Greasing Entire Drive Shaft U-Joints (5 Zerks Total)
Discussion in 'Technical Chat' started by The Parts Whore, Oct 18, 2009.
  1. Jun 2, 2010 at 8:18 AM
    #41
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Just did mine today. I only have 5 zerks also. No double cardon joint on mine (access cab). I'm still stumped as to why there's no slip yoke zerks. I've got rubber boots covering my slip joints....but still....??
    I'm baffled by the 'thrust bushing' thing also. I called two different dealerships and they couldn't give me any information. I'm wondering if this is someting in the axle shafts? I could be barking up the wrong tree, but I'm determined to find out exactly what this is - whether its a misprint in the manual or what.
  2. Jul 19, 2010 at 9:52 AM
    #42
    TryingTacoma
    TryingTacoma Member
    Canada
    2010 AccessCab 4X2 2.7L 4cyl Auto
    Engine Hour-Meter, Fumoto Oil Change Valve, Rear RideRite Helper Air Springs and Left/Right Pressure Guages.
    Great thread.
    One thought. Many years ago a motorcycle dealer suggested that pumping grease into a Zerk until it comes out of the seal in fact opens the fitting to easy water/salt entry.
    Assuming the seal is good, and the joint was properly greased at the factory, then a half shot of grease should be enough to keep the joints full and in contact with the grease.
    I got 100,000 Km on a motorcycle wheel bearings and 190,000Km on a 1958 Chevrolet suspension with no problems and no excess grease. Especially nice not to have to periodically clean the grease from the motorcycle brake drums.
    Anyone else tried this?
    TrueNorthTaco_TNT likes this.
  3. Aug 11, 2010 at 2:54 PM
    #43
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I just greased the zerks again. The three U-joints on the rear shaft took 3 full pumps of grease, on the fourth pump, the seal became displaced so I stopped. This was 5000 miles between greasing.
    The front two u-joints are much smaller and have a different lighter grade of grease in them. The seals went instantly when I began pumping, I just kept at it and pumped until the new grease came out the seals. Cleaned it up with some paper towels. It took 30 minutes and I saved $90.00 from the stealers pocket. :)
    Biscuits likes this.
  4. Aug 14, 2010 at 6:24 AM
    #44
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    That's really nice but motorcycles don't pull 6500 lbs of trailer plus 4000lbs of truck like the Taco does, all hanging on needle bearings around two spider stubs barely 3/4" dia.
    If I'm towing like that, I'll make sure all the dirty grease is pushed out and do it frequently... so what if the shaft tunnel is coated with old grease...it just gives less area for rust to start!
    I think his point is valid for things like ball joints and tie rod joints when they had zerks: filling them till the bellows burst was not a good idea and irked me no end when they did it during service.
  5. Aug 14, 2010 at 6:37 AM
    #45
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I use Amsoil Heavy Duty #2 Grease on the whole driveshaft no problems at 120k miles on truck and helps eliminate the axle wrap clunk also for me.
  6. Oct 25, 2010 at 9:08 PM
    #46
    Selimos
    Selimos Active Member
    George
    Calgary
    05 Tacoma Indigo
    Great write ups! makes it super easy to follow
  7. Dec 27, 2010 at 2:08 PM
    #47
    T0y0ta05
    T0y0ta05 Well-Known Member
    Pennsylvania
    05 Silver Sport DC Tacoma
    Bone stock other than new floor mats.
    Nice thread...you can grab the NLGI #2 grease, gun and coupler all at Walmart.
  8. Apr 6, 2011 at 5:15 PM
    #48
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
  9. May 11, 2011 at 4:50 PM
    #49
    southpier
    southpier Well-Known Member
    is there a company which manufactures both moly & lithium greases?
    Mobil 1 is lithium, but their tech support indicates that there is no moly grease in the Mobil line.
    LPS Laboratories has ThermaPlex CS Moly #70814 & ThermaPlex Multi-purpose #70614.
    would the LPS brand be satisfactory?
    thanks
  10. Jul 4, 2011 at 8:09 AM
    #50
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    not sure why the write up only states 5/6 zerks? there are 8 on the 4x4 trucks
  11. Jul 4, 2011 at 8:17 AM
    #51
    gatlin69
    gatlin69 Retired?
    Scott
    Tampa
    4x4
    Nerf bars, bug shield,skid plate, coming soon (hopefully) DVD NAV
    great write up I was just going to ask what a "Zerk" was...lol...mechanic I am not.
  12. Jul 14, 2011 at 12:47 AM
    #52
    Eurosport
    Eurosport Well-Known Member
    around the world
    maybe double cabs it's 8, access cab there's 5
  13. Aug 17, 2011 at 10:35 AM
    #53
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    In case anyone reading this has trouble greasing the front zerks - I always did - the solution is to use a small one hand grease gun. You can easily push coupling on to the zerks. I always had a hard time getting coupling to lock on with the larger two handed gun - the grease always shot out around the zerk instead of going in it.
  14. Aug 17, 2011 at 1:27 PM
    #54
    Crom
    Nick
    San Diego, CA
    Millions
    No vantaco is wrong if he is referring to 2nd Gen. There is only 5 zerks on 4x4. There are (3) on the rear drive shaft and (2) on the front. It does not matter if its access or double cab.
  15. Sep 22, 2012 at 7:33 AM
    #55
    Revjled
    Revjled Member
    Justin
    Bentonville, AR
    '11 SR5 DC 4x4
    Predator steps, alloys
    Appreciate this thread - made the work quick and easy.
  16. Oct 26, 2012 at 10:21 PM
    #56
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Time for me to get some grease cause I doubt Toyota Care is doing it. I have to go in for 15k service (last one) and I'll ask about it.
  17. Oct 27, 2012 at 5:42 AM
    #57
    george3
    New Jersey
    I do mine at every oil change. The first time I DIY water came out of the seals not grease - that's a clue they weren't done:eek:
    whoareyou133 likes this.
  18. Feb 18, 2013 at 5:07 PM
    #58
    Ben550
    Ben550 Well-Known Member
    2012 TRD OFF ROAD
    "In case anyone reading this has trouble greasing the front zerks - I always did - the solution is to use a small one hand grease gun. You can easily push coupling on to the zerks. I always had a hard time getting coupling to lock on with the larger two handed gun - the grease always shot out around the zerk instead of going in it."
    for the life of me i can not get the attachment to lock onto the zerks on the front two... how did you do it? are you using an attachment that does not lock?
  19. Feb 18, 2013 at 7:25 PM
    #59
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What grease are y'all using?
  20. Apr 9, 2013 at 4:39 AM
    #60
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    It's not hard to do. Get a one handed grease gun w a 12 or 18" hose on it. I used M1 wheel bearing grease. I didn't grease mine until the truck had 14,000 miles on it. Don't over think it, just grease the 5 joints in 10 minutes and get on w ur life. Mine took 5-6 pumps before they were full again.
    More room if the truck is on stands. Ill just do mine when I rotate my tires every 10-15k
    Put the truck in neutral and u can spin the shafts as you please
    TrueNorthTaco_TNT and BWilley like this.
