Got a new problem, I havent spent a lot of time on.
Discussion in '1st Gen. Tacomas (1995-2004)' started by krlang, Feb 6, 2010.
  1. Feb 6, 2010 at 6:50 AM
    krlang
    krlang [OP] NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    Its goofy,
    With all of my electrical items I have added to my truck it has a new issue.
    When I use my remote starter, occasionally I get a flashing ABS light.
    The brakes are new, the fluid level is good, and if you reboot it, it passes and the light goes out. It seems to have started after I installed my Scangage II, and it happens usually with the remote start. I think it did happen once with the key. It does not log a code, and the abs works great when the light is off.
    The light goes out after a while when it fails, but it comes back on when you step on the brakes.
    any ideas?
  2. Feb 6, 2010 at 7:37 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Assuming everything's OK with your brakes ....
    There's a known issue with ScanGauge II's triggering the ABS warning light - dating back years.
