Greensystemsgo's Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Greensystemsgo, Aug 25, 2011.
  1. Apr 6, 2013 at 7:30 AM
    #81
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    bought some black wax and plasti dip. shes gonna get cleaned here soon.
  2. Apr 9, 2013 at 9:41 PM
    #82
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Steel purchased for a better bumper mounting method, the elites getting cut up. its nice, but mounting sucks utilizing the stock locations. ive crushed the frame.
    also got some 3/16 plate with 1/2x1/2x1/8 angle for ribs to make a skid from bumper to back of tcase.
    gotta get ready to run predator, and lower/upper terminator by table mesa. crown king this weekend too.
  3. Apr 20, 2013 at 8:02 AM
    #83
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    so, cut off some more frame end, and cut that 2x3x3/16 box and end capped it/cross member, then capped that off with some plate that wraps around the side of the frame, cut up the bumper, cut off the shitty mounts, and reattached using 4" grade 8 hardware and stovers, going to attach the skid plate to these bolts which will stop it from tweaking any more, also cut off the stock core support mounts as those were toast. just 45'd some box and boom, new mounts.
    all in all it moved the bumper up about 3/4", and in about 3/4" had to weld the core support mounts a little higher, but all in all, it worked out GREAT.
    approach angles should be much better, finally.
  4. Apr 28, 2013 at 6:45 PM
    #84
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    predator trail run @ table mesa 4/27/13
    also tore two side walls and a chunk of tread off of a third. selling one chewed up all terrain haha
  5. Apr 28, 2013 at 7:23 PM
    #85
    vette6991
    vette6991 Well-Known Member
    um sliiiiiiiders
  6. Apr 28, 2013 at 7:35 PM
    #86
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    yessur, next up. they wouldnt of saved the driver door though, i had to have people push me from rolling onto driver side over the obstacle.
  7. May 9, 2013 at 6:05 PM
    #87
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    Trucks Looking good, I like that grille
  8. Oct 22, 2013 at 9:17 AM
    #88
    Robby655
    Robby655 Well-Known Member
    Robby
    Alaskuhhh
    White TuRD
    Peep the build
    :jelly: of those bumpers!
  9. Oct 23, 2013 at 1:07 PM
    #89
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    August 2013
    Got in a wreck and went to stock front lights trucks fine.
    oct 2013
    Fr rotors and pads, oem Toyota
    2x cv half shafts
    33x12.5x15 trail terrains
    Solid motor mounts
    Aux battery and goodies in the works.
  10. Oct 23, 2013 at 3:24 PM
    #90
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Someone said you died in that wreck. Oh well, I guess you were just ignoring me again.
  11. Oct 23, 2013 at 5:55 PM
    #91
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Haha nah.
    Not solid, hdounts though
  12. Oct 24, 2013 at 7:01 AM
    #92
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
  13. Oct 24, 2013 at 11:06 AM
    #93
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Reported.
  14. Nov 3, 2013 at 6:51 PM
    #94
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
  15. Jan 2, 2014 at 5:44 AM
    #95
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    new clutch master cylinder.
    and fighting the ac climate control module and cables. stuffs siezed and worn.
  16. Jan 2, 2014 at 12:27 PM
    #96
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Slave cylinder to go with it?
  17. Jan 2, 2014 at 8:40 PM
    #97
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Negative, no signs of leaking and fresh shift fork boot couple months back so its fine for now. Master was leaking, well, was wet around firewall. Not leaking so much. Been chasing spoungy clutch and loosing fluid since I bought the truck. Finally began loosing enough fluid to find problem and correct.
  18. Jan 3, 2014 at 7:36 PM
    #98
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    truck threw a iac error code until it warmed up no matter how many times i cleared it. going to order a gasket and clean the iac and see what that does.
    picked up a new climate contro lmodule tonight with cables. old cables are sticky and module has worn teeth.
    also i cleaned it and waxed/polished some of it.
    nothing else exciting.
  19. Jan 4, 2014 at 4:34 PM
    #99
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Disassembled IAC completely and cleaned built up carbon from valve. Tension spring has minimal springiness but appears OK. Also seafoamed into throttle body.
    Ran better but need to reset computer.
    Ugh.
    New climate control module is cleaned. Cables are a little rough.
  20. Jan 7, 2014 at 5:38 PM
    #100
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Ordered a 100k mile steering rack from cali. $170 bucks vs the ~550 before core of ac delco, and almost 650 reman before core from toyota.
    ill be ordering the rebuild kit, mainly guides and seals to rebuild if newer one shows wear, otherwise current one will be rebuilt eventually.
    ordered moog inner and outter tie rod ends, a denso coil, denso wires, 6x denso iridium plugs, throttle body gasket, and iac gasket.
    going to do that, a presurized flush of coolant, an injector cleaning, and perhaps a few other things too. this thing needs to get running right.
    Also in the works, swap to the 95.5-97 style front, grill and lights.
