grey wire mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003greenbean, Dec 8, 2007.
  1. Oct 4, 2013 at 8:26 PM
    #381
    Cykososhull
    Cykososhull Better not bring your kids
    Charles
    Coeur D' Alene
    03 Tacoma SR5 TRD
    uniden cb, Grey wire, Deck plate, OME 883 coils, Dakar w/D6XL, 4X innovations sliders, tinted windows, debadged, TG low profile bumper, Piaa lights, Allied soft 8s, Bighorn 285,75,16s
    Thanks for the write up. This was so simple. Why doesn't Toyota make it standard to use the locker in 2 wheel and 4 hi?
  2. Oct 4, 2013 at 8:43 PM
    #382
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    More than likely liability issues. Also if you try to engage the locker at any speed higher than about 10-15 mph it will strip the gears out on the motor.
  3. Oct 4, 2013 at 8:47 PM
    #383
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Hmm, as far as I know the warning is to not go above 5mph when engaging the locker. At least by Toyota.
    I just always come to a complete stop when engaging.
  4. Oct 5, 2013 at 9:04 AM
    #384
    Redneck92
    Concord, NC
    Either way, I like to come to a complete stop as well. Seems to engage/disengage faster when coming to a complete stop vs. rolling.
  5. Oct 8, 2013 at 11:01 PM
    #385
    REEFDUP
    REEFDUP Well-Known Member
    Ron
    Gulf Shores,ALABAMA
    04 TACOMA 4DR 4WD V6 AUTO
    Pro Comp,Rock Stars/ BFG Rugged Trail
    I done the grey wire mod! Simple easy mod that worked the first time I tried it before I put the kick panel back on. Tried it the other day in 4H,4LO and H 2 and now my diff lock light is blinking and my ABS light will come on
  6. Oct 8, 2013 at 11:11 PM
    #386
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    This is one of the best mods you can do for free.
  7. Oct 9, 2013 at 6:15 PM
    #387
    2003greenbean
    2003greenbean [OP] Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    It's good because it's free and makes drifting dirt roads even more fun
  8. Oct 13, 2013 at 3:30 PM
    #388
    toneyc
    toneyc NOOB
    Houston Texas
    15' TRD Off-Road
    Hello all,
    First time poster here. Been reading about this for awhile. Went out and did it today. Works great!
    Thanks!
  9. Oct 25, 2013 at 2:04 PM
    #389
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Then go forth & grey wire my son (high pitched girly voice):p
  10. Nov 1, 2013 at 2:45 PM
    #390
    Buck18
    Buck18 Well-Known Member
    Buck
    Euharlee GA
    01 Tacoma DC 4wd Limited TRD
    880's on Billie 5100's, second notch, AAL and 5100's, grey wire mod
    Did this mod today. Easy as pie. 2001 DC 4wd limited. Worked like a charm. No ABS light.
  11. Nov 1, 2013 at 3:59 PM
    #391
    tacomawammer
    tacomawammer Active Member
    wammer
    canada
    02 tacoma trd
    I did this mod a couple weeks ago on a 2002 dc and since then every once in a while i smelled a slight scent of wires burning. I stuck my head down by the mod area and it seems its coming from there. After checking the splices i noticed the screw the ground is attached to was loose and i tightened it and couldnt see any obvious sign of wires melting. Could the ground have been the problem or did i mess something up. And yes i cut the grey wire and connected the right end. Any advice would be appreciated before my truck bursts into flames
  12. Nov 15, 2013 at 6:43 PM
    #392
    adrenalinejunkie
    adrenalinejunkie Well-Known Member
    seth
    Washington
    2001 tacoma SR5 TRD 4x4
    Whats the top speed to use the locker at without causing damage?
  13. Nov 15, 2013 at 6:45 PM
    #393
    PcBuilder14
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Once it's engaged, you can go as fast as you like pretty much. Just as long as you're not trying to turn sharp on terrain that doesn't have any give.
    It's the engagement process that you need to be under 5mph for. I just come to a complete stop before I engage or disengage my locker. Better safe than sorry.
  14. Nov 15, 2013 at 8:47 PM
    #394
    adrenalinejunkie
    seth
    Washington
    hey thanks a bunch! engagement seems like a no brainer but i keep thinkin there mustve been a reason toyota had a lockout on the elocker.
  15. Nov 15, 2013 at 8:49 PM
    #395
    PcBuilder14
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Just to keep you from grenading your rear diff probably. If you accidentally hit the locker button while going say 50mph, say goodbye to your rear end...
  16. Nov 17, 2013 at 10:50 AM
    #396
    adrenalinejunkie
    seth
    Washington
    Oof... Haha yeah that would be rough
  17. Nov 17, 2013 at 12:09 PM
    #397
    4WD
    4WD cRaZy oLdmAn
    Doug
    Not really sure why you'd be smelling burning insulation & as far as loose ground screw I guess you could get a little sparking at the loose connection point but dont think it'd be enough arcing to start something to burn
  18. Nov 25, 2013 at 9:36 AM
    #398
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    If they say don't engage over 5mph, though, you can still easily do that in 4lo.
  19. Nov 25, 2013 at 2:47 PM
    #399
    4WD
    4WD cRaZy oLdmAn
    Doug
    I don't think I'd ever try to engage my locker on the fly, i always push the diff button at stand stll, then slowly apply gas for forward movement till gears line up & lock seems like doing it otherwise might be asking for ring gear chipping
  20. Dec 5, 2013 at 8:41 PM
    #400
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    When the locker engages is the light still blinking? If I push the button it blinks really fast, but when I'm in 4 low and push it it blinks really slow? Dafuq???
