Greasing Entire Drive Shaft U-Joints (5 Zerks Total)
Discussion in 'Technical Chat' started by The Parts Whore, Oct 18, 2009.
  1. Dec 17, 2014 at 8:09 AM
    #121
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Did mine last weekend when I changed my oil.
    I put in in "N" and applyed the parking break...that way you can rotate all shafts for easy access...(somebody asked this question here before)
    Biscuits and DrFunker like this.
  2. Dec 22, 2014 at 11:42 AM
    #122
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    So I just bought some Mobil 1 Grease, but then I went under the car and I don't see a single zerk lol
    I have a 14 prerunner Trd sport.
    So where should I use that Grease?
    Thx!
  3. Dec 23, 2014 at 7:05 AM
    #123
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Prerunner, that's why. Your u-joints are sealed. The 4WD trucks have the zerks.
    Biscuits likes this.
  4. Dec 23, 2014 at 9:05 AM
    #124
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I have a 4WD Tacoma and I don't have any zerks. I bought it used from a dealership this way. Could it be that the previous owner damaged the original driveshaft and either he or the dealership replaced it with a non-greasable shaft?
  5. Dec 23, 2014 at 9:37 AM
    #125
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It's possible they put in the Pre-runner u-joints.
  6. Dec 23, 2014 at 10:08 AM
    #126
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I just got off the phone with a Dive Line Service Shop and the manager informed me that the driveshafts without the zerk fittings are superior to the ones with them.
    Fixed. :eek:
  7. Dec 23, 2014 at 10:16 AM
    #127
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    :confused::confused:
  8. Dec 23, 2014 at 10:25 AM
    #128
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Fixed. I was typing quickly and distracted while posting
  9. Dec 23, 2014 at 10:30 AM
    #129
    Sandman614
    Tim
    '06 SR5 Off Road
    Without zerk > With zerk.. Maybe if you never go offroad.
    I have seen arguements that the ones without grease passages are stronger, but really I could imagine the shaft will die before the joint in that respect. I'd rather be able to add grease to push out water that got in them.
  10. Dec 24, 2014 at 9:42 AM
    #130
    Crom
    Nick
    San Diego, CA
    Millions
    Maybe that's true. . However it could be that the dealer improperly repaired the truck with non spec parts.
    I crawled under my truck last night and serviced the zerks with 52,160 on the clock. It seems to me that the front drive shaft zerks are always full of good grease. I do use 4WD, so the parts get used, but not nearly as much use as the rear shaft.
  11. Jan 5, 2015 at 4:43 PM
    #131
    hawkeye89
    hawkeye89 Well-Known Member
    Minneapolis
    '14 Spruce Tacoma DCSB
    Tailgate Antitheft, Locking storage bins, sliders, caltrend seat covers, seat warmers, bike racks, tonneau cover
    I'm gonna have to get down and look...when it's not -15 outside.
    I inquire about it whenever I'm at the dealer and they keep telling me they are sealed and no need. I have a 4x4 double cab. I want to make sure the dealer does what's on the schedule for the 20K service.
  12. Jan 6, 2015 at 9:34 AM
    #132
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Posted this in the Gen2 forums but thought it was more relevant here...
    I have read no less than 15 threads in five different forums the past two days trying to fully understand how to lube the propeller shaft...I'm close...
    I have a 2014 DCSB 4x4 Sport.
    Plan to lube the shaft in the next week.
    Havn't crawled under the truck yet but am assuming there is a "Slide Yoke" and " Double Cardan" joint...
    Some post list to use:
    - NLGI No.2 Lithium Base Chassis Grease is used for the universaljoint
    - NLGI No. 2 Molybdenum Disulfide Lithium Base Chassis Grease is used forthe Slide Yoke and the Double Cardan Joint.
    I understand from this thread and others we don't want moly in our u-joints...at least not high concetrations for long periods of time. Too hard for the bearing surfaces. Moly is for high pressure sliding apps (like the splines).
    Question: are most folks just using a good quality non-moly lithium based chassis greast (Mobile 1, Valvolene, Lucus RednTacky) for everything?
    Or, are you running two grease guns? I have two so getting two greases is not an issue.
    Also, old thread...does anyone have a current book for 2014 +/- listing the service method/lubes for the propeller shaft?
    Thanks!
  13. Jan 11, 2015 at 10:08 AM
    #133
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    Update on my 2014 DCSB 4x Sport.
    Crawled under the pickup yesterday.
    • Front drive shaft
      • front zerk, easy to get to. Plugged in the gun, took about 6 pumps. Seemed a little dry at 5800 miles...
      • Rear zerk - removed the heat sheild (two 12mm bolts) and greased the zerk. Same amount of pumps.
      • Used Valvoline Multi Purpose Grease/GM (great spec sheet). Red in color
    • Rear drive shaft
      • Front zerk - took about 6 pumps but it appeard to have a darker (black) grease come out of the boot...Didn't remove much so can't really say if it was dirty or really black (Moly based)...
      • Mid zerk - same as front
      • Rear zerk - same as front
    • Note
      • did not find a double cardan fitting
      • did not find a yoke zerk
      • did see the sealed boot near the rear. Have read some folks take off the clamps and service this... will look into that later.
    Bottom line after all of my reserarch?
    Get some grease (Valvoline, M1, Lucus Red n Tacky) and grease your zerks. Mine at 5800 miles seemed low.
  14. Feb 9, 2015 at 12:12 PM
    #134
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
  15. Feb 10, 2015 at 7:32 PM
    #135
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    Thankful I saw this thread, my zerks were completely dry on my 2014 Tacoma with 9,000 miles.
    tgordo49 likes this.
  16. Feb 11, 2015 at 4:00 AM
    #136
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    I asked the dealer to grease the shaft on my first oil change. But I'm certainly going to check it myself as soon as I can. And grease it myself from hereon in.
  17. Feb 11, 2015 at 9:11 AM
    #137
    Crom
    Nick
    San Diego, CA
    Millions
    Use the lithium NLGI No. 2. for all the u-joints, you only need one gun. Don't bother with NLGI No. 1 grease for the front drive shaft, it's unnecessary, even my local Toyota dealership uses NLGI No.2 for everything.
    To service the slip-yolk, follow the instructions here:
    http://www.tacomaworld.com/forum/2n...-lurch-stopping-started-axle-wrap-solved.html
    Yes.
    :eek:
  18. Feb 16, 2015 at 4:39 PM
    #138
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I greased my zerks with lubriplate white lithium today. The last 2 zerks did not work. The 2nd to last wouldn't take any grease at all. And the last one just spit it back out of the zerk. What should I do?
  19. Feb 16, 2015 at 7:01 PM
    #139
    Crom
    Nick
    San Diego, CA
    Millions
    Did you clean them with solvent before pumping? I'll use a rag with acetone and clean them up. You can also use an object like a screwdriver to depress the metal ball in the zerk, for the ones that are stuck.
    JGO, Skada and Biscuits like this.
  20. Feb 16, 2015 at 7:09 PM
    #140
    Shortman5
    Supercharged TRD
    Na, just hooked it up and pumped. All the others did fine. I'll try to clean and use the screwdriver on the second to last. But the one that takes grease and spits it out the zerk worries me a little. Are the zerks replaceable?
