Greasy gunk in intake manifold valves
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Jun 15, 2015.
  1. Jun 15, 2015 at 11:31 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I was curious as to the possible reasons why my intake manifold valves would have collected greasy gunk inside them? Is it normal or is it a symptom of a bigger issue? What should I use to clean them? I suppose cleaner valves mean smoother air flow into the engine and better running.
  2. Jun 15, 2015 at 12:12 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Usually it means :"Stop using cheap ass fuel and cheap ass oil" :D
    Edit: And that is some cheap ass pictures, I can barely see inside...
    T4RFTMFW likes this.
  3. Jun 15, 2015 at 12:16 PM
    foampile
    Mid-Atlantic
    Where do you install it ?
  4. Jun 15, 2015 at 12:21 PM
    foampile
    Mid-Atlantic
    Thanks. Now, do you know what product i could use to clean the valves from the existing grime ? Can I use regular household cleaners, like Simple Green or should I use a special product ? I thought a regular household product could do as it is only air going through them.
  5. Jun 15, 2015 at 12:22 PM
    foampile
    Mid-Atlantic
    I am taking it down. What should I clean it with ?
  6. Jun 15, 2015 at 12:24 PM
    BlueT
    NorthEast
    foampile can you take better pictures, from the one you have not sure what that buildup is.
    If in fact its only oil than Rock Lobster idea will help, but if its carbon than not much.
    Is it just in intake or on valves too? If its on valves than strange because fuel should clean them spotless.
  7. Jun 15, 2015 at 12:25 PM
    foampile
    Mid-Atlantic
    I'll try to remember when I get home tonight. I took this picture for a different purpose.
  8. Jun 15, 2015 at 12:31 PM
    DirtyTaco24
    DirtyTaco24 Well-Known Member
    Greg
    Ottawa
    '12 TRD DCLB Black
    Jam some Seafoam down there, and watch the carbon melt away. take out your sparkplugs and crank the engine a few turns to get the cleaner out. repeat if necessary.
    foampile[OP] likes this.
  9. Jun 16, 2015 at 11:21 AM
    foampile
    Mid-Atlantic
    Do you have any recommendation for the actual catch can ? And what size hose should I use ?
  10. Jun 16, 2015 at 11:31 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
  11. Jun 16, 2015 at 11:31 AM
    foampile
    Mid-Atlantic
    This useful writeup suggests sortof in between the brake master cylinder and the fuse box, attached to the sheetmetal. Do you think this generic can also would do ?
  12. Jun 16, 2015 at 11:38 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I think he's talking about the plastic flapper valves. They tumble the air as it goes into the engine to simulate variable intake runner length, which helps optimize the power band. If I'm right, fuel is introduced downstream of the flapper valves (I dont think my 2.7 has these, but I had a VW GTI that had them).
