Grillcraft Mod Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nick54, Nov 1, 2010.
  1. Nov 1, 2010 at 6:00 PM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I'm in on the GC group buy and was wondering if you installed a GC mesh grill WO/Satoshi, did you remove the existing grill bars or leave them in, if you left them in did you remove the emblem? Links or pictures would be great. Thanks
    Nick
  2. Nov 1, 2010 at 6:21 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Most everyone cuts them out. I think I've only seen one picture of the install with the bars still in tact...looked pretty bad.
  3. Nov 1, 2010 at 6:23 PM
    eskamo23
    eskamo23 Well-Known Member
    Pasadena, CA
    trd sport
    TRD cai with (AFE dry flow filter), de-flapped, tint, weathertech floor liners,coverking neoprene seat covers, rear TSB, Billy 5100's set at 1.75'', Pro Comp 7005's 17x8 BS4.5, any time fogs, tailgate theft mod, led lights in the int., slim cubby HID headlights and fogs, TRD skid plate, bed mat
    chop it out
  4. Nov 1, 2010 at 6:41 PM
    Vidman
    Vidman Protected by Glock
    Rick
    central Mass
    black TRD sport AC
    Not Enough
    Cut it out.. I needed a few cold ones before i could start hacking
  5. Nov 1, 2010 at 6:57 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Cut the upper and lower grill out completely. Other wise it just looks "half arse" if you know what I mean. Also install both upper and lower.....don't half arse it with just the upper. Do it right install both. The grillcraft offers much more protection to your cooling system than stock.
    Borrow a sawsall from a friend and buy a new blade. Very carefully begin cutting. Be extra careful not to cut any hoses.....wires etc. I cannot bold, underline extra careful enough. Then cut the lower, you will see its just not that hard. Just pay attention to the blade location all the times.
    Have a buddy help you and have beers after the cutting and install.
    It took me 1.20 hrs by myself. Turned out perfect. Easy........
    GL,
    Taco4x4nc
  6. Nov 1, 2010 at 7:00 PM
    TexasTacoma37
    ^ be careful not to cut any hoses? Did you leave the grille on the truck while cutting?
    Either that or you have way too many hoses on your work bench.
  7. Nov 1, 2010 at 7:40 PM
    Nick54
    Nick
    Mentor Ohio
    Thanks for the advise guys, I did buy both upper and lower. I'll probably remove the stock grill before any cutting. Is anyone repairing the cut locations where the horizontal bars attached to the sides or just leaving them as is? Is there an actual mod write up out here for the CG? I'll search to see what I can find, but if you know of the link, please advise. Is a sawsall the best tool for the job?
  8. Nov 1, 2010 at 8:02 PM
    ChaseUA
    ChaseUA Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
  9. Nov 1, 2010 at 8:21 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    haha seriously did you leave the grill on? takes 30 seconds to take it off...
  10. Nov 1, 2010 at 11:58 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Removed it. Easy to just use a saws-all. Smooth whats left a bit with a grinder.. it was pretty fun.
  11. Nov 2, 2010 at 6:26 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you don't have access to a Sawzall, you can go get a "close quarters" hacksaw. It's basically a handle that holds a hacksaw blade. Works well as the plastic is pretty soft and by not using power, less chance of losing control or cutting too much. Then just finish up with a file and/or sandpaper to smooth out the cuts.
    BTW, I did not remove the lower stock grill, just the upper.
  12. Nov 24, 2010 at 5:40 PM
    MMazz365
    MMazz365 Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
    do you have to do that figerglass shit where you cut out the bars?
  13. Nov 24, 2010 at 5:53 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Not necessary. Only if youre anal and dont want to potentially see the cut plastic behind the mesh.
    Personally, I filled those areas.
  14. Nov 24, 2010 at 7:20 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    Cut the bar out. I did it with a hack saw blade (no handle). With just the blade, it will curve to fit your needs.
  15. Nov 24, 2010 at 7:29 PM
    timmo
    timmo Well-Known Member
    Tim
    OKC
    2010 doble cab 4wd sr5-silver
    amen on the protection. haven't done it yet but i looked through my stock "grill" the other day and saw some bent radiator vanes on my 3 month old truck. that's ridiculous. my very next investment is a grillcraft mod. that way i also get to install a custom emblem from "metalmiller" too!
  16. Nov 24, 2010 at 7:29 PM
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 3 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf 2" block lift 1.5" wheel spacers Freedom Off-Road upper control arms .5" coil spacers ATOTO A6 Android double-din head unit
    Is that a grillcraft kit? That is sweet!
  17. Nov 24, 2010 at 7:36 PM
    toytacoma22
    toytacoma22 Well-Known Member
    COS
    3" Icon Lift, TC UCA, OME Dakars, Allpro front and rear bumpers.
    I used a hack saw blade no handle to do mine also, worked great.
  18. Nov 24, 2010 at 7:37 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    remove the bars **EDIT** i used a hacksaw blade to help form to the curves of the grille
  19. Nov 24, 2010 at 8:50 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Grillcraft. Top & bottom.
  20. Nov 24, 2010 at 8:56 PM
    mountainprimat2
    mountainprimat2 Well-Known Member
    Stefan
    Proctorsville, VT
    09 DC TRD Off-Road 6spd man
    Eibach Pro 2.5 CoilOvers(Front), Icon RXT 2.5 (Rears), Toytec Bumps, ICON RXT Multi-Rate Leaf Spring, Icon UCAs, Toytec Carrier Bearing drop, Toytec Front Diff drop, 33inch BFG KO2s on 17'' American Racing Wheels, TRD Cat-Back Exhaust, TRD CAI, Grillcraft Grilles(U/L), MOT's Badge Grille Mod (Red), Black Bed Lined Rear Bumper, Bushwacker Pocket Style Fender Flares, OEM Roof Rack, Husky Floor Liners, TRD 6spd Shifter Knob, Cobra CB w/ Firestick II, Interior LED Map(RED)/Dome(WHITE) Lights, LED Licence Plate Lights, LED Amber Fogs, Plasti Dip Badges, Trailer Harness Relocate, Thule Tail Gate Pad + Bed Rack, LEER Bed Cap
    Definitely a two person job with the little clips.....cut out the bars on the upper grill for sure because otherwise it really wont fit flush. Supper ill looking once its done. I hated hacking into it with a Dremel but came out awesome
