Grinding noise?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 45acp, Jul 7, 2011.
  1. Jul 7, 2011 at 9:27 PM
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    There's a constant light grinding/nails-on-a-chalkboard sound while I'm driving. Not sure where it's coming from since it only happens while the truck is in motion.
    I may or may not have driven through a lot of mud a few days ago, but I washed it really well and the noise has not ceased. So I'm not sure where it's coming from and I thought I'd get some opinions before I go tearing the brakes apart...
  2. Jul 7, 2011 at 9:31 PM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    maybe its from driving thru rivers :eek:[​IMG]
  3. Jul 7, 2011 at 9:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Jack up one corner at a time and spin the wheel. That'll narrow it down.
  4. Jul 7, 2011 at 9:43 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Heat shield scraping your drive shaft.
  5. Jul 9, 2011 at 8:59 AM
    Youngota
    Youngota Member
    Brendan
    Colorado Springs
    2001 4wd TRD V6
    6 inch lift Fabtech front and rear bumper from allprooffroad.com rock sliders AFE intake
    hey i had a problem just like that. it was rotational and loud when you first take off. It started about six months after i got my lift. At first i thought it was my carrier bearing but then took it to the local drive train shop. 110 bucks later everything was good. They extended the drive shaft 3 inches and cleaned out the U joints and something about grinding down something with the joints to make it smoother. also dont go to 4wheelparts shops to get work done on your truck at least the one in Colorado Springs. They charge way to much
  6. Jul 9, 2011 at 9:17 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    How much did you lift your truck and how did they extend the drive shaft 3 inches?
  7. Jul 9, 2011 at 5:15 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thanks for the help guys. The above technique found the problem. It is most definitely the front passenger brake caliper area.
  8. Jul 9, 2011 at 5:22 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    I had the same problem in the passenger brake caliper area, not sure what it was but it only happened at highway speeds from what I can remember.
  9. Jul 9, 2011 at 5:45 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    The caliper / front brakes and rotors are the easiest thing in the world to change.
  10. Jul 9, 2011 at 6:59 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Well I just finished cleaning the dirt out of the brakes and sprayed the shit out of them with some brake cleaner but it's still doing the same thing.:confused: Forgot to mention that the noise is louder when I'm braking.
    Call me stupid, but how much is supposed to be left of the pads until they need changing? I've never changed them and a guy at a shop a few months back glanced at them and said it looked like I had around 50% left. Hell my uncle didn't change the original brake pads on his taco until 195k miles.
  11. Jul 9, 2011 at 7:07 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Your caliper might be seizing. If not than your pads or rotors are worn out. When you say it gets louder when you brake, sounds like your pads are done. Check your rotors and see if they have significant scratches, then check your pads for scratches or chips.
    I had a similar problem when i caliper seized. When i jacked it up, the wheel had a hard time spinning.
    **Generally, you change your pads when it gets 1/8" thickness
  12. Jul 9, 2011 at 7:14 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    ^ what he said you could have one pad that is fubar and it could have worn down in a month if the capiper seized. IF you do decide to replace them your self i would recomend buying a new caliper just in case you can always return it.
  13. Jul 9, 2011 at 7:17 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    1/8" is about where it's at right now. The rotors kinda look like shit. Scratches and looks like some divits from rocks or something. Should I change the pads first and see what happens, or change out the rotors too while I'm at it?
  14. Jul 9, 2011 at 7:19 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    You might as well change the rotors while your down there. Bad rotors can cause your pads to wear out faster. Since your saying you rotors look like shit, i would change the rotors. Rotors are cheap too!
  15. Jul 9, 2011 at 10:40 PM
    StampedePasser
    StampedePasser Member
    Eric
    Mukilteo, WA
    02 Tacoma SR5 TRD
    Rotors are cheap, in stock, and easy to replace. If they have not been changed in 195k+ miles, I would for sure replace them. Any new pads on the old rotors will where down fast. The scratches in the rotor and the screetching are probably the backing plate of the pads rubbing.
  16. Jul 10, 2011 at 6:34 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    How do I tell if the caliper is seizing?
    And if it is, is there a way to clean it or does it have to be replaced?
  17. Jul 10, 2011 at 7:38 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    If the caliper is seizing, the wheel will not spin freely. Compare both wheels, if they both spin relativity the same then its probly not seized. If its seized there isnt much you can do but replace. And make sure you replace both calipers.
  18. Jul 10, 2011 at 9:00 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Well that's good to hear, the wheels spin with little effort. I think I'm going to go with the Centric rotors and pads from Wheelers.:D
  19. Jul 10, 2011 at 9:08 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    IF both your pads have a similar amount of meat left on them:cool: You probably wont need a caliper.
    IF not... some frozen caliper spin just peachy. Take a C clamp and the old pads to push the caliper pistons back in, If it doesnt budge then this means that it is FUBAR. Keep in mind that the pistons dont move to easily to begin with. IMO i would buy a caliper just in case if you dont need it return it. Cuz if you need it you wont be able to throw the old one on to drive to the store.
  20. Jul 11, 2011 at 11:31 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I just had the same thing happen to me, all it was was the noise maker on the pad that tells you it's time to change. It was hitting even without the brakes being applied. I couldn't get a picture of it but the very corner of it was rubbing on some rust that's around the outside of the rotor. I just got the new pads in the mail and am waiting for some shop time to get them put in.
