Grey wire mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003greenbean, Dec 8, 2007.
  1. Feb 13, 2010 at 4:50 PM
    #81
    ssjostrom1980
    ssjostrom1980 Taco Love
    Phoenix
    1998 SR5 4x4 v-6 5 speed
    I have put a K&N Air intake, 1500 series bilstein shocks set at 2.5, with a procomp add a leaf to the rear springs giving 1.5 inch lift to the rear. Kenwood Excelon Deck with USB Port 4.0 V Pre Outs! Infinty Ref 4 channel amp for mids and highs Infinity Kappa Perfect component 6.5 in the front and kicker 6.5 two way in the rear. Alpine mono amp for 2 kicker 10 inch competition Subs in a custom Tacoma box. Gold Plated battery Terminals. BFG All Terrain 31's.
    What is the benefit of being able to use the locker in high gears? Is it necessary and for what applications? Mud, snow etc..?
  2. Feb 13, 2010 at 7:40 PM
    #82
    Worm
    Worm Well-Known Member
    Scott
    Southern Maryland
    Hmm I can only think of every application lol. Whats better than gettin out of something in 2wd when others would have to hit the switch. ;)
  3. Feb 15, 2010 at 12:00 PM
    #83
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    going out to do this mod today. very excited:D.. but im tired of all up talk. theres gotta be some grey wire horror stories out there and i wanna hear 'em. im not talking about bad workmanship, im talking about has anyone blown the diff after using this mod a bunch? going too fast? ect. ect? gonna do it anyway but i wanna know what might be around the corner. thanks boys. ooh does anyone know what speeds are safe to use the e-lock in 4hi and 2wd?
  4. Feb 15, 2010 at 3:16 PM
    #84
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    why would you want/need to run it to a separate switch?? with the grey wire mod done the way you see it here......you can activate the locker in 2hi, 4 hi, or 4 lo.....anytime.
  5. Feb 15, 2010 at 3:43 PM
    #85
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no...not at all. when you hit the locker switch,as normal, it will come on and go off with the diff lock switch.
  6. Feb 15, 2010 at 6:21 PM
    #86
    n315on
    n315on Well-Known Member
    MA
    02 4x4 SR5
    3'' toytec lift springs wrapped around 5100's. Deck plate mod. TRD seat belt pads. JL audio amps /subs and Alpine speakers. Diff breather mod. Working on a custom rear bumper
    Oh. Ok I wasn't fully understanding that before. Thank you for clearing that up, and sorry for any confusion I have cause.
  7. Feb 15, 2010 at 7:05 PM
    #87
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no worries man.:)
  8. Feb 17, 2010 at 10:26 AM
    #88
    2003 TRD Man
    2003 TRD Man Well-Known Member
    Edison N.J.
    03 TRD automatic
    What does this do?
    I really do not know! THANKS
  9. Feb 17, 2010 at 10:07 PM
    #89
    Silvatacoma
    Silvatacoma Well-Known Member
    Hawaii
    I'll probably get flamed for saying this but here goes... I think hooking up a switch to the grey wire makes sense! You can flip the switch, ground out the grey wire then hit the locker switch to engage the locker in 2 or 4 high. When you're done flip the switch back and the grey wire is back to how it came from the factory. Seems like the safer way to go since nobody knows for sure if there's any ill affects to having the grey wire grounded all the time. I'm probably just being overcautious....
  10. Feb 17, 2010 at 10:10 PM
    #90
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    ive had mine done for some time with zero ill effects
    ive never read anything negative about it when done properly
    no sense in adding MORE wiring and switches when you dont have to...just makes it more complicated
    ground the wire...use locker sparingly as needed...still engage at very slow speeds...learn how it acts before acting like a jackass...
    and youre good to go :thumbsup:
  11. Feb 18, 2010 at 9:49 AM
    #91
    pdxwhiteout
    coty
    pdx
    monster tacoma
    thank you tigerfan! i know to engage at slow speeds but how fast is safe to use it. not talking crazy but is 20mph to much? excited to try!
  12. Feb 18, 2010 at 10:17 AM
    #92
    Fuzzyman81
    Fuzzyman81 The New Guy
    Jax, FL
    04 PreRunner TRD
    Please don't flame, but from my reading this is pretty much just a mod to do on 4x4s correct? Or is this for any PreRunner with the locker?
  13. Feb 18, 2010 at 2:20 PM
    #93
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its just for trd 4x4's with the locker.:)
  14. Feb 18, 2010 at 5:29 PM
    #94
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    na man its just a waste. the mod was created from studying the wiring diags.. It wouldn't work if it had Ill effects.
    Jimmyrace likes this.
  15. Feb 24, 2010 at 6:50 PM
    #95
    bivey
    bivey Well-Known Member
    Got it done and LOVE IT!
  16. Mar 13, 2010 at 11:27 AM
    #96
    jvandelft
    jvandelft Member
    Victoria, British Columbia, Canada
    Tacoma TRD
    K&N CAI, TBS, Custom Cat-back Exhaust(Comes out before Rear Tire), 3" Lift (TC UCA), 33" Hancooks, Grey wire mod, Rear Diff breather relocation.
    just did this mod to my truck. works fine. my only concern is going around corners on dry pavement. obviously the outer tire will spin faster than the inner(depending if you turn left or right) so my tire is skipping/skidding on the ground when i turn corners. i wouldn't reccommend using this on the road in dry weather. not really needed and will just wear the diff down as it is not a limited slip dif. Probably why toyota only wanted people to use it in 4Lo
  17. Mar 13, 2010 at 7:46 PM
    #97
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Prerunners have it.
  18. Mar 16, 2010 at 6:41 AM
    #98
    jvandelft
    jvandelft Member
    Tacoma TRD
    i used this out of another post with sub quotes. lol.
    he might be talking about new tacomas but the same still applies to old ones
    if you like a working rear dif for 4x4ing don't use this modification on the road for regular use. Its not limited slip and will wear on your tires and everything else connected to the diff when its locked. There are 2 kinds of locking rear difs you can have; A limited slip(for use on all surfaces) and just a straight locked diff(real bad on the road)
  19. Mar 18, 2010 at 3:17 PM
    #99
    easttexasboy
    easttexasboy Active Member
    texas
    02 sr5
    y does my 02 not have the abs or diff lock lights? also i dontknow how to turn my fogs on. i just bought this truck so i still dont know alot bout it.
  20. Mar 18, 2010 at 3:19 PM
    #100
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    do you have a diff lock button on the left side of the dash? If not, than like me, you have a sr5 model and do not have a diff lock.
