greasable shackle bolts
Discussion in 'Suspension' started by jbrandt, Dec 22, 2011.
  1. Dec 22, 2011 at 2:48 PM
    jbrandt
    jbrandt [OP] Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  2. Dec 22, 2011 at 8:04 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    maybe pull the bolts out and apply some of this.....it lasts a looooooong time.[​IMG]
  3. Dec 22, 2011 at 8:10 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    remove the bolts drill into the shackle, tap it, put a zerk on it. Tada!
  4. Dec 22, 2011 at 8:14 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    yep that to.man,why didnt i think of that.......:drunk:
  5. Dec 22, 2011 at 8:20 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    now,now
  6. Dec 23, 2011 at 10:19 AM
    jbrandt
    Justin
    I was kind of upset when I found out the shop I had install the bushings (needed to press out the OEM sleeves) didn't grease them... Otherwise, it probably wouldn't be an issue right now.
    What do you mean drill into the shackle? You mean drill a hole into the end of the shackle bolts?
  7. Dec 23, 2011 at 10:25 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Drill into the shackle housing without the bolt in place. Use a location where it will be easy to get a grease gun on it. Basically you are drilling a path for the grease to get to where to bolt is. Tap the end of the hole you just drilled so you can thread a zerk on it.
    I have seen this done for caliper slide pins as well.
  8. Dec 23, 2011 at 2:09 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    no.in the middle of the shackle,i think what he meant.
  9. Dec 23, 2011 at 2:14 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    From experience, I can tell you that it lasts just until you go 'wheeling and drive through a deep puddle, or expose it to a winters worth of road salt. My re-seized spring eye bolts were covered in the stuff during install.
  10. Dec 23, 2011 at 2:18 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    wow,first i've heard that.i use this stuff all the time and it hold up great imo.
  11. Dec 23, 2011 at 2:22 PM
    JDMcQ
    I figured it would too, after all, it is a royal pain to get off of anything. The spring eye bolts seized in the springs and I used a shitload of it on them ( I get to cut them out..again, YAY!). I have also tried it on skid plate bolts with similar poor results.
    I recommend marine grease, or caliper grease for water resistance.
  12. Dec 23, 2011 at 2:27 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    damb.....good to know.just never had that issue and yeah your right on getting it on everything else,before you know it,its on your elbow/face/clothing....lol
