Grey wire mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003greenbean, Dec 8, 2007.
  1. Nov 18, 2016 at 9:57 AM
    #561
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    Fall cleaning shop- haul mode
  2. Nov 18, 2016 at 1:52 PM
    #562
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Ooo i see them there something wrong with mine . cuz went i press my button nothing happens . or do i need to be stuck for the locker to activate ?
    Thanks for the reply. silver 02
  3. Nov 19, 2016 at 2:44 PM
    #563
    James Lee
    James Lee 1st gen for the win.
    Seattle,WA
    2001 Tacoma 4x4 Limited TRD
    -OME 882 coils -Jeep Jk 10mm trimpackers -Wheeler's extending rear brake line -OME Dakars+aal -4in Deckplate -nitro sport shocks all around -Star Hid projector headlights -Trail gear rock sliders -Trail Gear low profile front bumper -Pro Comp 51's 15x8 on BFG KO 32" -ARB snorkel -EBC pads and rotors -Rago Fabrication ditch lights+brackets -SpiderTraxx 1.25 wheel spacers -Snugtop Canopy
    How fast can you drive with the e locker engaged in 2wd? Can I be able to drive it on the freeway with it on?
  4. Nov 19, 2016 at 2:48 PM
    #564
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    Can and should are two different things. You CAN drive with it engaged at freeway speeds, however, you SHOULD not. The locker by design does not allow the rear wheels to spin at different speeds. When you turn even slightly the outside wheel needs to spin faster than the inside wheel. With the locker engaged it will bind if turning on a hard surface increasing tire wear dramatically.
    TACO ROCKO and James Lee[QUOTED] like this.
  5. Nov 19, 2016 at 3:03 PM
    #565
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Instead of driving back and forth and hoping it will lock (stop blinking), try (from a stop) turning your steering wheel all the way to the left (or to the right) and begin to roll forward. It should stop blinking within a foot or two!
    This mod is for 4WD Tacomas only (who only have locker available in L4) so they can have a locker in H4 and H2 (2WD). Obviously, 2WD Tacomas don't need the mod since the locker (if equipped) works in 2WD.
    The locker is for getting unstuck. If you are on a paved road, driving fast, etc. YOU ARE NOT STUCK!
    Use it when you begin to have tire spin or before crossing deep mud or climbing a steep, dirt grade where you anticipate tire spin.
    As stated, when locked, the back tires can not rotate at different speeds, as they must when turning. If they can't slip in a turn then you risk damage, or if at a high speed: losing control! Please don't give Toyota a reason to discontinue the locker because you did something stupid and killed yourself!
  6. Nov 20, 2016 at 8:12 AM
    #566
    MainerDave19995VZ
    MainerDave19995VZ Well-Known Member
    David
    Maine
    1999 Tacoma Extra Cab SR5 TRD 5 Speed 5VZFE
    2nd generation 16" wheels with 1.25" BORA spacers
    I'm going to try the wheel all the way left or right suggestion. I find that now that I've used it a few times it is locking much faster but I do need to roll forward or backward a couple feet at a minimum. I'll let you know if it seems faster with the steering wheel all the way over. Thanks for the tip!
  7. Nov 20, 2016 at 10:06 AM
    #567
    David K
    De nada! It was something I learned here on TW, and it worked every time. Mind you, I don't use the locker except for testing because my truck has the A-TRAC system which "auto-locks" both the front and back if there is tire spin on either end.
  8. Jan 13, 2017 at 6:39 AM
    #568
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    No can do, I gave up at page 3. One of the more painful reads on this website. "Will this work on a pre runner?" "Will this work if I don't have a locker?" "Can I add a switch so I can unlock the diff?"
    Tuluk and SierraMare like this.
  9. Jan 13, 2017 at 9:30 AM
    #569
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    It's a mod. to be able to use your rear locker in 4hi since you can only use your rear locker in 4lo. If you don't have a locker you can't do the grey wire mod. Since it's meant to do what I described above. If you have a prerunner, you don't have 4 wheel drive so you don't need to do it either. Cause prerunner's already have a button to push to use your rear locker and you don't have to worry about 4hi or low.
