Grey wire mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003greenbean, Dec 8, 2007.
  1. Dec 15, 2012 at 1:45 PM
    #321
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
  2. Dec 15, 2012 at 1:47 PM
    #322
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
  3. Dec 15, 2012 at 2:04 PM
    #323
    CMAHON
    CMAHON Active Member
    TX
    03 excab 3" lift
    mine just keeps blinking and doesn't go solid. how long should i wait or do i need to start driving?
  4. Dec 15, 2012 at 2:10 PM
    #324
    CMAHON
    TX
    03 excab 3" lift
    ok.. forget that last post. it just blinks until i start going then it will activate.
  5. Dec 15, 2012 at 2:26 PM
    #325
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Best bet is to find a little dirt & push your diff button & make slow right/left hand turns (circles even) so the diff gears line up & mesh, should/might hear a click , light goes solid, boom, you're locked....:)
    it may take a few turns to do it...
  6. Dec 17, 2012 at 5:34 PM
    #326
    T4coma
    T4coma Active Member
    Mass
    2003 XtraCab 4x4 v6 TRD SR5
    5100/5125 shocks, grey wire mod, deck plate
    Excellent, worked prefect! Thanks for the write up
  7. Dec 26, 2012 at 5:43 AM
    #327
    tomashworth
    tomashworth New Member
    [​IMG][/url][/IMG]Thank for the info. Great Mod.
  8. Dec 26, 2012 at 6:34 AM
    #328
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if you use it about 2 dozen times it gets loose and will engage quicker
    and smoother as time goes on....my first five attempts the thing never
    wanted to go in, and when it did, it was with a LOUD kerrrang! now it is
    mostly quiet and engages right away without missing a synchro opportunity
  9. Dec 26, 2012 at 12:51 PM
    #329
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yep, more you use it the smoother the operation becomes
    love the user name BTW !!:)
  10. Jan 10, 2013 at 4:00 PM
    #330
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    Good idea for multiple driver trucks. I will be doing that. :cool:
  11. Jan 15, 2013 at 8:53 AM
    #331
    Boosted TRD
    Boosted TRD your what hurts!?!?!?
    Zeb
    So Cal
    00 TRD SR5 4x4 5-spd supercharged, Cantilever L/T.
    TRD Supercharger, URD 7th injector, 2.2" S/C pulley, light weight crank pulley, CAI, CB exhaust, Camburg Mid-Travel front, LSK Cantilever L/T rear
    Great Mod, Vary good easy instructions in this thread![​IMG]
  12. Feb 16, 2013 at 5:12 PM
    #332
    dicenrice
    dicenrice Member
    Joshua
    utah
    03 TRD DURATRAC, W/Shell
    rough country 2" lift kit, Flowmaster Super 44 muffler, grey wire mod, deckplate mod,KYB Gas Adjust 2, Arie shell w/ carpet kit, Rockford Fosgate T1 sub, RF p5002 amp, Pionner deck/ door speakers, (2) 55w pro comp lights ,(2) 6" 130w pro comp lights, light bar by "Eddie209" :)
    Hey guys i did this mod a year ago or more... Worked amazing... Now im having problems..
    Hit ths switch abs kicks off.. Yes i know its off im not slow..
    Dif light blinks and blinks no engaging no familiar click of the locker engaging..
    Any ideas advice. Previous probles please help!
  13. Feb 16, 2013 at 5:42 PM
    #333
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Serpentine!
  14. Feb 17, 2013 at 8:44 AM
    #334
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    Check the wiring ya did. See if the ground wire came off
    It may be deeper than that...might be a burnt relay, may be the solenoid is burnt at the actuator by the differential.
    Check fuses that have to do with the solenoid.
    Good luck.
  15. Mar 3, 2013 at 4:18 PM
    #335
    03tacoman
    03tacoman Well-Known Member
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    confused with this a little bit ... the mod "locks" the rear end so that both tires spin rather than one?
  16. Mar 3, 2013 at 4:32 PM
    #336
    Buy1Get1Freee
    Buy1Get1Freee HERP DERP
    PEI
    2001 Tacoma TRD
    Grey Wire Mod, Bilstein 5100s, Eibach Coils! 255/85/16 KM2. DDM HID 35W 6000K, Homemade Rear Bumper, Trail Gear Rock Sliders
    No, the mod let's you use the locker (Which locks the rear end so both wheels spin) In 2 wheel drive or 4WD Hi instead of just 4WD Low
  17. Mar 3, 2013 at 5:26 PM
    #337
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    So unless you install a switch to the grey wire your rear end will be locked in 2wd no matter what ?
  18. Mar 3, 2013 at 6:41 PM
    #338
    Buy1Get1Freee
    PEI
    2001 Tacoma TRD
    No, you can switch between locked or unlocked with the push of the RR Locker button in your truck whenever you want.
  19. Mar 3, 2013 at 6:45 PM
    #339
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    ahhh got it!
  20. Mar 10, 2013 at 3:11 PM
    #340
    dicenrice
    dicenrice Member
    Joshua
    utah
    Ok so went wheeling up above the B in bountiful ut, went to shoot aome guns, snow filled muddy road, problem with locker still exsisted. Tested it out was not working. Got home tore panel off and just re did the whole jump wire. Now it works!!!!! But the light stays flashing so any one got an idea of why???
