Got Exhaust Leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Apex1, Dec 9, 2018.
  1. Dec 9, 2018 at 5:31 AM
    Apex1
    Apex1 [OP] Well-Known Member
    Central CT
    2011 DCSB TRD
    I was chasing some exhaust noises on my new to me 2011 dcsb. I tried the vacuum cleaner and soapy water trick. To my surprise virtually all the joints showed a leak.
    I dropped the y-pipe and there is lots of rust in the flanges. The gaskets were falling apart.
  2. Dec 9, 2018 at 5:35 AM
    Apex1
    Central CT
    2011 DCSB TRD
  3. Dec 9, 2018 at 7:23 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    A new donut gasket and your good to go. Simple job.
  4. Dec 9, 2018 at 5:42 PM
    Apex1
    Central CT
    2011 DCSB TRD
    Already on it! Done and much quieter.
  5. Dec 9, 2018 at 7:13 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
  6. Dec 9, 2018 at 7:27 PM
    08TacoTrD
    08 TRD Offroad
    Still a straightforward job. I had to replace one bolt and nut combo due to rust.
  7. Dec 14, 2018 at 5:57 AM
    Apex1
    Central CT
    2011 DCSB TRD
    Same here, 3 round gaskets and one donut gasket sealed everything up. Had to replace 1 nut bolt combo.
  8. Apr 21, 2019 at 4:57 PM
    stevelknievel1
    stevelknievel1 Member
    2006 Silver Tacoma Sport
    Hey, I need to replace a gasket on drivers side, the bolts/nuts look the same as that picture above. Once the nut is removed, how do you get those bolts out?
  9. Apr 21, 2019 at 5:12 PM
    Apex1
    Central CT
    2011 DCSB TRD
    They are studs, they are threaded into the flange. I would not bother removing them.
  10. Apr 21, 2019 at 5:15 PM
    stevelknievel1
    Ah crap.. Did you drill them out? I got the nuts off no problem..
  11. Apr 21, 2019 at 5:43 PM
    Toy4me
    Tom
    NNJ
    :rimshot:
    My trucks' studs were so rusted they just fell out. The flange was so rusted on each side I didn't trust it to seal up with the new gasket so I put a heavy bead of exhaust sealant in there. So far so good.
  12. Apr 21, 2019 at 5:45 PM
    stevelknievel1
    That was actually my original plan.. lol
    Toy4me[QUOTED] likes this.
