Greensystemsgo's Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Greensystemsgo, Aug 25, 2011.
  1. Jan 8, 2014 at 5:42 AM
    #101
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Put something on those MOOG tie rods. Put some on my 88 Pickup, fuckers started rusting. Kinda pissed about that.
  2. Jan 8, 2014 at 7:27 AM
    #102
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Mmkay. I have some galv paint, I'll clean and hit with that.
  3. Jan 20, 2014 at 7:53 AM
    #103
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    New/er steering rack, inner and putter tie rods installed.
  4. Feb 17, 2014 at 6:15 PM
    #104
    trailbikerider
    trailbikerider Well-Known Member
    Kalamazoo, MI
    Man you're making my purchase look good haha. I bought my '97 with 140k on the odometer (at lest that's what the body has, no idea how many miles the engine has) for $4000. Has needed a bunch of stuff already, probably put $500 in it already. Plus it needs either both inner CV boots or axles, as well as the corner lights and some other miscellaneous crap.
  5. Feb 17, 2014 at 6:45 PM
    #105
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Way ahead of me!
  6. Mar 20, 2014 at 9:08 PM
    #106
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    iac is still finicky. however it appears to be ecu problem. new ecu ordered.
    iac has three prongs, ground open, positive, ground closed. obviously positive is constant, ecu/ecm/pcm says to be open or closed depending on circumstance. well mine says to stay open, and closed. at the same damn time. split entire wiring harness and tested and tested and tested and well, its the ecu.
    other issues, trucks in closed loop always. bumped into open loop maybe twice for a twenty mile drive from cold startup.
    hooray.
  7. Mar 20, 2014 at 9:17 PM
    #107
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    also, disliking 33" tires on 3" ifs lift.
    if i can ever catch a break, im planning on front end swap to a early taco glass headlight style. satoshi grill, and some sliders.
    hoping to get vw bug done soon though (been on backburner for years) so i can drive that. my engine troubles have rewarded me with ~13mpg.
  8. Jun 20, 2014 at 10:36 PM
    #108
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    fixed idling issue couple months ago.
    throttle body butterfly as well as body was actually worn. newer TB fixed that.
    new bfg at 31" on stock wheels with no spacers
    front eibachs at softest settings
    custom leafs in rear, little trophy truck however they are shot so modifying the all pro expos to fix the douche.
    front end parts scoped. it looks so ghetto. i have two headlights and one marker. other marker/grill/filler plates are gone.
  9. Jul 4, 2014 at 11:33 AM
    #109
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Small fender bender over a year ago. Front Elite with custom mounting held up pretty good. 4 car accident. second vehicle, truck with trailer merged and was unable to stop in time as he cut off white civic, and he rear ended blue civic. He couldnt produce proof of insurance. White civic stopped in time, but i didnt and slid right into it. damage would of been better for him if i had absorbed any of it. but, i didnt. because i was in rear i was tagged for 100% of the entire accident. Thankfully i have insurance that covered everything/everybody.
  10. Jul 4, 2014 at 4:28 PM
    #110
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
  11. Nov 4, 2014 at 10:48 PM
    #111
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    worked on the black bitch. still boring stuff.
  12. Nov 5, 2014 at 8:17 AM
    #112
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    You need to dump that Frankenstein and put your money into a different one! What's the next project?
  13. Dec 8, 2014 at 8:14 PM
    #113
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    literally nothing to report. just dailying her.
  14. Dec 9, 2014 at 9:16 AM
    #114
    Seabass
    Adam
    AZ
    '06 Sport 4x4
  15. Mar 13, 2016 at 11:23 PM
    #115
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    updated op, all of 2015 and now 16' updated. pics to come. hows everyone doing?
  16. Mar 14, 2016 at 9:07 PM
    #116
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
  17. Mar 15, 2016 at 12:29 AM
    #117
    BigFishAllDay
    BigFishAllDay And then?
    Nick
    ABQ, NM, USA
    I have too many Toyotas...
    Everything... and a bag of Cheetos.
    Put your cell phone down while driving.
    There's more rear ending in this thread than an "I'm feeling lucky" search for... well... lots of things.
  18. Mar 15, 2016 at 10:35 AM
    #118
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    :cheers:
    If only that were it.
  19. Mar 15, 2016 at 5:11 PM
    #119
    BigFishAllDay
    Nick
    ABQ, NM, USA
    Ah, I see. I stand corrected.
    Glad to see the Elite bumper held up well.
  20. Mar 22, 2017 at 11:19 AM
    #120
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    March update? Because its been a year.
    - Got a spare 5vz for the low cost of two monsters. Told was running when pulled but has no injectors or spark plugs so I guess I will be doing some inspecting.
    - Picked up a driver door, and side panel to fix trail damage
    - Traded computer work for (sliders OR camper cage work OR frame work.
    - discovered some harline cracks on pass front inner fender
    - Picked up some manual hubs/spindles, gonna order tundra brakes and do at the same time.
    - Also, 4th gear in the trans dieded. Hunting down another now.
