Got some fender flares, need help with paint
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fiolo, Mar 13, 2012.
  1. Mar 13, 2012 at 4:47 PM
    Fiolo
    Fiolo [OP] Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    I got some oem fender flares that were painted white but I want them black, how do I remove the old paint, is there some kind of paint remover for plastic or should I just sand it
    Thanks
  2. Mar 13, 2012 at 6:46 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I would personally just repaint them. Removing the paint may cause damage and even if it doesnt, factory flares fade quickly.
    On a side note, I heard that soaking plastic parts in brake fluid will remove paint without destroying the plastic. Never tried it myself though.
  3. Mar 13, 2012 at 6:48 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    arent the stock flares fiber glass?
  4. Mar 13, 2012 at 6:50 PM
    Fiolo
    Yeah my bad, fiberglass not plastic
  5. Mar 13, 2012 at 6:51 PM
    Fiolo
    Thanks, break fluid, i may look into that
  6. Mar 13, 2012 at 6:55 PM
    Fiolo
    I may try some plastidip and see what happens
  7. Mar 13, 2012 at 6:58 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Ditto. Sand, primer, and paint. I used semi-gloss black and it turned out great.
    I would advise against this. Taking off the flares twice sucks especially if you break the tabs. Do it right the first time, see above.
  8. Mar 13, 2012 at 6:59 PM
    Fiolo
    Yeah I have to sand them a lot because of paint drips, that's why I wanted a paint remover to make it easy
  9. Mar 13, 2012 at 7:03 PM
    TACOMABOSS
    96 SR5 4x4
    Paint thinner or lacquer thinner? not sure if that would hurt the fiberglass
  10. Mar 15, 2012 at 5:35 PM
    Fiolo
  11. Mar 15, 2012 at 5:44 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
  12. Mar 15, 2012 at 5:44 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Looks good!
  13. Mar 15, 2012 at 5:45 PM
    Fiolo
    thanks man, yeah i got to wash it pretty soon so we will see how it holds up
  14. Mar 15, 2012 at 5:46 PM
    Fiolo
    Thanks!
