GPS antenna location
Discussion in 'Audio & Video' started by 06TRDbama, Oct 29, 2007.
  1. Oct 29, 2007 at 10:07 AM
    06TRDbama
    06TRDbama [OP] Well-Known Member
    Maryville, TN
    06 Prerunner TRD Sport
    For those of you that have a navi system, where did you place the antenna for best reception? inside our outside the window? thanks
  2. Oct 29, 2007 at 2:21 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    most people put it on top the dash in one of the corners, but i put mine behind the oh shit handle on the passenger side. i removed the a-pillar cover and ran it up and used the magnet to attach it right between where the screws are to attach the handle. i get 3/4 to full signal most of the time.
  3. Mar 7, 2010 at 10:08 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I attatched mine directly to the top of the head unit. The signal is full strength even through the plastic dash. The antenna is out of sight and a clean easy install.
  4. Mar 7, 2010 at 11:52 PM
    The_Hodge
    SC
    holy revival batman!!
  5. Mar 8, 2010 at 5:57 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    x2
