Grinding on Acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoskim, Dec 10, 2008.
  1. Dec 10, 2008 at 11:33 AM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    hey guys got a quick question. when on a dead stop, and when let go of brake and let the truck roll when i accelerate hard from the roll i hear this weird grinding/vibration noise from the front of the truck. it doesnt do it if i floor it from a dead stop, only if its rollin a little then i floor it the noise happens. it doesn't do it through out the whole rpm, only when i step on it in the beginning.. any ideas what this can be, transfer case? tranny?? thanks for any ideas!
  2. Dec 10, 2008 at 11:56 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  3. Dec 10, 2008 at 11:59 AM
    tacoskim
    Los Angeles, CA
    Stock
    is this normal??
  4. Dec 10, 2008 at 12:15 PM
    mjp2
    NJ
    Common, but a floppy driveshaft can't exactly be classified as "normal". ;)
  5. Dec 10, 2008 at 1:28 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
  6. Dec 10, 2008 at 1:34 PM
    tacoskim
    Los Angeles, CA
    Stock
    k i really hope its not this.. i havent even off roaded my truck yet so i dunno what i could of done to break the frame... can the torque from my mods cause this?
  7. Dec 10, 2008 at 1:37 PM
    RelentlessFab
    Eric
    Sparks, NV
    hope its not the case too. i'd imagine that the extra torque could help in leading to this issue, especially if you drive it aggressively but who knows. Check under the truck and see if this is your case. good luck.
    here's the first thread i saw about it: http://www.tacomaworld.com/forum/2nd-gen-tacomas/20703-check-your-motor-mounts.html
  8. Dec 10, 2008 at 3:09 PM
    tacoskim
    Los Angeles, CA
    Stock
    k i checked the motor mounts, i see no rusting.
    EDIT: ha damn i feel dumb. well i found it and motor mounts are good.
  9. May 1, 2013 at 12:12 PM
    Ludo
    Ludo Member
    Houston, TX
    06 Prerunner
    What was the problem.
  10. Jun 9, 2013 at 10:01 PM
    Zilla
    Zilla Well-Known Member
    snah
    los osos ca
    Red Tacoma SR5 4X4 6speed
    this just stared for me today
  11. Dec 5, 2017 at 10:36 AM
    Logoleaf
    Logoleaf New Member
    Kevin
    2004 Tacoma 4wd
    I have a 2004 4wd. Does the same issue as you. Did you find out what caused the issues? Mine is grinding every stop sign when i do hard acceleratiing. If i slowly hit the gas padle, it drives normal. Any one with the same issues, please drop me some comments. Thanks
    Kevin,
  12. Nov 10, 2020 at 8:18 AM
    Zoocoma
    Zoocoma Active Member
    PNW
    Fodofomohoes
    What a douche..
  13. Nov 10, 2020 at 8:20 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You're 12 years late to the party
    Torspd likes this.
  14. Nov 10, 2020 at 10:04 AM
    Zoocoma
    PNW
    Fodofomohoes
    What are you still doing here front and center?
  15. Nov 10, 2020 at 10:09 AM
    BassAckwards
    Wondering why you're calling out some random person from 12 years ago? :notsure:
    Torspd likes this.
  16. Nov 10, 2020 at 10:09 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Lmfao
    :sadviolin:
    Torspd likes this.
