Greasing zerks - One or two differnt type of grease?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmf21, Jun 9, 2011.
  1. Jun 9, 2011 at 12:52 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Just got a grease gun and would like to grease the zerks on my 04 4wd. I know I need to get nlgi 2 grade grease but I'm a little confused because from my reading on here it seems that I need to purchase two different type of grease? Lithium for the u joints and moly for everything else? Is this correct or can I just use one type of grease for the whole thing. Seems like a real hassle if I have to use two different types.
  2. Jun 9, 2011 at 4:28 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Make sure you purge all the other base-type of grease from the joint. They do not get along.
  3. Jun 9, 2011 at 8:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    FWIW, i've been using lucas red 'n tacky for all driveline zerks for several years (~70K miles) no problems at all. Still all original joints.
  4. Jun 9, 2011 at 8:54 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    Bought some Royal Purple 01312 Ultra Performance Grease today. Going to try it out in a few days when the gun arrives.
  5. Dec 23, 2012 at 8:19 PM
    wildcatkit52
    wildcatkit52 New Member
    Russellville, AR
    Found your old post in a search, figured I'd ask how you feel about the royal purple after a year and a half? Doing front end work on my 1 ton Ford and thinking of using the same grease for new ball joints, rod ends, and bearings.
  6. Dec 23, 2012 at 9:43 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I trust lucas red-n-tacky.
