Greased my drive shaft...
Discussion in '1st Gen. Tacomas (1995-2004)' started by subtleshift, Feb 26, 2011.
  1. May 8, 2019 at 2:57 PM
    #101
    greengaint97
    greengaint97 Well-Known Member
    Al
    Colorado's Western Slope
    SOLD: 01' TRD xtra cab 3.4L five speeder
    I will have to look here in a bit when I drain and flush my coolant. Thanks for that heads-up!
    EDIT:
    Yep, there are 9 and I got all 9 - just didn't count right! Thanks @Dirty Pool for the catch
    cruiserguy likes this.
  2. May 30, 2019 at 7:10 AM
    #102
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    I was only able to find two in the double cardan joint. Where is the 3rd one ? Thanks
  3. May 30, 2019 at 7:57 PM
    #103
    greengaint97
    Al
    Two are in the same place on each side of the double cardan - if you see one from R to L or vice versa, then about a quarter turn and inside (between the two more obvious ones) the joint towards the front of the truck is the other one...it hides. You may need to block your wheels and put your truck in N to rotate the driveshaft. It's there alright - at least on mine it is.
    Cheers
    GQ7227 likes this.
  4. Mar 22, 2020 at 9:56 AM
    #104
    GQ7227
    GQ7227 mw survivor
    J A Y
