Grey wire mod ruined?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MichaelsTacoma, Oct 3, 2017.
  1. Oct 3, 2017 at 10:10 AM
    MichaelsTacoma
    MichaelsTacoma [OP] Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    IMG_4977.jpg So do to a lack of brain cells I've managed to dwindle the grey wire from the grey wire mod down to nothing. I did the mod probably 2 years ago and it had worked fine. At first I did the easy wrap it is electrical tape which never lasted. So after using the incorrect size wire to match the grey wire and also cutting it to short in the first place, my grey wire is nearly gone. Is there any way to fix this or am I out of luck at this point?
  2. Oct 3, 2017 at 12:13 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    You should be able to remove the pin from the connector and either replace with another, or with a bit of luck, get the old wire out and reuse it on new wire. The trick is to get the proper tool to move the spring catch to release it. I ordered these when rewiring connectors on my BMW power seats. https://www.amazon.com/gp/product/B0752VQR9Y/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
    Sorry, I don't have any experience with this particular connector, but most have a single tang that you push back down toward the wire from the front side (opposite where the wires go in) and then hold it there while simultaneously pulling the pin out the back of the connector. Sometimes it helps to first push the pin in, so that the tang is free to move. Good luck!
    FirstTimeFirstGen likes this.
  3. Oct 3, 2017 at 12:27 PM
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    Thanks for you help I'll order that tool and see if I can get the old connector out and put another one in. I really appreciate it I was feeling like I had no hope to fix this screw up.
  4. Oct 3, 2017 at 2:46 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Is it just me, or have you had some shorting problems?
  5. Oct 3, 2017 at 2:55 PM
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    like shorts in the wiring with things not working? Nothing so far. If your looking at the burnt wires it was from a heat shrink wrap and the flame got to close.
  6. Oct 3, 2017 at 4:37 PM
    toyrunner
    toyrunner Puddle Jumper
    Danny
    Pasadena, Ca.
    2004 4X4 Tacoma TRD Xtra Cab
    Kings in front, Bilstien Reservoir rears, Custom sway bar disconnects, 265/75 16 BFG AT's, ARB front bumper and FROR rear bumper. Bao-Feng 2 meter radio and Cobra CB
    Use a hair dryer for shrink tube. Cleaner!
  7. Oct 3, 2017 at 8:18 PM
    jbrandt
    Justin
    Ahh... I gotcha.
    Lol
    Looked like a serious short there!
  8. Oct 3, 2017 at 9:32 PM
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    Yeah I see what ya mean
