Grey wire mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003greenbean, Dec 8, 2007.
  1. Dec 2, 2015 at 1:44 PM
    #521
    muddog67
    muddog67 Well-Known Member
    So I did the mod Just now , cut gray wire and grounded the wire from the plug to ground . Diff lock light is on when engaging diff lock and ABS light is on .Havent tried it out on dirt or mud yet . Does it sound like I did this mod right ?
  2. Dec 3, 2015 at 4:06 AM
    #522
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I don't have ABS so I'm not 100% but, yes, it sounds like you have it right. The ABS would be pretty much useless when locked so I'm not surprised it would disable when the locker is engaged.
  3. Dec 3, 2015 at 7:39 AM
    #523
    muddog67
    Thanks John , I will try to get out on dirt or mud in the next few days to test
  4. Dec 4, 2015 at 3:55 AM
    #524
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
    I do have ABS and yes, the ABS light does come on when the locker is engaged
  5. Dec 4, 2015 at 4:31 AM
    #525
    muddog67
    Thanks Walt . I have read that you should only use your locker in mud . Have you used your locker since you did the gray wire mod in 2wd on the dirt or snow or even on the pavement when its engaged ?
  6. Dec 4, 2015 at 5:37 PM
    #526
    Kneeboarder1025
    Walt
    Broken Arrow, OK
    '03 Forester
    I have in snow, dirt, rocks. Works great. The only one i would use caution with is on ice. Having a locked rear will cause the rear to break traction easier on ice and fish tail. At least that's been my experience.
    muddog67 likes this.
  7. Dec 5, 2015 at 2:50 PM
    #527
    tacomadaddy
    tacomadaddy Active Member
    only thing i would do different is put a switch in between so that it would be selectable so that when you don't need the rear end locked up like when driving in town
  8. Jan 13, 2016 at 12:38 PM
    #528
    T4RH33L
    T4RH33L Helping to find Jimmy since 2017
    Al
    Raleigh, NC
    2013 MGM DCSB TRD OR
    5100s with Eibach coils and zombie Dakars.
    That's an awesome idea! I have a question though. Is this mod for ALL 1st gen Tacos? Also, just to make sure that I am understanding what it does exactly, this just allows the rear differential to provide better traction in any scenario minus actually being in 4WD?
  9. Jan 13, 2016 at 12:50 PM
    #529
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    A switch on the gray wire would not add any functionality. You already have a switch on the dash that enables or disables the e-locker.
    The only point of this mod is to allow the e-locker to be enabled in 2wd and 4Hi as well as the usual factory 4Lo.
    Silver02Taco likes this.
  10. Jan 13, 2016 at 12:50 PM
    #530
    cynicalrider
    cynicalrider #NFG
    Jersey
    Only if you have a locker. Also I don't get the switch suggestion? You already have a switch to turn your locker on and off. This mod doesn't negate that setup.
    All this mod does is let you lock the rear diff without needing to be in 4wd high or low. You should still lock/unlock below 5 mph per the manual. BUT you can take a 2 high locked truck as fast as you want on pavement, shouldn't harm anything really.
  11. Jan 13, 2016 at 12:52 PM
    #531
    T4RH33L
    Al
    Raleigh, NC
    The switch idea made sense to me as a good idea because I wasn't aware that this only worked if you already had the rear diff switch. I do not have said switch, so I am assuming I don't have the locker.
  12. Jan 13, 2016 at 12:54 PM
    #532
    cynicalrider
    cynicalrider #NFG
    Jersey
    No if you don't have a switch in your cab then no locker for you unfortunately. Not an easy thing to acquire a factory locker setup either, need a new axle, actuator, and harness. Cheaper and easier to install an ARB in the rear if you don't have one from the factory.
  13. Jan 25, 2016 at 5:16 PM
    #533
    w1cked
    w1cked Member
    Jorge
    2008 Tacoma TRD
    Does this work on a 2nd Gen??
  14. Jan 25, 2016 at 5:20 PM
    #534
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    No, not that I know of
  15. Jan 26, 2016 at 5:28 AM
    #535
    w1cked
    w1cked Member
    Jorge
    2008 Tacoma TRD
    Is there anyway to lock the rear in 2wd or 4hi ?
  16. Jan 26, 2016 at 6:37 AM
    #536
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I would like to know this as well. Is there also a way to lock only 3 wheels and not all 4? Will this mod work if driving upside down? Where can I purchase the key to unlock it, or is it a combination lock?
    Thanks
  17. Jan 26, 2016 at 7:26 AM
    #537
    cynicalrider
    cynicalrider #NFG
    Jersey
    :rofl: I thought this was serious at first.
  18. Jan 26, 2016 at 8:49 AM
    #538
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yes. This is what the mod is for.
    MatthewMay1 and Sicyota04 like this.
  19. Jan 26, 2016 at 12:24 PM
    #539
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    :facepalm:
    Too funny! :rofl:
  20. Feb 24, 2016 at 9:50 AM
    #540
    LukeBo4x4
    LukeBo4x4 The more people I meet, the more I like my dogs.
    luke
    Big Island,Virginia
    03 TRD ext cab
    OME 882s, wheelers 5 leaf pack w/aal, ARB front bumper, 305/70/16 nitto mud grapplers,pro comp 7069s, Grey wire mod.
    Did this today and thought to myself, why haven't I already done this. Works like a dream.
    BHill_teq, 4WD and Dcsleeper408 like this.
