TSB List for 2005+ Toyota Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Angus_NB, Mar 25, 2008.
  1. Mar 25, 2008 at 10:21 AM
    Angus_NB
    Angus_NB [OP] Well-Known Member
    Riverview, NB, Canada
    '08 Tundra DC SR5 4x4
    Update Feb 3, 2021
    The 13+ year old divshare link is dead. As dead as my 2005 Tacoma.
    I have removed the link. I do not have the PDF files.
    _______________________________________________________
    TSB = Technical Service Bulletin
    A TSB is not a recall.
    AU001-05 FEB 06 Audio System - Amplifier Won't Turn OFF/Battery Drain
    AU001-06 FEB 07 Audio System - Quick Reference Diagnostic Guide
    BO001-06 JAN 06 Body - Front/Rear Window Runs Deformed
    BO003-05 MAR 05 Body - Overfender Refinishing Process
    BO004-05 APR 05 Body - Water Leaks Onto Front Floor
    BO018-07 NOV 07 Body - Bent Rear Tailgate
    BO022-06 NOV 06 Interior - Driver's Side Lower Dash Panel Poor Fit
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
    EG021-06 APR 06 Exhaust System - Ticking Noise Between 2,000-2,500 RPM
    EG043-05 MAY 06 Fuel System - MIL ON/DTC's/No Start in Extreme Cold
    EG046-06 AUG 06 Intake System - Air Intake Hose Rattle
    NV003-06 MAR 06 Body - Front End Rattle/Squeak on Bumps
    NV004-06 MAY 06 Interior - Front Seat Squeak Noise
    NV006-07 AUG 07 Body - Windshield Wind Noise at Highway Speeds
    NV007-05 JUN 05 Body - Front/Rear Popping/Knocking Noise on Rough Roads
    NV007-07 JUL 07 Body - Dech Side Panel Rattle
    PD039-04 SEP 04 Pre Delivery - Initial Calibration Of Compass
    PD075-06 AUG 06 Pre Delivery - TPS Initialization Procedure
    PG004-06 NOV 06 General - TPS Diagnostic Tips
    SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
    SU002-05 NOV 05 Suspension - Rear Suspension Noise
    SU006-07 SEP 07 Suspension - Harsh Rear Spring Ride With Heavy Loads
    TC004-06 JUN 06 M/T - Clutch Pedal Squeaking Noise
    T-SB-0132-08 JUL 08 Drivetrain - Driveline Vibration Between 15 - 25 MPH
    T-SB-0305-08 SEP 08 Suspension - Rear Spring Harsh Ride
    T-SB-0326-08 OCT 08 Engine Mechanical - Oil Leak from Front Timing Cover
    T-SB-0164-09 MAY 09 Abnnormal Sound from JBL Subwoofer
    T-SB-0119-10 MAY 10 Steering Intermediate Shaft Rattle Noise
    T-SB-0359-10 DEC 10 - Suspension - *Updated* Rear Spring Harsh Ride
    T-SB-0250-12 DEC 12 - Drivetrain - 2WD Rear Propeller Shaft Clunk/Thunk Noise
    T-SB-0008-14- 03 FEB 14 - Driveline Vibration Part 1 Part 2
    T-SB-0044-14- 07 JUL 14 - Spark Knock Noise
    T-WB-POL14-03 - 15 JUN 14 - Warranty Extension for Headlamp Assembly Bubbling 2005-2011
    T-SB-0016-13 01 FEB 13 - 4WD Rear Propeller Shaft (Driveshaft) Clunk/Thunk Noise
    Each TSB can be read and / or downloaded here (dead link removed).
    In cases where a TSB has more than one revision I have uploaded the latest revision.
    There are a few other TSBs that I do not have PDF files for.
    If you have a TSB that is not on the list, let me know and I will add it or also PM a moderator to have it added since the OP has not been here in a while.
