GPS VS Speedometer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coffeesnob, May 19, 2010.
  1. May 19, 2010 at 5:08 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    What would you say is the most accurate? A 2010 Tacoma speedometer or a Garmin GPS. My Garmin is consistently reading about 2 MPH faster than my Tacoma speedometer. The odometer is dead nuts with the Garmin but with all the electronic trouble Toyotas are accused of having it makes me wonder which is right. Maybe it has to do with the cruise control. Whats your thoughts, ya I know 2 MPH is not a big deal but it is a brand new truck. Has anyone else checked out the speedometer to see if it is acccurate? Thanks!:confused:
  2. May 19, 2010 at 5:09 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    i've heard gps is more accurate.
  3. May 19, 2010 at 5:09 PM
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    all of the speedometers are off just a little bit.....
  4. May 19, 2010 at 5:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The difference between your SPEEDO and your ODO is the display mode. The ODO is displayed from a digital source to a digital display. The SPEEDO is a digital source displayed on an analog display. Digital to Analog creates inherent error, usually on a non linear scale (It'll be like 2% off...so 1mph off @ 50 mph and 2mph off at 100 mph...as an example. 10% is allowable I think...)
    So...your ODO is right, and the GPS gives the correct speed. Your needle is just a little error prone.
  5. May 19, 2010 at 5:14 PM
    coffeesnob
    VA
    they are?
  6. May 19, 2010 at 5:15 PM
    P-Hill Tacoma
    P-Hill Tacoma Well-Known Member
    Missouri
    2010 DC Short Bed 4WD Off Road Barcelona Red
    Fr Bilsteins@1.75", Rr Bilsteins w/ 1.5" AAL & RideRite Airbags, Truxedo Lo-Pro Tonneau, Step Tubes, 1.25" Spidertrax
    When garmin says 70 my Tacoma says 73-74. Haven't checked the odometer. Just figured it was off the same as the speedometer.
  7. May 19, 2010 at 5:18 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    yes + or - 10% is the amount allowed by law. idk why we cant make ones that are dead on with all of our fancy technology but thats the way it is. slight difference sin tire size will also make a difference.
    just for reference, i found my base 2004 reg cab to be just about spot on
  8. May 19, 2010 at 5:20 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    We can- but producing those needle assemblies to such perfect tolerances would be far more expensive and have another part that could fail and/or require maintenance.
    I think most folks have found scangauge units show speed correctly, as read from the ODBII port.
  9. May 19, 2010 at 6:01 PM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    Both my Garmin 765T and 660 are dead on with the speedometer of my Tacoma from 0 to 80 mph. My Honda Element that I just traded in was always off 2mph when the speedometer went above 20 mph.
  10. May 19, 2010 at 6:04 PM
    zdog
    zdog Well-Known Member
    Oregon
    2010 5lug Access Cab SR5 2.7/5speed
    This is about where I am....2010 Tacoma 4 cylinder.
    ZDog
  11. May 19, 2010 at 6:15 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    on my cbr1000rr my bike said 76 garmin zumo550 said 71
  12. May 19, 2010 at 6:15 PM
    crf69
    Ohio
    ummm yeah
    wait....wrong forum.....too many windsor and seven up's
  13. May 19, 2010 at 7:08 PM
    bruinsrme
    bruinsrme Well-Known Member
    Scott
    Worcester
    BRM 2010
    well GPS could be affected by terrain.
    Is the GPS a 2D or 3D resultant.
    If 2D then it is esentially using Ve and Vn (velocity north and velocity east)
    If a 3D fix is calculated then Vv (velocity vertical) or altitude is figured in to the equation.
    If 2D is used it doesn't account for the up and down of the terrain.
    Another factor is how often a fix or position is calculated. If every 3 to 5 seconds then you loose that data in between fixes. the GPS only calculates point to point (fix to fix) or successive approximation, so if you are going 65mph and go thru a large sweeping turn the GPS may not actually calculate the total distance traveled but only from when you entered the turn to some point in or out of the turn increasing or decreasing the actual distance traveled.
    Angle of elevation of the satellite also is a factor as well as if the satellite(s) have the latest Almanac and Ephemeris data.
    If I was to believe one over the other I would believe both.
    Oh by the way, is your GPS calculating speed using a statute mile 5280 feet or a nautical mile 6000 feet. More than likely its using a nautical mile.
  14. May 19, 2010 at 8:00 PM
    DarkKnight4684
    DarkKnight4684 Member
    10 DC LB Sport 4x4
    I have the same thing happen to me. I have the Garmin 765T and it is consistently off by 2 MPH. When I used the GPS in my Scion tC, it was dead on. So yes, something is off in our Tacomas.
  15. May 20, 2010 at 4:47 AM
    coffeesnob
    VA
    I don't know if its 2d 3d or what..it is a Nuvi 260 or 65. I drove 1800 miles the last week and it was consistently off a few MPH. It sounds like the guy with the Scion is having pretty much the same disparity as me. To the posts that say 10% is allowable by law I believe you but I think that is ridiculous that car makers can't get closer than that. In fact I don't ever remember having a speedometer that I didn't really trust, especially brand new.:confused:
  16. May 20, 2010 at 4:52 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    How many have you compared to GPS tho?? My two cars right now are the only ones I've had a GPS in- and most of the time your speedo shows faster than you are really going- so you won't get tickets or anything...
  17. May 20, 2010 at 5:20 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    gps for sure. but my nav and speedo match up perfect
  18. May 20, 2010 at 5:28 AM
    n2advnture
    n2advnture Well-Known Member
    Mark
    New Market, MD
    2007 Double Cab 4x4 TRD Sport Longbed
    Front skid plate color matched to wheels, Weather Tech floor mats, Window visors, Bug deflector, Exhaust tip, Bed mat, EZ down tail gate, Redline hood struts, Cover Wet Okole custom seat covers w/ heaters, FJ Anthracite Special Edition Wheels, 265/75/R16 BFG All-Terrain KOs, Pioneer Avic Z110BT, Back up cam in Pop N Lock, XTang Solid Fold tonneau, Escort Xi45 hardwired radar detector, Scan Gauge II
  19. May 20, 2010 at 5:40 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    Also, if you have increased your tire size and or your gear ratios that can also change the speedometer. I remember when I lifted my chevy and it went off by 5 mph. Also GPS accuracy will be based upon the signal strength.
  20. May 20, 2010 at 7:10 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Wow, it's amazing how these topics come up over and over. Not sure on the "base" 2wd tacoma's, but for the rest of us it's been shown over and over that the odo is accurate and the speedo reads 6% fast. So if you're speedo says 65, you're doing 61. That's one of the main reasons people switch to a 265/75 from a 265/70 tire...because it eliminates the speedo error and makes it accurate.
    BTW, among those that have tested it with GPS, I haven't. I've discovered my error when following another vehicle that was dead-accurate. And since then have tested it against the radar checks. 6% error is accurate. Reads 3 mph fast at 40, 4 mph fast at 65, etc.
