Got the leaf Spring TSB. Here are some pics !
Discussion in '2nd Gen. Tacomas (2005-2015)' started by khfactor, Jan 19, 2008.
  1. Nov 8, 2012 at 12:35 PM
    #541
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    I doubt it but its worth a shot.
  2. Nov 8, 2012 at 12:39 PM
    #542
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Yea that was what I was going with. I'll call and let you guys know.
  3. May 10, 2014 at 4:19 PM
    #543
    bmore07trd
    bmore07trd Well-Known Member
    john
    Baltimore Maryland
    2007 tacoma TRD off-road
    none
    Does anybody have this 4 leaf pack for sale with low low miles? My truck has 94k miles and would like to get this done....looks like its going to be at my expense which is fine. As long as i can haul my 4 wheeler ill be happy. Just need the parts or if anyone has part numbers from toyota that would be great. Thank you
  4. May 10, 2014 at 5:58 PM
    #544
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    If you're going to buy new, might as well just buy an aftermarket leaf pack
  5. Jul 1, 2015 at 1:48 PM
    #545
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Bumping this to ask a quick question....I just bought a 2015 to use for motocross, so I'm going to constantly have motorcycles in the bed. Does this TSB still apply to the new models?
  6. Jul 13, 2015 at 2:10 PM
    #546
    rmorse
    Bobby
    Bowie, MD
    Anyone know?
  7. Jul 13, 2015 at 2:12 PM
    #547
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
  8. Jul 13, 2015 at 2:15 PM
    #548
    Toyotacrawler
    Cusseta/Opelika AL
    Looks like it only goes to 2011
  9. Jul 14, 2015 at 7:06 AM
    #549
    rmorse
    Bobby
    Bowie, MD
    Bitter....My 2015 only has 3 leaf springs. Would definitely prefer 4 since I bought it to use it as a truck.
  10. Jul 14, 2015 at 7:07 AM
    #550
    rmorse
    Bobby
    Bowie, MD
  11. Jul 14, 2015 at 7:39 AM
    #551
    Toyotacrawler
    Cusseta/Opelika AL
    You're welcome @rmorse ! Check out Wheeler's off Road. I just installed the progressive 3 leaf pack on my TSB springs. To be honest the TSB springs didn't really handle a load all that well. My truck still sagged in the ass end with our RTT and camping gear loaded. I gained 2" of lift back there and paired with the 5100's the ride is so much better that before. I retained my overload spring is how I gained the 2". They have other options as well for loads. @YotaDan is full of helpful advice if you have any questions or concerns on leafs.
    rmorse and YotaDan like this.
  12. Mar 13, 2017 at 8:39 PM
    #552
    Texas_Christo
    Texas_Christo Well-Known Member
    South TX
    2015 Pyrite Mica Tacoma TRD O/R
    Hi all, new member here. hoping i can get some advice.
    I have a 15 dcsb 4x4 and it is currently 2.5 inches higher in the back (4 leaf stock) than the front.
    I was planning on doing 5100 paired with 885 to get that roughly 2.5 inches up front to help level with the back.
    i havent seen anyone do this setup without an aal or switching to dakars or wheelers. Can i expect any issues by going with this setup? other than
    the risk of the notorious vibration issues. Thanks
  13. Mar 14, 2017 at 5:57 AM
    #553
    tgear.shead
    tgear.shead Well-Known Member
    Ok, you see, there is a REASON the back end is up higher than the front. When you put stuff in the bed of the truck, it gets pushed down. There is also a reason why the suspension is called a "suspension"... and that is because it "suspends" the truck. That means that it needs the right amount of "droop". Bumps go in two directions -- UP FROM the surface of the road, and DOWN INTO the road. You want the front suspension to be somewhere in the middle of its range so that it can react to BOTH directions of bumps. If you lift the front end by 2.5 inches, then you basically don't have any more droop, which means that if you hit a hole in the road, you're going to break your teeth on the steering wheel.
  14. Mar 14, 2017 at 8:59 AM
    #554
    Texas_Christo
    South TX
    ok so does that still apply if i do an aal in the rear? should the front always have a rake?
  15. Mar 14, 2017 at 10:43 AM
    #555
    ajpagosa
    ajpagosa Well-Known Member
    SW Colorado
    2005 Access Cab TRD Off Road 6-speed manual
    Dude this is ridiculous. There are plenty of people running around with 2.5" lifts or higher and not "breaking their teeth" on bumps, as well as people leveling F/R regardless of lift and having no issues hauling or towing. There is a lot more than 2.5" of droop in these suspensions. Also 2.5" higher in the rear is way too high, far too much weight on the front unloaded. I just had the rear leaf TSB done on stock TRD off road, rear sat 1.5" higher and looked ridiculous, handled oddly too. I leveled it out with a 6112/5160 Bilstein kit, maybe 1.5" lift in front leveled out rides fantastic on the horrendous potholed dirt roads in my neighborhood.
  16. Mar 14, 2017 at 11:36 AM
    #556
    Texas_Christo
    South TX
    ill have to re-measure when i get home. center of the hub directly up to the fender right?
    i hate the amount of rake it has now. Just want to lift/level safely. so much info here, trying to read through it all
    and make the best choice on my budget.
  17. Mar 14, 2017 at 12:37 PM
    #557
    ajpagosa
    SW Colorado
    I'd jump down to the suspension section here and spend some time reading there, including the stickied threads on top. Plenty of people doing what you're thinking of without issues. As for cost what I did was approx. $1100 shipped, fully assembled (top hats etc.) Bilstein 6112 coil-over struts + 5160 rear remote reservoir shocks. I had them set the 6112 for 1.5" lift (2nd notch), you can set them from about .8" to 3" lift. Installed them myself with basic hand tools and floor jacks etc. Not rocket science. There are many other cheaper and more expensive ways to go, read a lot first and decide.
  18. Mar 14, 2017 at 5:46 PM
    #558
    Texas_Christo
    South TX
    thanks for the advice. ya i have been reading pretty heavily for about a month now.
    Creeping on here, decided i should finally make an account and ask some questions and get to know some people.
  19. Aug 19, 2017 at 7:19 PM
    #559
    CanOfRockstar
    CanOfRockstar Active Member
    2012 Barcelona Red TX Pro
    Sooooo.... how many leafs are there supposed to be?
    I have a 12 and Im wondering if I should be worried about it. Ive loaded the rear heavy a couple of times in the year ive had my taco but havent noticed any issues. a buddy of mine has an 11 and it has 4 leafs and is leaving me confuuused.
  20. Jan 3, 2018 at 4:17 PM
    #560
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    Looking for someone to sell me their TSB leaf springs. Thanks
