Got into a damn car accident!
Discussion in 'General Automotive' started by ColtsTRD, Jul 29, 2011.
  1. Aug 2, 2011 at 11:54 PM
    #81
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Do it! long travel setup soon?
  2. Aug 2, 2011 at 11:54 PM
    #82
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i would only get glass if your getting LT soon
  3. Aug 2, 2011 at 11:56 PM
    #83
    ColtsTRD
    ColtsTRD [OP] Well-Known Member
    Scott
    AZ
    well just the front glass and then following Camburg spindles....that'd gimme another 3/4-1 inch worth of width....what do you think???
  4. Aug 2, 2011 at 11:56 PM
    #84
    ColtsTRD
    Scott
    AZ
    then maybe 295s to fill it in???
  5. Aug 2, 2011 at 11:57 PM
    #85
    PLC721
    Patrick
    Chandler, Az
    depends on how wide your tires are too?
  6. Aug 2, 2011 at 11:57 PM
    #86
    ColtsTRD
    Scott
    AZ
    :notsure:
    IDK if I wanna spend the money on it...people do it, but its expensive to do it RIGHT
  7. Aug 2, 2011 at 11:57 PM
    #87
    PLC721
    Patrick
    Chandler, Az
    do it you only live once :cool:
  8. Aug 2, 2011 at 11:57 PM
    #88
    ColtsTRD
    Scott
    AZ
    295s??? would that suffice?
  9. Aug 2, 2011 at 11:58 PM
    #89
    ColtsTRD
    Scott
    AZ
    well I only plan to marry once too LMAO!!!!!
  10. Aug 2, 2011 at 11:59 PM
    #90
    Lucario Runner
    Robert
    06 Toyota 4Runner
    True, I mean if I were in your position I would invest in it with top quality, but that would take alot of time and cash.
  11. Aug 2, 2011 at 11:59 PM
    #91
    PLC721
    Patrick
    Chandler, Az
    yeah idk man, i plan on getting glass with my bumper, and that will be before im LT but my tires are also 13.3" wide
    haha your on your own there!
  12. Aug 2, 2011 at 11:59 PM
    #92
    ColtsTRD
    Scott
    AZ
    right, and buying a nice house is a lil more important right now....I wanna getta family started ya know?
  13. Aug 3, 2011 at 12:00 AM
    #93
    ColtsTRD
    Scott
    AZ
    true
    :p :eek:
  14. Aug 3, 2011 at 12:00 AM
    #94
    Lucario Runner
    Robert
    06 Toyota 4Runner
    nice, sounds like you got your priorities straight then.
  15. Aug 3, 2011 at 12:01 AM
    #95
    ColtsTRD
    Scott
    AZ
    for sure, but I don't want the truck looking gay either...IDK I might just have them fix it with factory shit
  16. Aug 3, 2011 at 12:02 AM
    #96
    ColtsTRD
    Scott
    AZ
    But the all pros are only 2.5" wider too...maybe 285s or 295s with 1" spidertrax for a temp fix
  17. Aug 3, 2011 at 12:31 AM
    #97
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    he is running the 295s with spindles and doesnt seem to need the allpros.
    http://www.tacomaworld.com/forum/2nd-gen-builds/68703-sandmans-build.html
    the spidertrax are 1.25", so you will still be about 1.25" inside the fender per side. give or take some for the wheel backspacing difference. but will probably come out looking like olivers.
    Maybe with the spindles and spidertrax. (2") plus the 10 millimeter (1 centemeter) (265-285=20/2=10) you get from the 285s might bring you flush with the allpros. I think thats how the tire width works.
  18. Aug 3, 2011 at 12:33 AM
    #98
    ColtsTRD
    Scott
    AZ
    Oli is running 255s bro...the wider tire will look much better
    edited
  19. Aug 3, 2011 at 12:34 AM
    #99
    ColtsTRD
    Scott
    AZ
    :sighs:
    well IDK what to do...should I just have it fixed back to stock??
  20. Aug 3, 2011 at 12:45 AM
    #100
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    theres nothing wrong with stock. If you actually gained some function with wide fenders, like the long travel guys do, it might be a different story.
