Grinding noise after lift
Discussion in 'Suspension' started by 90YotaPU, Nov 12, 2011.
  1. Dec 7, 2011 at 6:19 PM
    #41
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    No more grinding! I flipped the driveshaft and it worked. Right up to come.
  2. Dec 7, 2011 at 8:31 PM
    #42
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Cool now come over and flip mine!
  3. Dec 7, 2011 at 8:37 PM
    #43
    jandrews
    '09 FourDubDee TRD OR
    Shit, I wouldn't even pay that much attention.
    No real need to mark - the flanges are only going to line up in the correctly phased orientation unless you disassemble the slip-yoke.
    And if you manage to damage a u-joint while removing the driveshaft by hand, I would take the whole fucking shaft back to Toyota, tell them they could keep it, and go have a custom one made.
    So, simpler instructions:
    1) Unbolt driveshaft.
    2) Flip it around.
    3) Bolt back up. Torque spec: rather tight.
  4. Dec 7, 2011 at 9:26 PM
    #44
    chad68
    Chad
    Hmm looking at the pick after the flip now I'm wondering how that will hold up over time. The fat heavy end of the driveshaft now has gravity on it's side, with it's weight pushing down on the smaller end, that's now at the diff..
  5. Dec 8, 2011 at 5:22 AM
    #45
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I think the only problem would be rubber boot is now closer to the ground and more prone to damage. That things is so light I can't imagine any part of it holding up well to a good hit though so it may not matter. If mine does screw up I will definitely have one made because Toyota definitely doesn't have an answer. I will have the small write up done when I get to work. Even though it's fairly easy might help some folks to try it.
  6. Dec 8, 2011 at 5:36 AM
    #46
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    It's funny I stumbled upon this thread because my DCLB has the same exact noise the OP is describing, at the same speed! I'm going to have the dealer look into it before I spend money on a one piece shaft. I may also load up the back first and drive around with a few hundred pounds in the bed to see if the noise goes away when the angle is lower.
  7. Dec 8, 2011 at 6:39 AM
    #47
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
  8. Dec 8, 2011 at 6:40 AM
    #48
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    That is weird. I haven't looked into it happening on anything but the regular cabs. Let us know what happens.
  9. Dec 8, 2011 at 10:01 AM
    #49
    NC15TRD
    Nick
    PA
    I noticed it as soon as I had the TSB springs put in. I was too pissed at the service department to go back that day and it has been a bit over a year that I have dealt with it. I'm going to another stealership to see what they will do about it
  10. Dec 8, 2011 at 12:58 PM
    #50
    Sunner
    Sunner Well-Known Member
    Not that I have this issue or will since i dont have a reg cab, but I want to ask you if you can get ahold of a Go Pro or some sort of recording devise and mount it under your truck and record your shaft in action to see if you actually did fix the problem or if you just moved the noise to a place you cant hear it anymore, the camera should let you know. Just curious.
  11. Dec 8, 2011 at 1:04 PM
    #51
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I would but I don't have access to anything I could film it with. I doubt that I just moved the noise though. One reason I say that is because not only could you hear it but you could feel it through the pedals. If I can find something to film with I will defiantely do that though.
  12. Dec 8, 2011 at 1:07 PM
    #52
    Sunner
    You probably did solve it then, the only reason I asked was because one of the previous posters said that flipping the shaft just moves the noise to somewhere else. Good job though.
  13. Dec 8, 2011 at 1:14 PM
    #53
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    It could be a combination of badly greased u-joints and the slip yoke. I dunno I'm just glad it's gone!!
  14. Jan 3, 2012 at 5:06 AM
    #54
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    did you find out whats causing the noise?
    i have this problem, but it happens when i full lock right. like a grinding/creaking noise. (stock rear, 1.75 up front)
    i just got my alignment yesterday hoping it would solve it..but its still making noise. but now that i look at it, it still looks like i have slight positive camber.
    probably going to take it in to another shop some other time.
    anyway, everything looks good to go..all in place, bolts tight:confused:
    i dont know what else to do help!
  15. Jan 3, 2012 at 7:38 AM
    #55
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    First thing to look for is tire rubbing.
    If there's less than half an inch clearance when you check while turned both ways on both sides at just a little less than full lock, you might be rubbing while rolling.
  16. Jan 3, 2012 at 9:56 PM
    #56
    671taco
    Guam
    twenty-ten rc
    ill check......still got 245/75s
    but sounds more of a metal creaking noise
  17. Jan 4, 2012 at 8:23 AM
    #57
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    OK, the upper control arms have rubber bushings, and they want to be bolted up at the factory ride height, which you've changed by installing the lift.
    So try this:
    1. Locate the upper control arm frame mount bolt. It's a Loooong 8" or so bolt that attaches the upper control arm to the frame. There may be a little bit of plastic flashing in the wheelwell that you have to move to find it.
    2. Loosen it.
    3. Re-tighten it to 85 ft-lbs.
    Do all this while your truck is sitting on its own weight on its tires.
    That'll relieve the twisting pressure on the rubber bushing, so that it's tight at it's new "natural" position.
  18. Jan 4, 2012 at 5:00 PM
    #58
    671taco
    Guam
    twenty-ten rc
    ya that makes sense, ill give it a shot.
  19. Jan 4, 2012 at 5:25 PM
    #59
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Also check for sway bar interfering with springs, but I noticed that more on potholes and speedbumps than turns.
