Grade my lift
Discussion in 'Suspension' started by JPT, Apr 3, 2013.
  1. Apr 3, 2013 at 10:28 AM
    JPT
    JPT [OP] Avid Jeep Hater
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    Blacked-out emblems, Oem Roofrack, Uws Low-Pro, Color-Matched Front Grill, Custom Pinstripes
    After spending countless hours on this website I believe I have found the proper lift for what I want to do. I am a 4x4. I'm trying to get around 2.5-3 inches of lift. I love to off road but don't get to do it terribly often. Trying to do this right but not spend thousands of dollars. Please Grade the following
    - Adjustable front bilstein 5100s (set at 0)
    - Rear bilstein 5100s
    - Ome 885x front coils
    - 2 inch Wheelers rear aal.
    I plan on getting all of this, then when I can afford it new ucas. Is there anything Im missing? Please leave lots of feedback. :D
  2. Apr 3, 2013 at 10:32 AM
    JPT
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    :eek: What did i do wrong?
  3. Apr 3, 2013 at 10:33 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I would swap the Billies for OMEs the shocks that were made to go with the 885s.
    The 885s will give you around 2 1/2" up front.
  4. Apr 3, 2013 at 10:37 AM
    JPT
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    I've heard of people saying toytec doesn't necessarily support this, but I also read that a lot of people on here have this. The reason i did front and rear 5100's is because I could get the package from Down South Motorsports that they offer to TW. What is the name of the Ome shocks?
  5. Apr 3, 2013 at 10:39 AM
    Large
    Large Red
    OME 885x, if you want about 2.5" front lift with a DCSB. FWIW, I ran 885s on 5100s without issues, and the member I sold them too has 0 issues as well.
  6. Apr 3, 2013 at 10:40 AM
    JPT
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    What leaf pack do you guys suggest will lift the back as much as the 2" aal?
  7. Apr 3, 2013 at 10:41 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    OME nitro chargers are the name of the shock. Without going all out nobody is going to say its a great lift. Totally up to you though, its your truck.
  8. Apr 3, 2013 at 10:42 AM
    JPT
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    Why did you get rid of them and what is your current setup?
  9. Apr 3, 2013 at 10:46 AM
    Spitfire
    Spitfire Well-Known Member
    AZ West Valley
    05 TRD Taco
    OME Lift, Stubbs Sliders, Truxedo cover, Pioneer Avic deck, speakers/amp etc., Black badges.
    Being a brand new truck I think an AAL is fine, you don't need a whole leaf pack right away since your stock leafs are still fresh. I am upgrading my AAL to a leaf pack but my truck is an '05 and the leafs are sagging.
    I ran 885 OMEs with OME's shocks and it was a great ride. The Bilsteins have a warranty advantage over the OME's though (lifetime Vs. 2 year). I had one of my rear OME's fail just before 2 yrs.
    I put your original plan at a B/B- completely fine if you aren't interested in coilovers, remote reservoir shocks, and other various sexy items.
  10. Apr 3, 2013 at 10:50 AM
    JPT
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    Thank you. The shocks are basically off of opinion, but the ome's are suggested because 885s are normally paired with them. Correct?? :confused:
  11. Apr 3, 2013 at 10:51 AM
    Large
    Large Red
    Ran 885s to fit 285s, switched to 886s and nitro charger shocks to accommodate a plate bumper and a winch, which was about 180 lbs of front weight, they were both good and very solid lifts. Added a lot more weight with skids and sliders so I went with Kings all around and a dakar leaf pack in the rear.
  12. Apr 3, 2013 at 10:52 AM
    Large
    Large Red
    You won't have any more issues running 5100s with 885s than you will with 885s and the OME shocks. The only difference is price, and I could not tell a difference in the ride.
  13. Apr 3, 2013 at 10:53 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Disregard all the other negative comments cause this is the same lift I have for the most part except I now have ICON rear reservoir shocks but even before those I loved the feel of this lift! Its a little bit on the stiff side but most of the other lifted Tacomas I've been in were the same way. I say go for it and stick with this lift. ;)
  14. Apr 3, 2013 at 10:57 AM
    JPT
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    I plan to basically do this and later on add an arb front (In like 2-3 years). Do you have a build thread so i can look at yours and maybe copy? :)
  15. Apr 3, 2013 at 10:59 AM
    scocar
    scocar hypotenoper
    Although not the same truck, I ran 881s with 5100s on zero, and they semed to get really stiff after a while. I swapped out the 5100s for Nitros, and they are still firm, but less harsh. Regardless of truck model, OME shocks are designed specifically to work with the spring rate specifications of OME coils. It stands to reason that this will provide an optimized ride quality with OME coils.
  16. Apr 3, 2013 at 11:00 AM
    JPT
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    I think i looked at your build a few days ago :D haha. How close are you to sitting level with this setup? Any bro-lean?
  17. Apr 3, 2013 at 11:03 AM
    Large
    Large Red
    You are right, I didn't run mine long enough for a thorough review. The only reason I ran 5100s with 885s is because I found a good deal on both and they were all brand new in box. Otherwise I would have run 885s with the OME shocks.
  18. Apr 3, 2013 at 11:06 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would say that's a decent quality lift. Overall, I would say a B- if you're only comparing it to other stock travel lift kits.
    I would add a set of UCA's and opt for a multi-leaf AAL instead of a single AAL. I also agree, if possible I'd keep like parts together (OME coils with OME shocks) but there are no issues with the setup you're looking at. Talk to DSM, they used to sell OME stuff even though they didn't advertise it. They also sell the Icon 3-leaf AAL so you might be able to get everything from one vendor. You might pay a little more for some parts but you'll save in shipping costs.
  19. Apr 3, 2013 at 11:07 AM
    Spitfire
    AZ West Valley
    05 TRD Taco
    I never drove a truck with the 5100s and 885 coils, but was very happy with the ride I had with OME shocks and 885s.
  20. Apr 3, 2013 at 11:11 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    A multi leaf AAL like the Icon or Wheeler's 3 leaf will still sag if your stock leafs are soft, which most are. I rode with the wheeler's 3 leaf for a while and then swapped the 2nd Toyota leaf out for a 70's chevy leaf and now the rear is all perky. Barely sags with a load.
    Get your minds out the gutter!
