Great, how much is this going to cost me?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BRUIN8124, Oct 24, 2013.
  1. Nov 4, 2013 at 11:54 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I've never been a fan of sit and pray it goes away and then pray some more it doesn't come back, and pray some more that it doesn't hurt my truck or worse me.
    It doesn't take much effort to get a code read and know if it's something potentially catastrophic..
    Good Idea but in the mean time do some research.
    Another members experience
  2. Nov 4, 2013 at 2:49 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm confused too, those lights are triggered by seperate ECU's.
    There has been reports of engine wire harnesses damaged by rodents. Any chance you had any critters gnawing on the wireing. When that happens, all sorts of crazy stuff can happen.
  3. Nov 4, 2013 at 4:15 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    CEL comes on, it will trigger the other to come on and disable the traction control. Just does that.
  4. Nov 21, 2013 at 10:24 AM
    BRUIN8124
    BRUIN8124 [OP] Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    Well, it looks like the "pray it goes away" approach isn't going to work as I had expected... The lights are back and I have a date with the stealership. I bought my truck certified used. I think there is a 100,000 mile warrantee. I will have to check. You guys know? Maybe my luck will change after all.
  5. Nov 21, 2013 at 12:55 PM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
  6. Nov 21, 2013 at 4:11 PM
    koditten
    Kirk
    Central Michigan
    Just about all the scanners out there do a good job telling you what code is present. The problem with some is that some codes are thrown and disappear. You need a scanner with some logging ability.
    Any scanner is a good investment. With a bit of googleing, you can find out what "may" be the cause of the CEL coming on.
    These forums are also wonderful tools for finding out what is wrong with the car too.
    As for the OP, I wish I knew the code numbers that are being thrown. Any Autozone can scan your truck for free.
  7. Nov 21, 2013 at 9:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like the Cam Position Sensor or the Oil Control Valve for the Variable Valve Timing.
    If it is running smooth and with no issues it is more likely the sensor that is not sending the feedback to the ECU.
    If it was running like crap it would more likely be the Oil Control Valve sticking etc. As the VVT isn't working the engine would not perform correctly.
    The manual says:
    Retarded cam timing:
    With warm engine and engine speed of between 500 rpm and 4,000 rpm, all conditions (a), (b) and (c) met (2 trip detection logic)
    (a) Difference between target and actual intake valve timings more than 5°CA (Crankshaft Angle) for 4.5 seconds
    (b) Current intake valve timing fixed (timing changes less than 5°CA in 5 seconds)
    (c) Variations in VVT controller timing 19°CA or less of maximum delayed timing (retarded)
    Trouble Areas:
    • Valve timing
    • Oil control valve (OCV)
    • OCV filter
    • Camshaft timing gear assembly
    • ECM
  8. Nov 21, 2013 at 9:50 PM
    BRUIN8124
    Mark
    Awesome answer! Thank you so much!
    It is running and driving smooth so my guess would be the sensor is having some issues.
    Any guess how much that would/should cost me to fix or replace?
  9. Dec 7, 2013 at 5:15 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    hey BRUIN8124, my check engine light just came on two days in a row, has the same code P0012. i also got a B2799 don't know what that code is. can't find it in the repair manual, code doesn't match any of the other codes.
    what did you do, and how much do it cost?
  10. Dec 7, 2013 at 6:55 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Id start with Google or your favorite flavor of search engine.
  11. Dec 7, 2013 at 12:40 PM
    BRUIN8124
    Mark
    I ended up canceling the appointment. The truck is running and driving fine and the light went off. I couldn't really afford it with the holidays around the corner. I am not sure what that second code could be. I would check Google. After the new year I will get it all taken care of. I will let you know.
