Goodyear Wrangler DURATRAC's
Discussion in 'Wheels & Tires' started by skistoy, Feb 11, 2010.
  1. Nov 18, 2014 at 4:35 PM
    #1901
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
  2. Nov 18, 2014 at 6:34 PM
    #1902
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
  3. Nov 19, 2014 at 6:40 AM
    #1903
    ThatTallDude
    ThatTallDude Well-Known Member
    Jesse
    sf peninsula
    '01, 4x4, SR5, 2.7L, 5spd, 33x12.5x15
    Leer shell, bedliner, helwig helper springs, hid aux driving lights. UPDATE: 33x12.5x15 duratracs, buds skid plate & belly pan (delivered not yet installed); now need good bolt-on sliders... UPDATE: Ordered bamf sliders, LCA skids, & badlands rear bumper
    Lt tire has a deeper tread 18/32" vs 16/32" and often has a more aggressive tread pattern (lugs further apart;etc) and typically designed to better withstand more off-road abuse. The tread compound can be different for to better withstand off-road and/or performance. The lt may have more plys, but maybe not in this particular case since the load c has lower weight rating than the non LT tire.
    The standard (non LT) tire will have better road manors and should be able to do more miles before the tread is worn out.
    I would want to see each side by side, to see the tread pattern differences and the the plys listed. But that's just me; I am a weirdo that likes checking out that kind of stuff.
    Hopefully there are people here that can comment with first hand expirence with the differences of the two versions of that size tire...
  4. Nov 19, 2014 at 7:58 AM
    #1904
    HB Taco
    Curt
    Just look at the specs. The 115SL tire has a higher load rating (C+ Load?) but interesting on the 16/32 tread depth? I assumed all were 18/32. I'd get the $170 one. As tall dude said they probably will ride better on the street but still are aggressive. I doubt the tread is much different.
  5. Nov 19, 2014 at 12:28 PM
    #1905
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Does anyone's Duratracs seem to have poor wet traction? When taking off from a stop when the road is wet, I seem to brake the tires loose easily. It seems like the stock BFG Rugged Trails had better wet traction.:confused:
  6. Nov 19, 2014 at 5:33 PM
    #1906
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Mine have gotten worse with age, as every tire I've ever owned has. I'm at 45k miles or so, but when they were pretty new, wet weather was excellent.
  7. Nov 19, 2014 at 9:46 PM
    #1907
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    Replaced mine just the other day, 45,000, a bit noisy and when we had a fine mist, entering the freeway when I had the green light on the ramp with a slight upgrade, could not get traction, and I was being easy on the gas. That night picked up my new KO2's
    The DT's did fine off road for a bunch of trips. Just don't think any one tire will make everyone happy.
    Also unlike some here, I always get "E" rated tires. The strength on the sidewalls, the ability to haul my rig with boat, shell, armor and winch. Ride is not like a car, but I have a car for that ride.
  8. Nov 19, 2014 at 9:47 PM
    #1908
    JimBCa
    Jim
    Bay Area California
    2012 TRD Off Road
    Yep
  9. Nov 19, 2014 at 10:15 PM
    #1909
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    My duratracs have no wet traction at all. The are horrible on wet roads and when going up hills it's like driving in the snow. Worst tires I've ever owned for wet traction! I so can't wait to get something else!
  10. Nov 20, 2014 at 4:04 AM
    #1910
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Best wet traction tires I've owned. No comparison to my BFG ATs. Haven't been in deep snow yet. This should be my first chance this year since we moved.
  11. Nov 20, 2014 at 4:49 AM
    #1911
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    This is my first AT tire, but compared to a stockish tire they suck on wet roads. I still like them though. Time for snow where they shine.
  12. Nov 20, 2014 at 6:47 AM
    #1912
    SRC
    SRC Well-Known Member
    Shawn
    Guelph, Ontario
    2017 DCSB OR
    I'm in this same boat. I'm trying to figure out if I should go with C or SL.
    I just got off the phone with Goodyear and this is what I found out.
    265/70/17
    SL - 4 ply - 44.84 lbs/tire - 16/32 tread depth - 51 psi max.
    C - 6 ply - 43.04 lbs/tire - 18/32 tread depth - 50 psi max.
