Greasing Entire Drive Shaft U-Joints (5 Zerks Total)
Discussion in 'Technical Chat' started by The Parts Whore, Oct 18, 2009.
  1. Nov 30, 2009 at 8:01 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Just to make it clear, this is a 1st generation driveshaft.
  2. Dec 1, 2009 at 11:44 AM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Not all greases are compatible -- I believe that the recommended grease is a lithium complex.
    in some cases mixing may cause a problem. To solve problem pump enough to flush grease. run for a few days -- let it mix around and re--grease.
    Aluminum complexes offer excellent water resistance -- use a EP grease. Moly is ok as long as its below 3% and its from a quality manufacturer as they will use ultrafine moly. all others are to be avoided.
    see link
    sorry link button not working
    http://www.mindconnection.com/library/handyman/greasecompat.htm
  3. Mar 3, 2010 at 11:19 AM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    wait, so is it 5 or 6 zerks?
    From the pictures, it looks like there's 6, but I only see 5 listed.
  4. Mar 3, 2010 at 11:28 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    There are only 5 zerks. Two on the front drive shaft if your 4x4, and three on the rear drive shaft.
  5. Mar 6, 2010 at 6:50 PM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    To make this job simple buy a grease gun with a hose attachment.
    5 mins and it is finished!
  6. Mar 7, 2010 at 11:41 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    can one of you upload a pic of what this grease gun hose attachment nozzle looks like? I got a new grease gun and I think I'm missing something...
    and I guess you put the nozzle in the zerks and pump? that's it right?
  7. Mar 7, 2010 at 8:27 PM
    Crom
    Nick
    San Diego, CA
    Millions
    You're probably missing the coupler. I had to buy one too.
    Estephe21 and ready6delta like this.
  8. Mar 8, 2010 at 4:30 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    AHHH!!! I knew I was missing something... is that coupler thingy!!
    does it lock right in the zerk?!?!?
  9. Mar 8, 2010 at 4:50 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Yes the coupler attaches to the zerk. The coupler is adjustable. It is designed that way to fit the variety of zerks that one would encounter.
    Here is a close up view of it all in action.
    ready6delta and Biscuits like this.
  10. Mar 20, 2010 at 4:56 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I dont know about u hippies, but everytime I tried to do something on the bottom of my truck... the zerks never faces down... it always up on top
    today I did the 3 zerks in the back... using mobil 1 grease, I pump it until the black just comes out a bit and that's it...
    the front driver shaft sure giving me hard time, it's a in bad spot, I need to jack the whole truck in order to get to it, it seems like.
    do I really need to do the front since I use it that much?
  11. Mar 22, 2010 at 8:52 AM
    Crom
    Nick
    San Diego, CA
    Millions
    linkfeeney, You can rotate the front drive shaft by hand if the 4WD actuator is not engaged. I was able to do mine because I parked the truck over a depression and then crawled under the truck and had lots of room to work with.
    If I were you I'd still lube the front regardless of how often you use.
  12. Mar 22, 2010 at 4:27 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I can rotate what?!?! I never knew that... i guess I can do it for the front too... but so hard to get my hand in there to get the coupler in and take it out...
  13. Mar 22, 2010 at 11:21 PM
    WATacoRider
    TRD Sport 4x4
    lol.
    For me, the 1 on the very front was easy to get to.
    #2 zerk was at an awkward spot for me. I wonder if there's a good reason they changed the zerk locations compared to the rear.
  14. Apr 3, 2010 at 5:53 PM
    Drogers
    Drogers Well-Known Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Leer 100XR Topper, Re-wired interior dome light, Shaved front mud flaps, Rebadged flat black, Avid offroad light/bull bar, Yellow OEM Fog Light Mod, 265/75R16 Nitto Terra Grapplers, stock 16 steelies painted flat black, K&N air filter
    How many grease fittings are there in total for a reg cab's drive shaft?
  15. Apr 3, 2010 at 6:04 PM
    #35
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    subd, nice work, buddy was talking about doing this
  16. May 1, 2010 at 10:57 AM
    #36
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    ok I finally for the chance to grease the front drive shaft...
    but I can only do the front in!!
    i can't reach my hand or shove the coupler into the zerk on the back of it...
    anyone got any ideas???
  17. May 7, 2010 at 7:09 AM
    #37
    dbarn
    dbarn Well-Known Member
    Texas
    Tacoma 4X4 V6
    The number 2 zerk is a a lot easier if you remove the protective plate. 2 12 mm bolts from the bottom. You then have much easier access.
  18. May 7, 2010 at 8:52 PM
    #38
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I have to remove the plate?! man what a pain... I wish I have a lift like the garage have... so much easier to do it!!
  19. May 11, 2010 at 2:11 PM
    #39
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    Just got under the truck to grease the zerks. I found 6. First time I have them myself. The one near the tranny was dirty dirty with grease thrown underneath the truck. The back end took about 6 pumps to fill.
    Great thread!!
    TrueNorthTaco_TNT likes this.
  20. May 16, 2010 at 5:51 PM
    #40
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    well people... I did it! I able to fit the coupler into the rear front drive shaft!!
    2 pumps that all it needs!!! Man it was a pain in the ass, I wish I had a lift!!!