    36tacundra and David K like this.
  10. Jan 13, 2017 at 12:44 PM
    #570
    retroboy1989
    99 2.7L 5spd 4x4
    I think you missed my point..... I was not asking those questions. I was quoting them from what I read in the first 3 pages of this thread. I gave up on reading this thread because of questions like that.
  11. Jan 17, 2017 at 5:02 PM
    #571
    obs ham
    obs ham Well-Known Member
    99 tacoma trd blower
    Dont let that magic smoke out of the wire
  12. Jan 19, 2017 at 10:43 PM
    #572
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Okay random question that may be answered in the thread (sorry I haven't read it)
    I did the grey wire mod the day after I bought my truck so this doesn't apply to me, but I thinking the other day and curiousity made me wonder the following..
    So we know that if you have ABS, any time the diff is locked it defeats the ABS, my question is, if you haven't done the grey wire mod, but hit the button to lock it while in 2wd or 4hi (so the light just flashes and of course won't lock) will this still defeat the ABS while the button is pushed in? Or does it only shut down ABS once the diff physically locks?
    Random question I know, but if that worked that seems like a simple and temporary ABS defeat for someone who hasn't done the grey wire mod.
    Or maybe I've just had to many :cheers:
  13. Jan 30, 2017 at 1:08 PM
    #573
    back_on_two
    back_on_two New Member
    2004 Black Tacoma Double Cab 4wd TRD
    3" Lift, Wheels/Tires, All Pro Front Tube Bumper w/ Winch, Gray Wire Mod
    I just did this on my 2004 and, as everyone already said, super easy!
    I didn't read through every page, but one thing I'll note is that my connector did not have 5 pins on top and 5 on bottom, but 4 on top with a space in the middle and 6 on the bottom.
    1 2 _ _ 3 4
    10 9 8 7 6 5
    It was still pin 8 and a gray wire, but just a different connector than the one illustrated on page 1 of this thread.
    sinks88 likes this.
  14. Nov 17, 2017 at 8:26 AM
    #574
    Jacob032
    Jacob032 Well-Known Member
    Jacob
    Alright, I finally got around to doing the "Grey Wire Mod" on my 2002 3.4l TRD. When I first spliced the new ground to the truck I used the kick panel screw, only to find that the mod did not wot as to my diff lock light still flashing and the e-locker not engaging. I relocated the ground to the bolt just above it and it was still flashing. I drove the truck around the yard and it finally engaged and now it engages every time after that. I don't know if it wasn't making a good connection or the motor was a little cold/seized. Any input?
    Bulldogs129 likes this.
  15. Nov 17, 2017 at 11:24 AM
    #575
    MainerDave19995VZ
    David
    Maine
    I'm still planning to do the mod. Don't know why I haven't yet! Anyway, it took a bit to get my locker working but after using it a couple of times it was way faster. I posted about it in this thread somewhere. Thanks for reminding me to do this before winter!
  16. Nov 22, 2017 at 9:46 AM
    #576
    36tacundra
    36tacundra Well-Known Member
    The diff actuator can become stuck from not using. Use it once a month for keeping it working correct. It not locking right away had nothing to do with your ground.
    Jacob032[QUOTED] and Bulldogs129 like this.
  17. Mar 18, 2019 at 5:52 PM
    #577
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Not reading this whole post. Has the light always on been fixed? Easy way around it?
  18. Mar 18, 2019 at 6:00 PM
    #578
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    What light always on?
    I did the grey wire mod on my ‘03 4x4 and had no lights stay on.
  19. Mar 18, 2019 at 6:49 PM
    #579
    johntoyota
    Down yonder in TN
    16 truck
    Wondered about the locker light being on. On the first page, that was the case. I figured someone has since corrected.
  20. Mar 18, 2019 at 7:37 PM
    #580
    johntoyota
    Down yonder in TN
    16 truck
    This one. Maybe I misread and it was actually was supposed to be engaged and my brain assumed otherwise.
    95 taco[QUOTED] likes this.
