gray wire mod for 2nd gen tacomas??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by redline929_e, Jul 19, 2007.
  1. Jul 19, 2007 at 9:39 PM
    redline929_e
    redline929_e [OP] Member
  2. Jul 20, 2007 at 1:46 AM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    That is awsome. Hopefully someone knows.
  3. Jul 20, 2007 at 5:52 AM
    flyman767
    flyman767 Well-Known Member
    Yes...it will work. The grey mod was for older Tacoma's and the new generation is the basically the same with the exception of different color wires to locate.
  4. Jul 20, 2007 at 8:16 PM
    redline929_e
    wow this one looks alot harder than it does for the 1st gen tacomas!!! is there a more simple way?? do you know if it will hurt the rear axle??
  5. Jul 20, 2007 at 8:29 PM
    redline929_e
    do u have to use a relay??
  6. Jul 21, 2007 at 7:17 AM
    flyman767
    No, it won't hurt the rear axle. The axle in the 4WD is the same as the 2WD. The 2WD is already configured with the grey wire mod because the locker is engaged anytime(below 5MPH). The relay is not difficult to install from what I see and read...you have to have a way to switch the locker on/off.
  7. Jul 21, 2007 at 12:39 PM
    gcwaterski
    gcwaterski Well-Known Member
    Can someone post it on here so that we dont have to subscribe to tundrasolutions?
  8. Jul 21, 2007 at 2:36 PM
    flyman767
  9. Jul 23, 2007 at 9:07 PM
    gcwaterski
    gracias :D
  10. Dec 5, 2008 at 11:38 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
  11. Dec 6, 2008 at 12:35 AM
    nvdeserted
    Reno, NV
    Thanks Jolayiv. I'm gonna assume the wire coloring is the same for 09s. Now I know what I'm doing tomorrow...
  12. Dec 6, 2008 at 12:48 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
