got the lift installed...
Discussion in 'Suspension' started by LonghornTaco, Oct 25, 2008.
  1. Oct 25, 2008 at 8:20 AM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    got the front lift installed and I'm at Discount Tire getting the tires mounted. After that and the alignment, I'll take and post pics.
    But, I set the ToyTec coilovers like the instructions said and I got 4" of lift rather than 3. And the damn things are practically impossible to adjust on the truck, so I'll have to take the shock assembly back off to adjust down. In the meantime, am I gonna damage my CVs if I am only city driving? I also dropped the diff and inch.
    But, so far...I like!
  2. Oct 25, 2008 at 8:22 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Glad to hear, can't wait to see how it looks.
  3. Oct 25, 2008 at 9:31 AM
    LonghornTaco
    Minnesota
    any thoughts on the health of the CV joints with the 4" lift up front if just city driving? Also, I know it will probably settle some, but how much can I expect it to settle? I'm sure not a whole inch...
  4. Oct 25, 2008 at 11:08 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    I wouldn't do it -- but I may be paranoid about things like that. Fix the height first and then go get your wheels...
  5. Oct 25, 2008 at 12:10 PM
    LonghornTaco
    Minnesota
    Well, I've already got my tires and has my alignment done. However, I did the alignment at Firestone and I bought the lifetime alignments so I could make adjustments.
    Next weekend I'll probably take it apart and adjust it down.
  6. Oct 25, 2008 at 12:58 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    PICSSSSSSSSSSSSSSSSSSSS Where are the picsssssssssssssssssssss?
  7. Oct 25, 2008 at 1:42 PM
    LonghornTaco
    Minnesota
  8. Oct 25, 2008 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    4" is BAD. Not sure how long your CV's will last. I have heard some that fail pretty quickley, others can last a few months.
  9. Oct 25, 2008 at 6:56 PM
    LonghornTaco
    Minnesota
    How much is it to replace the CV joint(s)?
  10. Oct 25, 2008 at 7:03 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    It's one of those things thats a $12 part but if you have someone else do it they'll put a hole in your wallet. If you do replace them your self make sure you get the solid slip on ones and not the ones that are cut in half and you clamp them together.
    IMO just lower it an inch and don't worry about it.
    Truck looks good by the way!
  11. Oct 25, 2008 at 7:05 PM
    LonghornTaco
    Minnesota
    Oh, that's what I plan to do - take it down an inch. Just wanted to know...
  12. Oct 28, 2008 at 10:00 PM
    LonghornTaco
    Minnesota
    So, tonight I finally tackled adjusting those coilovers... I was going to do it on Thursday, when I had some help, but I was starting to get a little paranoid about blowing a CV joint. I've heard days or months... So, I went to O'Reilly's got the last couple of tools that I needed (borrowed someone elses last time) and did it myself.
    Took me about 2 hours (would have been a little easier and faster with someone else) but I adjusted the coilovers down just over a half inch (which should translate into 1" lower). As soon as I torqued everything down, put the tires back on and lowered the truck off the jacks, I measured it and it was EXACTLY THE SAME!!!
    I drove it around the block and it appears to have gone down almost 3/4". I'm gonna check it again when I get to work tomorrow and see if it's settled anymore. Otherwise, I'm gonna have to take it apart again and adjust more!
    In order to get the coilover off, I had to take the ball joint of the UCA off the spindle which I wasn't planning on - so I practically had to take the whole damn thing apart!
    Anyway, I'll keep you updated.
  13. Nov 5, 2008 at 3:04 PM
    DAN LUSHER
    DAN LUSHER HI-TECH LIFTS
    ELYRIA, OHIO
    TACOMA
    3.5 INCH LIFT , MORE TO COME.
    Got a question all cvs are pretty much the same to much angle and they bind. I have lifted alot of trucks, i mean alot, if they are raised off (full drop)the ground and wheels rotate freely , there will be no and i mean no issues chevy, ford , dodge. Toyota is no difference drop the diff 1 inch no problems whats all the early failure talk. Have not seen any fail.
