Grey wire mod 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EDJY, Jan 14, 2016.
  1. Aug 24, 2019 at 12:14 PM
    #81
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yep. I will add that it is probably also not a great idea to leave ABS and traction control enabled.
  2. Aug 24, 2019 at 1:26 PM
    #82
    Heyitsclint
    Heyitsclint Well-Known Member
    Clint
    Santee, CA
    2019 Cement TRD Offroad 4x4
    None yet
  3. Aug 24, 2019 at 1:38 PM
    #83
    lapoltba
    CT - 06076
    You can make the truck think it is in 4hi while actually being in 2hi. I don't have a locker don't know if it works in 4hi. If it does, then yes you can have locker in 2hi. Same goes for 2lo.
    If i remember correctly you can only use the locker in low range.
  4. Aug 24, 2019 at 10:49 PM
    #84
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    What I'm hoping to eventually see is the ability to lock the diff in 4 hi...
    Heyitsclint likes this.
  5. Aug 25, 2019 at 4:25 AM
    #85
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    If, instead of shorting the lines to ground with a hard jumper wire, you pull them "low" with a 1K ohm resistor, you won't destroy the ECU if you're wrong.
    Usual disclaimer applies.
    The bigger risk is running w/ the diff locked all the time. That's not a limited slip diff, so you're starting a death song for your diff the moment you lock it. 5K? 50K? Then you'll hear that grinding noise that signals "Maybe that wasn't a good idea."
  6. Dec 24, 2019 at 6:21 AM
    #86
    JoviTV
    JoviTV Active Member
    Northern NJ
    2016 Offroad Inferno
    Bought used Dec ‘19 with TRD pro grille, grabber ATx tires 285/75r16, small unknown lift kit. Installed TRD Grille accent lights, Anzo headlights. aluminum running boards.
    Sub’d