  2. Mar 25, 2008 at 10:27 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    nice compilation. thanks
    FriarTuck likes this.
  3. Mar 30, 2008 at 9:50 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    Since I found this site I have been able to identify two of my existing problems. The bottoming out of my rear end and my windshield noise. Great job.
    TacoNorth2010 likes this.
  4. Apr 17, 2008 at 8:32 PM
    415tacoma
    415tacoma Well-Known Member
    Woodacre, ca
    08 TRD Sport Debadged
    anymore up dates for 2008s? thanks
  5. Apr 20, 2008 at 3:21 PM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    I would like to know if the 08 will have the same leaf spring TSB..... It's the same part ##:confused:
  6. Apr 20, 2008 at 5:03 PM
    missileman125fw
    missileman125fw Well-Known Member
    Thanks for the info!!
  7. Apr 20, 2008 at 5:12 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it will......toyota just has to update the tsb to include the 08 models.....which should be soon.
  8. Apr 21, 2008 at 8:56 PM
    Rockstar2448
    Rockstar2448 Well-Known Member
    Maryland
    05 Indigo Ink TRD Sport D-Cab LB 4x4 // 2020 Super White TRD Sport D-Cab LB 4x4
    2005: Toytec 3" Lift, Helo Maxx6 Chrome 17x8, Nitto Terra Grappler 265/70/17, Polished Billet Grill-Full Front Kit, Westin Polished SS Tube Steps, Leer 700 Tonneau, Fog Lights On Anytime, Debadged, USA Spec iPod Adapter, Britax car seat with special UNC color scheme, Window Tint, SilverStar bulbs 2020: TRD Skid Plate with front spoiler delete, emblems partial removal/blackout, Toyota folding hard tonneau
    After joining this forum, which is great by the way, I've learned some interesting things. Like I didn't realize there were so many TSB's out there. I have a 2005 Tacoma with 32,000 miles and I would venture a guess in saying I probably haven't received any of these notices. Anyone know how I can get myself on the mailing list for these things? Of particular interest in the rear leaf spring one. I haven't done a lot of towing with my truck so it hasn't been a problem, but what if I do and have trouble? Does the TSB for the rear springs change the ride without weight which is the usual condition of use for my truck, or at least minimal cargo except for passengers. It's probably already too late to convince Toyota to do the work free of charge as I'm in the neighborhood of 3 years and almost 36,000 miles. Any thoughts?
  9. Apr 22, 2008 at 9:15 AM
    ChrisDeSoup
    Up in ya
    You can go to toyota.com and sign up for TSB access. I think they charge you $10.00 per day or some annual fee if you want unlimited access. I think edmunds.com has a free one but I'm not sure.
    good luck!
  10. Apr 22, 2008 at 3:14 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    As far as I know, they don't mail them out. That's a popular misconception. These are not recall notices because they're not considered safety issues.
    Don't wait though. You're under 36K miles. That's what counts.
  11. Apr 22, 2008 at 4:02 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    I thought they used the year as well?
  12. Apr 23, 2008 at 11:39 AM
    edoilfan
    edoilfan Member
    Alberta
    07 TRD
    TRD exhaust, AFE pro dry stage 2 cold air intake, AFE TBS
    I was in for the windshield noise repair but it's still there. Not as prevelant but still really annoying, especially when meeting semis on a 2 lane highway. Anyone been in and still having the problem??
  13. Apr 23, 2008 at 3:34 PM
    Rockstar2448
    Maryland
    I have the windshield noise on occassion but I've never taken it to the dealership to have it fixed. Now that I know what it is, I'm just going to fix the stupid thing myself. It doesn't do it all the time, just at highway speeds when there is a lot of cross or head wind to deal with, otherwise I don't usually hear it at all. Maybe I'm luckier than some that seem to have a lot more problems with it.
