Got the Method Standard 17" - Now What Tires?
Discussion in 'Wheels & Tires' started by 1Badmamajamma, Sep 21, 2012.
  1. Sep 21, 2012 at 4:32 PM
    1Badmamajamma
    1Badmamajamma [OP] New Member
    So Cal
    PreRunner
    I bought a set of the 17" Methods but dont know what tires or lift would go well with it. I have stock Suspension now and am thinking of just leveling the front to fit 285/70/17 tires. I ride MX and am a short guy so I still want to be able to load my bike by myself. Will these tires fit well or rub in the rear when my truck is loaded?
  2. Aug 26, 2014 at 10:39 PM
    BS2014
    BS2014 Active Member
    Las Vegas
    2014 Tacoma 4x4
    4 inch Tuff country lift with uni-ball UCA's, 2 inch spacers in the rear (for now) 16 inch method double standards with 33" Toyo Open Country MT's
    What offset ?
  3. Aug 31, 2014 at 5:50 AM
    Neutral
    Neutral Well-Known Member
    Fella
    Alabama
    14 SR5, 25 SR5
    14 4.5" RCD, Pelfreybilt armour, Fox coilovers/shocks, Alcan leaf springs, 4.56 gears, 35's 25 Stock
    Question on the rims... Are they these? ( picture below) I am looking at buying them also but I was wanting to know if the center cap and/ or the fake beadlock bolts were not plastic? I originally planned on getting xd Addicts until I found out the center caps and fake beadlock bolts were made of plastic. I mean why put plastic on a rim?! :facepalm: :goingcrazy:
  4. Aug 31, 2014 at 7:55 AM
    BS2014
    Las Vegas
    2014 Tacoma 4x4
    I'm almost 100 percent positive the bolts are steel on these. That's why I ordered them as well.
  5. Aug 31, 2014 at 8:10 AM
    Neutral
    Fella
    Alabama
    14 SR5, 25 SR5
    Awesome, thanks!! Is the center cap aluminum?
  6. Aug 31, 2014 at 8:13 AM
    Colt562
    Colt562 Well-Known Member
    Brett
    SoCal
    13' TRD Sport 4x4
    Icon Stage 3 Lift Kit...Dakars
    wrap them in some Nittos. I am very happy with mine. I also have the same rims.
  7. Aug 31, 2014 at 8:16 AM
    BS2014
    Las Vegas
    2014 Tacoma 4x4
    That I'm not sure of. I'm still waiting on mine but I would assume aluminum. I'm running 33" Toyo AT 2's. Best tire if you don't spend too much time in the desert.
  8. Aug 31, 2014 at 9:22 AM
    Neutral
    Fella
    Alabama
    14 SR5, 25 SR5
    When you get the rim in let me know if you don't mind. I've.heard good and bad thing about those Toyo's. Seems to me.like more people run Goodyear Duratracs. How high of a leveling kit you looking at? I know stock you can run 265s so I'd say a 2 or 3" lift should easily clear those 285s.
  9. Aug 31, 2014 at 9:47 AM
    BS2014
    Las Vegas
    2014 Tacoma 4x4
    I was lifted now I'm just leveled. I lifted the front 3 inches. It sits a hair higher in the front but it looks pretty leveled. My best friend won baja 1000 back to back on toyos. I didn't go with MT's because I drive on the street mostly.
