Greasing TC UCAs
Discussion in 'Suspension' started by bigmooze, Sep 27, 2009.
  1. Sep 27, 2009 at 7:22 AM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Before I install my TC UCAs, I would like some guidance on the amount of grease I should be pumping into each zerk of my new TC UCAs. Would it be safe to pump it in until I hear it start seeping out, just like the U-joints on my driveshaft?
    I was planning to use the same Lithium-based grease (NLGI-2) as I used for my U-joints - anyone see any problem with that?
    T-minus three weeks until the install :D
  2. Sep 27, 2009 at 7:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Rub grease ALL OVER the bushings BEFORE you install them into the UCA. Then, give about 4 pumps of grease, drive it around, then 3 more pumps 2 days after install, drive it for 2 days, then 3 more pumps. Repete this for a week. THEN, a few pumps every 4 to 6 months should be fine. DO NOT try and pump them untill the "pop" or seep out the side, as this will cause the bushings to bulge out, and can leade to larger issues or damage to bushings.
  3. Sep 27, 2009 at 7:30 AM
    bigmooze
    Richard
    Belle River, ON
    Duly noted, thanks Chris.
  4. Sep 27, 2009 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. Sep 27, 2009 at 10:29 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Yeah make sure that you put a lot of grease all over the bushings and the washers and do not over tighten the top mount bolt. I'm still having an issue with my passenger side tc uca squeaking and creaking everytime I hit a bump, its pretty darn annoying. And I put a lot of grease during install. I'm going to uninstall, clean and re-grease a third time in hopes of getting rid of this very annoying noise. I'm going to try to record it so you guys can hear what I mean.
  6. Sep 27, 2009 at 10:39 AM
    azTRD
    azTRD Well-Known Member
    How do you know it's the UCA making the squeaking noise? Is it possible that it's something else? Just curios... because it sounds like you have them lubed up and installed correctly.
  7. Sep 27, 2009 at 10:42 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    my squeak like crazy.... very aggravating! ofcourse my rear springs squeak alot to soooo...... o well
  8. Oct 16, 2010 at 12:12 PM
    bigmooze
    Richard
    Belle River, ON
    Installed my TC UCAs yesterday and greased the bushings well. When I went to apply more grease in the zerks it took only two squirts before I heard the cracking of grease... Am I in trouble now? I stopped at that point, figuring there was enough grease inside. I'll wait a while until trying to force more grease in.
  9. Oct 16, 2010 at 12:18 PM
    Brunes
    Brunes abides.
    Rotorhead
    As long as it's not pushing out of the spaces between the washers and bushings- You should be fine. Drive it for a few days and keep your ears open.
  10. Oct 16, 2010 at 12:28 PM
    bigmooze
    Richard
    Belle River, ON
    I don't know whether it did squirt out or not, I may have had excess grease present between washers/bushings from the initial install.
    I'll monitor the grease and any sounds. Just listen for squeaking?
  11. Oct 16, 2010 at 12:29 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yeah, you will be able to tell.
    IMO I like the sound of squeaky bushings, but I hate the sound of squeaky coils and leafs
  12. Oct 16, 2010 at 12:32 PM
    bigmooze
    Richard
    Belle River, ON
    Lol ok thanks guys. Pics to follow.
  13. Oct 16, 2010 at 1:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Grease oozing between the bushings is no biggie. Give a couple pumps of grease, drive it a couple days, then give a couple more, and repete in 3 days. That should be good. You dont want to over grease them, and cause a bushing to bulge out.
  14. Oct 16, 2010 at 1:23 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    is it a good idea when regreasing them to back off the bolt so the assembly is semi loose, grease them and articulate the uca (suspension) then retighten the bolt? that might relieve some buldging issues??
  15. Oct 16, 2010 at 1:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It cant hurt. I dont think you "need" to do it that way though.
  16. Oct 17, 2010 at 8:57 AM
    bigmooze
    Richard
    Belle River, ON
    I'm not sure I understand the bulging issue. How can the bushings bulge if they are in tight and compressed by the washers?
  17. Oct 17, 2010 at 9:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Too much pressure from the grease can cause them to bulge out between the washer and UCa mount.
  18. Oct 17, 2010 at 10:41 AM
    bigmooze
    Richard
    Belle River, ON
    OK thanks. How would the problem manifest itself? I would assume that the bushings become uneven and let water etc between the bushing and UCA then?
  19. Oct 17, 2010 at 11:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The problem arises when too much grease is pumped into the bushings. many folks install the UCAs, and get happy with the grease gun. Too much pumping, can push the bushings out.
  20. Oct 17, 2010 at 11:28 AM
    bigmooze
    Richard
    Belle River, ON
    Alrighty I'll just add a little at a time. Thanks Chris.
