Grey wire mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003greenbean, Dec 8, 2007.
  1. Mar 10, 2009 at 5:08 AM
    #61
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    When you do the Grey Wire mod the 5Mph is still in effect, It wont lock until you slow down... :) so your good!
  2. Apr 15, 2009 at 7:29 PM
    #62
    kyle32963
    kyle32963 Active Member
    Kyle
    lenox
    03 SR5
    Head lights-hids rims-american raceing neon-red inside and out side of truck
    cant you just hit the rr dif lock and that will work in 2wd and 4 hi?
  3. Apr 15, 2009 at 7:30 PM
    #63
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    only if you do the gray wire mod
    otherwise it will only lock in 4lo
  4. Apr 16, 2009 at 6:30 AM
    #64
    PrezidentRedz
    Redz
    Owings, MD
    x2:d
  5. Sep 10, 2009 at 12:30 PM
    #65
    donnyt99
    donnyt99 Member
    Donny T
    Louisiana
    08 Tacoma Tss
    Factory 20's
    Why not install a switch on this wire and have the option to turn it off??
  6. Sep 10, 2009 at 12:56 PM
    #66
    PrezidentRedz
    Redz
    Owings, MD
    ? huh? the purpose of the gray wire mod is so you can use the locker when ever you want. 2wd or 4wd.
  7. Sep 10, 2009 at 1:02 PM
    #67
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    :rofl:
    Hit a 5 month old thread and then asked a question like that? Only a noob.
    BTW, welcome to the Forum.
    I know I'm a jerk and can live with it. Can you?
    Jimmyrace likes this.
  8. Sep 10, 2009 at 2:10 PM
    #68
    donnyt99
    donnyt99 Member
    Donny T
    Louisiana
    08 Tacoma Tss
    Factory 20's
    what i meant was when you ground the wire, it locks the diff, correct?
    Why not put a switch between the wire and ground so it's not locked (grounded) all the time?
  9. Sep 10, 2009 at 2:11 PM
    #69
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it isnt locked all the time with the grey wire mod.......it lets you lock the diff in 2 hi and 4 hi as well as 2 lo. no switch needed.
  10. Sep 10, 2009 at 2:12 PM
    #70
    drew02a
    San Antonio, TX
    ^^ Faster than I
    I realize what you meant. The Grey wire mod doesn't make the locker engage, it simple makes it so you don't have to be in 4-LO to engage it.
  11. Sep 10, 2009 at 2:22 PM
    #71
    donnyt99
    donnyt99 Member
    Donny T
    Louisiana
    08 Tacoma Tss
    Factory 20's
    oic now, it's kinda an "on demand" locker......passive......this just gives permissive to lock full-time "When needed"- I'm mucho familiar with four wheel drive systems, just missed a note here or there on this one.......... sorry guys, thanx for the patience.
  12. Sep 27, 2009 at 10:52 PM
    #72
    1998tacoma4x4
    1998tacoma4x4 Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    Anyone know what kind of wire i should buy to do the gray wire mod. where do i buy that wire?
  13. Sep 28, 2009 at 6:22 AM
    #73
    PrezidentRedz
    Redz
    Owings, MD
    you should'nt need any wire. if you do I would say any small gauge wire.
  14. Oct 18, 2009 at 7:31 PM
    #74
    bail22
    bail22 New Member
    Bailey
    Kansas City
    01 Afghan War Vehicle (AWV)
    Airraid cold air intake, Throttle body spacer, Gibson Cat back exhaust, Custom 5.1 channel surround with 7" widescreen monitor
    So how does the locker work & is it engaged full time? Can you deactivate it? Would a simple contact closure switch enable you to be able to turn on & off at the flip of a switch?
    Thanks
  15. Oct 19, 2009 at 5:14 AM
    #75
    PrezidentRedz
    Redz
    Owings, MD
    Does your truck have the TRD Elocker>?
    If so you already have a switch. all this MOD does is: Allows you to use the Locker in 2wd, 4wd, and 4Low. If the truck is stock and no MOD is done you can only use the Locker in 4low.
  16. Oct 20, 2009 at 4:45 PM
    #76
    bail22
    bail22 New Member
    Bailey
    Kansas City
    Thanks for that ?; I was catching the switch in some other threads & wasn't clear on the lockers activation. To be clear, the only switches I have to enable anything is O/D & ECT. Am I overseeing anything?
    Thanks,
    Bailey
  17. Nov 8, 2009 at 5:20 PM
    #77
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    completed the grey wire mod this weekend on my new truck, took a whole 10 minutes. tired it out and cha-ching money. now i gotta try it out on the dirt:)
  18. Dec 3, 2009 at 5:46 AM
    #78
    Dabates
    Dabates Well-Known Member
    Guelph, Ontario
    2001 TRD
    Can someone explain when and why I'd need to use my e-locker? I'm new to 4wd and haven't had my truck off road much so have never needed to investigate the consequences of pushing the button, although I have just learned that it flashes because I'm going faster than 5mph...
    Tell me what this e-locker magic is you all speak of...
  19. Dec 3, 2009 at 6:06 AM
    #79
    Rosco75
    Rosco75 Well-Known Member
    Clavet Sk
    2001 Tacoma SR5 TRD
    3 inch skyjacker lift, k&n FIPK, 33inch procomp mud terrain tires
    Hey, the locker makes the diff act like you have one solid axle with equal ammounts of torque to each side. Very nice if you have gotten into a spot where you have one of your rear wheels totally up in the air. Is also nice when you get stuck. The truck behaves a little differently when it is engaged, it will want to push straight ahead of the rear wheels so be aware!
  20. Dec 23, 2009 at 9:05 PM
    #80
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    ok my tacoma is the 2004 with the electric 4x4 switch but you still have to shift into hi or lo manually you know what im talkin about?
    does that matter or is it still the same?
