Greased my drive shaft...
Discussion in '1st Gen. Tacomas (1995-2004)' started by subtleshift, Feb 26, 2011.
  1. Feb 27, 2011 at 4:42 PM
    #41
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    this may be accurate but what 4WD is getting at is that alot of people including myself use the same grease for all three and have never had a problem what so ever.
  2. Feb 27, 2011 at 4:44 PM
    #42
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    same for most Toyota dealerships.
  3. Feb 27, 2011 at 6:02 PM
    #43
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    all i know is i work on helicopters we have 14/28 day inspections as part of the inspection you grease every fitting on the head of the aircraft and you grease until it purges clean grease and inspect the old shit that comes out looking for water muds dirt and other comtaninants. thats how i grease mine and i do it every oil changes so every 3000 or 3 months i have upwards of 340,000 miles on all original parts including joints. and also autozone sells a grease needle for like 3 bucks. its like a hypodermic needle with a zerk on the end thats how i grease my ball joints and everything of that type it helps and is a good cheap investment. P.S. i drive my truck like i stole it everywere and no issues. i use the cheap walmart red grease. below is a link to what i am speaking of
    VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
    http://www.amazon.com/Lumax-S-S-Grease-Injector-Needle/dp/B000MD4YWK
  4. Feb 27, 2011 at 6:10 PM
    #44
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    How exactly does that needle get into the stock boots/bushings? Just stab it?
  5. Feb 27, 2011 at 6:21 PM
    #45
    mackattack07
    william
    what i do is i have a paint pen i put a dot then i slowly push it through grease it till it purges then its good. next time i go to do it i go in the same dot and re paint it that way i go throught the same tiny tiny hole each time the rubber will close the hole back up with no issues. the only downside to doing this is that your pushing thich grease thru a needle thus it makes it a little hard to pump and it takes alot of pumping if they are dry
  6. Feb 27, 2011 at 6:22 PM
    #46
    mackattack07
    william
    just because toyota didnt put a fitting on it doesnt mean it cant or shouldnt be greased
  7. Feb 27, 2011 at 6:22 PM
    #47
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    and then drive around, come home and grease all over the place.....don't worry. I do it every other oil change, red grease.
  8. Feb 27, 2011 at 6:30 PM
    #48
    mackattack07
    william
    you can also slide the needle between the boot and shaft to keep from puncturing the boot
  9. Feb 27, 2011 at 11:07 PM
    #49
    subtleshift
    subtleshift [OP] Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
  10. Feb 28, 2011 at 9:38 PM
    #50
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
  11. Mar 1, 2011 at 9:31 AM
    #51
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    So where are the 8 on your 4x4? I counted six on my 4x4 too. both end ujoints on the drives shafts=4 and one each on each driveshaft flange=2.
    4+2=6
    Where are your other 2?
    Thanks,
    Flash
  12. Mar 1, 2011 at 12:00 PM
    #52
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Did you count the 2 for the double Cardan joints ? If not great , but if you don't have the serviceable cardan, I feel for you cause when it goes, its drive shaft time....:eek:
  13. Mar 1, 2011 at 1:17 PM
    #53
    Skillet
    Skillet Well-Known Member
    Caleb
    Palmdale,Ca
    99 tacoma prerunner 3.4 auto trans trd,
    Trd edition,black powdercoated wheels,king Coils front, king double bypass rear, k&n cai, jba headers,borla exhuast,optima batt,xenon hid,crystal headlights,rewired entire car to four guage wiring on big stuff alt starter etc.,alpine screen,focal honeycomb components,JL four channel amp,dynamated entire inside of truck and hoodliner,limo tint all rear windows,LEDs everywhere possible dome light, tails,fronts,04 tailights,
    His shaft may have been serviced by the way, that may be why he deosnt have as many zerks, you can rebuild a shft, I did mine ( that stupid piece of shit shaft forever burned in my memory ), it was the biggest pain servicing my cardan shaft it acually ate the needle bearings on the cardan shaft and I found new needles to replace them what a bitch!( greasing until the old shit comes out is a must or you'll be buying / rebuilding yours.) My local machine shop has all the u joints for this shaft and rebalanced mine after I rebuilt it ( made a huge diff in vibrations ) my driveshaft took 6 hours to rebuild and 300.00 bucks hence the importance of greasing, grease you're shit or you'll be doing some cardio...
  14. Mar 1, 2011 at 1:17 PM
    #54
    Flash1034
    N/W Montana
    Do you mean the cardan going in to each front wheel? I thought those were CVs?
    Flash
  15. Mar 1, 2011 at 1:37 PM
    #55
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No, the double cardan joint is the 2 joints kinda knuckled together, just past the center bearing towards the rear diff, some were servicable & (pretty sure it was from 2000 -on) previous to 2000 from what I understand it was a perma seal-type bullshit which I can't stand, meaning when it was done , so were you & the recommendation was to replace the drive shaft, I could be wrong here on all counts !! :eek::eek:;) (but I don't think so) mine has the double cardan but its servicable/greaseable with 2 zirks...
  16. Jun 6, 2011 at 5:38 PM
    #56
    southpier
    southpier Well-Known Member
    so i did the red grease in the universal zerks this weekend and the truck actually seems to run quieter. 10,500 k - 2011.
    so where else do i squirt this stuff?
  17. Jun 6, 2011 at 10:00 PM
    #57
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    this thread is gold. thanks for all the info guys (gals too?)
    Question, i noticed when i was greasing during my last oil change (first, only owned the trucko a few months) that two of the zerks didn't appear to let any grease in, and instead of pushing grease out the 'normal' way, the grease pushed out around the zerk... i'm assuming this means new zerk fitting time. Are all zerks the same? if not, does someone have the part #? would i need to plumbers tape the threads? loctite? Thanks!
  18. Jun 7, 2011 at 5:07 AM
    #58
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not neccessarily, wipe those zerks off before attaching grease tube to zerk, push straight down on it till you "feel" it seat around the zerk, now pump, you weren't on it all the way...;)
  19. Jul 2, 2011 at 7:02 PM
    #59
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    did mine today for the first time...got all 8
    took quite a bit in some joints before i saw new grease...old stuff was BLACK
    gonna make sure i do it much more often...had the truck 10 months, first time doing it myself
    MainerDave19995VZ likes this.
  20. Jul 2, 2011 at 7:29 PM
    #60
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Nice !!! good job & yeah I've seen alot of post here with guys having all these driveline noise/Ujoint failures issues (many on 2nd gens with lo miles) & it seemed to me that the mileage some said they had & the issues they were having also could only be one thing..... simple lack of maintenance/chassis lube/driveline lubing, I've got 166K on my truck, same U joints as far as I can tell. (ok, bought it with 94K on it already)
    I've put on at least 70K , no driveline issues at all, I lube mine once a month, minimum, more during winter when we do alot of runs in rain/mud etc;.....;)
