow covered roads. i have maybe 1000KM on them now they have been super quiet for such an aggressive looking tire
  18. Nov 10, 2014 at 4:28 PM
    #1878
    toyotatacomaTRD
    I have a love hate relationship with these tires. This morning, it was really slick and we had black ice. The tires worked great. In the snow, I think they handle just as I would want. However, they are getting louder by the day and I have had them rotated twice and I don't think I'm quite to 10k miles. Plus, I live with a steering wheel shake at anything above 50mph because I'm tired of going back to have them balanced.
  19. Nov 11, 2014 at 1:05 AM
    #1879
    runner05
    runner05 Well-Known Member
    Karl
    I had them and had no issues whatsoever. It's a good mix of AT and MT when it comes to overall performance.
  20. Nov 11, 2014 at 6:25 PM
    #1880
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Finally got mine mounted up tonight.
    When I was getting them balanced, I asked the guy to check the air in all of em and make sure it was at 32psi per the door sticker. He said I need to run them right around 40psi. Seems kinda high to me....
    What air pressure do you guys typically run them at? Mine are 265/70/17s, C rated, on stock Sport wheels.
