grey wire mod need help asap
Discussion in '1st Gen. Tacomas (1995-2004)' started by floger70, Nov 17, 2009.
  1. Nov 17, 2009 at 2:59 AM
    floger70
    floger70 [OP] Young Taco
    Brett
    Waverley, Nova Scotia
    2000 Taco, 4cyl, reg cab shorty.
    tundra front springs 3" lift chev half ton rear springs 3 inch lift magnaflow muffler cb 33" kuhmo mud terrains pioneer deck. bilstien 5100
    ok guys i need help asap. i have removed both sides of the kick pannels searching for the 4x4 computer to do the grey wire mod. nothing to be found. i looked behind the glove box too. anything i should know or am i nutts? its a 2000 taco 4x4
  2. Nov 17, 2009 at 4:45 AM
    Auto
    Auto Well-Known Member
    Delaware
    01 TRD SR5
    None Yet Some Coming Soon
    You have to find the 4x4 box which is behind the driver side kick panel. Then you have to unplug the wiring harness from the 4x4 box. They grey wire is in the harness that connects to the 4x4 box.
  3. Nov 17, 2009 at 4:47 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    The wire to be cut is in the number 8 pin position. As auto said it will be behind the drivers side kick panel.
  4. Nov 17, 2009 at 4:48 AM
    Afwrestler1986
    Johnstown, NY
    Wait, is it a TRD or factory e-locker?
  5. Nov 17, 2009 at 5:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    Not on a regular cab
  6. Nov 17, 2009 at 5:13 AM
    floger70
    Brett
    the e-locker isn't on the reg cab? i don't believe its a TRD, ill have to check into it more but i don't think so. any easy way to tell. i know what the 4x4 box looks like and how to do the mod and everything but i just cant find the 4x4 box anywhere at all.
  7. Nov 17, 2009 at 5:47 AM
    Afwrestler1986
    Johnstown, NY
    Well, if you don't have a locker, the mod does you no good.
  8. Nov 17, 2009 at 5:47 AM
    Afwrestler1986
    Johnstown, NY
    And if you do have a locker it is most likely aftermarket and the mod will do you no good.
  9. Nov 17, 2009 at 5:51 AM
    floger70
    Brett
    no no. not saying i dont have a locker, i have no idea. i just cant find the 4x4 box under the drivers side kick panel thats all. any ideas? like i said. maybe i dont have a locker because thats what the post above said but i have no clue, any info would be great.
  10. Nov 17, 2009 at 5:55 AM
    Afwrestler1986
    Johnstown, NY
    If you don't have a locker in it, then why try the gray wire mod? The 4X4 module may be up inside you dash further instead of behind the kick panel. The other question is....does it actually have 4X4?
  11. Nov 17, 2009 at 6:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    If you don't have a REAR DIFF LOCK button, cutting that wire isn't going to do anything. If the wire is even there.
  12. Nov 17, 2009 at 6:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No E-locker from the factory in the reg cabs.
  13. Nov 17, 2009 at 6:30 AM
    floger70
    Brett
    okay this answers my question.
    it is 4x4 and it works
    i wanted to do the mod if i had the rear diff locker but i guess i dont so i cant do it. this is what i was looking for.
    thanks.
  14. Nov 17, 2009 at 6:32 AM
    Afwrestler1986
    Johnstown, NY
    Lincoln locker FTW.