    E - 10 ply - 51.92 lbs/tire - 18/32 tread depth - 80 psi max.
    Also SL has a different tread pattern than the LT versions.
    This left me confused....how could C weigh less than SL and have a lower max pressure ? :confused:
    EDIT: I think the GY lady got her wires crossed. Tirerack shows SL is 43lbs and C is 44lbs.
  13. Nov 20, 2014 at 11:55 AM
    #1913
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    One pound difference between them, and more tread, I'd go with the C. That sidewall on the SL is gonna be really thin. I wonder though if the SL balances easier than the C or E?
  14. Nov 20, 2014 at 6:08 PM
    #1914
    ThatTallDude
    Jesse
    sf peninsula
    Everybody that's getting bad wet traction, what psi and tire size are you running?
    If you're running more than 25 - 30psi with oversized tires( stock 1 gen tires being more oversized than stock 2 gen) wet traction should suffer.
    Higher tire pressure will reduce wet traction in all tires.
    Duratracs don't have all the much siping and are not an especially sticky tread compound.
    So if you have the tires aired up to like 40 psi or something, not much tread is going to contact the asphault; the edges of the tread do most of the gripping when it is wet.
    So if you if there isn't tread edge on the ground don't expect much traction.
    I had traction problems with the factory tires Dunlop at21(?), they sucked... I think I just ran door sticker pressure but may have aired them up for more mpg, not drop them down for wet roads; I can't remember. Well it was a dozen years ago when I had those tires..
    I haven't had these duratracs out much in the rain yet, guess I'll play around with different psi on wet roads & report back.
  15. Nov 20, 2014 at 7:33 PM
    #1915
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Ive had mine on for a week now, figure I'll post some insight...
    First off some background info -
    They 265/70/17 C rated. I bought 2 them used @ 10/32nds and 2 of them new. They are on stock Sport wheels. Fronts are the used ones @37psi. Rears are the new ones @ 35psi. They balanced out fine and have no vibrations between zero and 75 mph (havent found a reason to go over 75mph yet)
    So far, Ive driven in 15* snow, rain, mud, dirt, and 60* degree sun with them.
    They are louder than the E rated 265/70/16 Cooper AT3s I used to have on the truck. I think most of the noise is coming from the fronts though as the noise gets louder when Im turning at a low speed. My girlfriends Jeep JKU has 275/70/18 E rated Duratracs on it with about 2000 miles and they are super quiet. The noise mine make isnt that bad, but its noticeable.
    The wet/snow/cold traction is great with them. No issues as described by other members. The dry traction is is fine too. They handle mud and dirt fine as well.
    Cant really complain at all about them. Once I found the proper psi to run them at theyve been awesome.
  16. Nov 20, 2014 at 10:50 PM
    #1916
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Mine have been fine in heavy rain. Still take freeway on/off ramps at 50+mph. I did spin the rear once from a stop on a hill in the rain tho. And when it rains in Hawaii, it rains hard.
  17. Nov 21, 2014 at 5:26 AM
    #1917
    SRC
    Shawn
    Guelph, Ontario
    2017 DCSB OR
    This got me thinking more though. For only a difference of 1 pound per tire, how could the sidewall really be that much stronger? 1 pound can't be that much material, and the additional tread depth must eat up a bit of that weight difference too. There was a price difference of $60 CAD/tire to go from SL to C. There is a clear difference in weight of the E range so it's easy to see they have been reinforced. I'd love to hear someone elses take on this. Maybe I'm just delusional. $60 for 1lb of rubber seems off to me.
  18. Nov 21, 2014 at 5:42 AM
    #1918
    moondeath
    Pa, Gardners
    I've had wet traction issues anywhere from 32 to 37 psi. Wet traction gets worse with age. When they're new, they're not as bad. Get some miles and they're horrible on wet roads.
  19. Nov 21, 2014 at 5:44 AM
    #1919
    moondeath
    Pa, Gardners
    Again, with age is when these tires start having traction and noise issues. When new they're not bad.
  20. Nov 21, 2014 at 5:57 AM
    #1920
    steveo27
    Pittsburgh
    Yep. Not really worried about the noise though.
