Got me a 95!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kanekz, Jun 17, 2013.
  1. Jun 17, 2013 at 1:46 AM
    Kanekz
    Kanekz [OP] Member
    Hi everyone! Got me a 95 taco today. Acc cab 5spd v6. Fun as hell to drive. Previous owner cut the front springs so that will be first thing to do. Haha.
    Also I was wondering if 95 4runner parts will fit our trucks. Can't seem to find much info about it.
    Thanks in advance guys!
  2. Jun 17, 2013 at 1:52 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    95.5 3.4 5speed Xtra Cab for the freaking win!!! :D:D:D
    Welcome!! as you may have guessed, I have the same specs
  3. Jun 17, 2013 at 1:58 AM
    Kanekz
    Kanekz [OP] Member
    I have manual locks and widows. I'd like to try swap all that. 95 4runnner is available to me for cheap, will it bolt right up?
  4. Jun 17, 2013 at 6:31 AM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    Was previous owner trying to lower it or stiffen the front suspension by cutting them?
  5. Jun 17, 2013 at 8:38 AM
    Kanekz
    Kanekz [OP] Member
    Young boy was tryna go lower.
  6. Jun 17, 2013 at 8:42 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Sounds like you have a 5 lug and unfortunately the 4runner stuff is totally different.
    Your tacoma has longer doors and a somewhat different interior And 100% different suspension.
  7. Jun 17, 2013 at 9:59 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Like TacoMeElmo is asking... do you have the 2wd or 4wd? FWIW, I have a manual hub, manual trans, manual window rig. I really like the ability to fix anything that breaks with a wrench and some WD40. That being said, I haven't heard people complain about their electric windows doing funny things...
    Post up some pics, let's see this thing!
  8. Jun 17, 2013 at 11:35 AM
    Kanekz
    Kanekz [OP] Member
    Yeah it's a 2wd. It's the sky blue color. Will post when I get home. Wanted to swap out some stuff from the runner, guess that might be outta the question.
  9. Jun 17, 2013 at 12:56 PM
    colby8100
    Colby
    South carolin
    I'd leave it alone since its a 2wd. Just buy a 4 runner if you want an off road rig. The easiest way to do an auto door lock setup is with aftermarket alarm and lock actuator kit. Now power windows get tricky if the doors are the same you could use 4runner regulators and switches and make you a harness but you could make a mess if you don't know what your doing. When you change the springs you need to do the ball joints and rod ends then have it aligned.
  10. Jun 17, 2013 at 1:17 PM
    Swimmerboy2112
    Swimmerboy2112 Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    It depends what stuff you want to swap out. Motor parts will be the same assuming it's the same engine in both vehicles.
    Didn't know they made the V6 in a 2wd truck without it being an S-Runner??
  11. Jun 17, 2013 at 4:12 PM
    Kanekz
    Kanekz [OP] Member
    Everything manual on the truck. Gonna check out some alarm systems today. I would like keyless entry, and eventually pwr windows. Yeah I got a v6, and not a srunner
  12. Jun 17, 2013 at 10:57 PM
    Kanekz
    Kanekz [OP] Member
    here she is... not the greatest looking, but fun project...
  13. Jun 18, 2013 at 5:45 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    That's so strange, I had no idea the V6 came in 2wd. As far as swapping out the power locks and windows go, I would see if you can't find a Taco at the junkyard (goodluck) and take the door cards along with the window and lock motors.
  14. Jun 18, 2013 at 6:26 AM
    colby8100
    Colby
    South carolin
    The only thing is the harness connector may not be pre wired for power accessories so junkyard parts would be pointless without a harness that would work. Some companies have them pre wired gm for a fact doesn't and each year and option could have different pin locations ect.. leave it lowered paint it and boost it. because it's not 4x4 or a towing rig . The cut springs stiffen the front and could help with faster weight transfer and more traction as long as there aren't blocks in the rear to increase axle wrap. And the springs will also prevent body roll being stiffer
  15. Jun 18, 2013 at 6:30 AM
    colby8100
    Colby
    South carolin
    I tow my boat with mine lowered but I bought a kit and didn't cut my springs. Now I have 97 mazda b4000 650lb springs with a 1/4 coil cut for fitment issues to support the jz weight and transfer.
  16. Jun 18, 2013 at 2:07 PM
    Kanekz
    Kanekz [OP] Member
    I will keep it dropped, just. Better setup. Probably a djm. Will do body work and paint. I'll show progress. Just installed my 12L7 yesterday. I don't think I will boost tho haha.
  17. Jun 18, 2013 at 2:08 PM
    Kanekz
    Kanekz [OP] Member
    I also have a set of door poppers on the side, might just use that as my keyless entry. Well see.
  18. Jun 19, 2013 at 9:02 AM
    colby8100
    Colby
    South carolin
    Here's mine
    I did djm 3/4 on mine. I did new bearings, seals, rod ends, ball joints, and shocks when I did mine since it was apart.
  19. Jun 19, 2013 at 12:23 PM
    Kanekz
    Kanekz [OP] Member
    How much did that run u about? The djm kit is pretty cheap. How about all the other stuff? U like the 3/4 better then the 3/3?
  20. Jun 19, 2013 at 1:49 PM
    colby8100
    Colby
    South carolin
    Yea my rear was an inch higher than the factory. And what happened to mine eas a bearing locked up and broke the spindle. I think I jad 800 $ in it and the spindle was expensive. I thinkb ball joints were 40 each shock 40 $ each and tie rods maybe 50 $ each I think the kit was 350 $ and spindle was 250?