  14. May 3, 2008 at 5:28 AM
    rrtr2008
    rrtr2008 Member
    san jose, Ca
    08 tacoma SR5
    I don't see any TSB'S for 2008 I called my local Toyota dealer to have a TSB done on my rear springs because when i put even a small load in it it becomes a low rider truck. The dealer called me back and said nope no TSB for this year so now I'm stuck with what i consider a 1/4 ton truck quite a shift from my last truck that was a 2001 dodge 2500 diesel. a 3/4 ton truck that barely noticed a 1 ton load in its bed. GRRRR
    ColoTacoPrerunner06 likes this.
  15. May 3, 2008 at 5:42 AM
    rrtr2008
    rrtr2008 Member
    san jose, Ca
    08 tacoma SR5
    I have owned several trucks maybe its unfair to blame the Japanese for not knowing how to make trucks that can handle a load. But every Japanese truck that i have owned either wont handle a load (over rated tonnage wise) or they ride like little lumber wagons (similar to a Harley with a rigid frame.)
    My 2008 Taco has a great car like ride but with 500 pounds of tools on board its like a frikin lowrider.
    Dougk420 likes this.
  16. May 3, 2008 at 5:58 AM
    RoadKill
    RoadKill Northern Alliance: padawan
    North of the border
    First gen 4x4
    285x70x17 offset rims+ 1.5 spacers, rear Timbrens + 3 inch lift add a leaf, Sway-a-way coilovers + camburg control arms, Fender flares (2.5 inch), clear lights, headers, sliders, roll bar
    Add a leaf?
  17. May 3, 2008 at 10:22 AM
    ChrisDeSoup
    Up in ya
    Hey neighbor, what dealership did you go to, I sent an e-mail to capitol toyota they just don't respond. I was going to try to call toyota next week and tell them I need it fixed so I can carry some concrete. I understand if you call toyota they will make the d-ship fix it.
  18. May 3, 2008 at 3:49 PM
    rrtr2008
    rrtr2008 Member
    san jose, Ca
    08 tacoma SR5
    Chris at Capitol Toyota is the one that told me of the no TSB'S for 2008
    408 979 4051
    BTW I like the Thomas Paine quote but as a strict constitutionalist i think he would be spinning in his grave about the USA being the world police IE: Iraq, Viet Nam, Iran (next) need I say more
  19. May 9, 2008 at 12:38 PM
    Danman
    Danman New Member
    Portland, OR
    06 Tacoma DC TRD Sport
    My 06 Double cab is the third Toyota pickup I've owned. I've loved all of them despite their lousy rear suspensions. The first was an '88, the second was a '99 4x4. I had trouble with the leaf springs in both of those. I had the leaf springs in the '88 re-arched and added a leaf. I had a leaf in the '99 break going over a speed bump so I had to replace those and added a leaf at that time too.
    I started looking around online for a solution for my '06 because I have been noticing the bottoming out and sag and was thinking that I was going to have to add a leaf or something. After stumbling across this great forum and saw the information about the TSB, I decided to give a call to Toyota's 800-331-4331 Customer Experience Center. I didn't let on that I knew about the TSB and told the guy about my problems and, while he was helpful, he said that he couldn't find anything on that. Then I told him that I had seen the TSB SU006-07 and he looked it up and magically found it. At any rate, he said that it is covered under the warranty and would have the Customer Relations Rep at my local Toyota Dealership (Beaverton Toyota in Beaverton, Oregon) contact me about getting the work done. We'll see how it goes from here.
    Thanks for all the great info!! Hopefully, I'll be saving a bunch of money by getting Toyota to cover it under warranty.
  20. May 11, 2008 at 9:06 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I'm suprised that it sags. I tow an 18' Ranger bass boat with my 2005 2WD Tacoma. Without any problems, and the truck doesn't sag at all. I do not have the TRD package either. I guess the 2005 model was better built. I have 84,000 miles & it is still just as strong as when it was new. My 2003 Tacoma was a different story, but that was a small truck. It did sag.
