Grey wire mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003greenbean, Dec 8, 2007.
  1. Mar 6, 2016 at 12:07 AM
    #541
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, still the single best/most effective/least expensive (if not free) MOD for 4x 1st gens...
    BHill_teq likes this.
  2. Apr 14, 2016 at 9:26 AM
    #542
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    One question does the rr diff lock light flash when engaged if this mod is done?
  3. Apr 14, 2016 at 9:34 AM
    #543
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
    No - It will not effect the indications on the dash (or at least it hasn't for me)
    TacoVio likes this.
  4. Apr 14, 2016 at 10:12 AM
    #544
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    The RR DIFF LOCK light goes solid when the lock is engaged. If it is flashing you need to slow down so it can engage. Also the ABS light comes on solid meaning it is disabled.
    BenCO likes this.
  5. Apr 24, 2016 at 11:20 PM
    #545
    Dcsleeper408
    Dcsleeper408 Well-Known Member
    Mark
    San Jose
    2000 Sr5 xtra cab
    Fishing pole antenna
    Thanks op! Easy mod! Well worth it.
    Could've used this last time out. Got a little sketchy throwing in 4low to get the locker on
  6. May 8, 2016 at 9:55 PM
    #546
    Goldtaco99
    Goldtaco99 Member
    99 Gold TRD Tacoma
    3 inch toytec spacers 33 12.50s on steel wheels
    Did it to my 99 5 speed 2.7 a while back and nothing changed other than when I put it in 4lo the rear locks automatically. In 2wd I can push the button and it just blinks. Can't remember if it does anything in 4hi. Any ideas?
  7. May 8, 2016 at 10:50 PM
    #547
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I didn't think there was a 4cyl TRD with elocker....
  8. May 8, 2016 at 11:29 PM
    #548
    eon_blue
    Azusa, CA
    They are rare but they were offered for one (maybe two) years when the TRD package was first introduced in the Tacoma.
  9. Jul 24, 2016 at 3:45 PM
    #549
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Can you hear the motor running when in park? Or does it only run when in drive?
  10. Jul 24, 2016 at 4:55 PM
    #550
    muddog67
    muddog67 Well-Known Member
    You can only hear the motor running when it kicks on and locks . Once its engaged you will not hear it at all
  11. Jul 24, 2016 at 9:01 PM
    #551
    gray223
    SE Missouri
    2014 Tundra Limited
    Yeah I figured it out. Thanks
  12. Aug 8, 2016 at 9:18 PM
    #552
    Bush82
    Bush82 Member
    matt
    04 tacoma dc
    I just got my first tacoma it is a 04 dc 4x4 I think it is a base model I seen in some tacomas a locker switch of some sort my truck dose not have this dose this mean I can't do the gray wire mod?
  13. Aug 8, 2016 at 9:26 PM
    #553
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    That would be correct. Ya gotta have a locker! If it doesn't have the differential locking switch on the left ya don't have the E locker.
  14. Aug 10, 2016 at 8:38 PM
    #554
    Goldtaco99
    Goldtaco99 Member
    99 Gold TRD Tacoma
    Got stuck in the sand today and tried it while waiting for someone to pull me out and it started working for the first time since I owned the truck and pulled right out of the sand
  15. Aug 14, 2016 at 8:51 AM
    #555
    indetrucks
    indetrucks Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    So to clarify, I am grounding the grey wire that goes into the 4wd CPU and NOT the wire that goes back in to the harness correct?
    Sorry, just want to be 100% before I do this.
  16. Aug 17, 2016 at 3:08 AM
    #556
    indetrucks
    Christian
    Southern CA
    Thank you sir!
  17. Nov 15, 2016 at 2:14 PM
    #557
    MainerDave19995VZ
    MainerDave19995VZ Well-Known Member
    David
    Maine
    1999 Tacoma Extra Cab SR5 TRD 5 Speed 5VZFE
    2nd generation 16" wheels with 1.25" BORA spacers
    I noticed the rear diff locker button when I bought the truck in Florida last October. I think I pushed the button in 4 low to see if I could figure out what it did during my test drive. That was the last time I pushed the button. Until today. Today I decided that the grey wire mod would rise to the top of my list and so I read this entire thread. This took some time and, as usual, I learned a ton! Earlier in the day I confirmed what I knew. I do not have ABS brakes. So, one less light to look at. Just now I went out to see if the locker even works. Went out and started the truck and pulled off the pavement and onto some spongy wet grass and woodchips. Put truck in 4 high then 4 low and drove back and forth and then hit the rear locker button while in 4 low. Blink, Blink, Blink...... Never went solid. Figured maybe I'm going to have to service it. But, I had read the entire thread so I drive back and forth with the locker light blinking all the while in 4 low. No dice. Just keeps blinking. I think that maybe this thing has never even been locked. Undeterred I kept driving back and forth in 4 low and then the light stops blinking...stays solid. I take it out of 4 wheel drive and light starts to blink but that slower blink. I put it in 2 hi and drive down the road and back. Pull onto the grass again and go to 4 lo. Hit the locker and blink blink blink...no dice. Start to drive forward and backward and then bingo! Solid light again. Third time through all this the light went solid instantly upon pressing the locker button. So, tomorrow when the sun is out I'm going to do the grey wire mod! My primary reason is that I get stuck in the least bit off snow when on a slight grade and I just need a little more traction to get moving and then I'm good. After 17 years the rear differential locker is now going to get used at least a dozen times a year. And honestly, if I ever sell the truck, I'm pretty sure that showing this to a buyer is going to make a good impression. THANK YOU to all the posters on this thread who made this whole process understandable. My advice to newbies is to read the whole thread. Then check to see that you have or don't have ABS just so you know what to expect with lights on the dashboard. Cycle your diff locker a few times so you know that it works and how long it takes and all that. Then do the mod. I'll post up my mod photos as soon as I'm done.
    TacoSupremeo and Bulldogs129 like this.
  18. Nov 16, 2016 at 6:48 AM
    #558
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    Mine is doing the exact same thing. I'll start reading the thread asap. Thanks for posting your truck symptoms.
  19. Nov 16, 2016 at 7:08 AM
    #559
    cynicalrider
    cynicalrider #NFG
    Jersey
    Good to hear you had success! These lockers definitely can go bad if unused. Keep using it and you will likely not have issues.
    MainerDave19995VZ likes this.
  20. Nov 17, 2016 at 10:05 PM
    #560
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Can i do this mod on my 2wd trd with elocker? and is it the same color wire aim looking for ? (grey)
    Any help with be a preciated
