Grinding/ Seizing from front end after 3" OME lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goldenstone, Sep 15, 2011.
  1. Sep 15, 2011 at 7:03 PM
    goldenstone
    goldenstone [OP] Member
    Calgary
    07 TRD Tacoma
    3" OME lift with AAL in the rear. 285/70/17 Nitto All terrains
    Well upon closer inspection it looks like the cv boot has oil on it, can't see any actual tears in the boot but there must be one. If it is the cv joint, do you think it has failed due to improper installation of the lift kit?
  2. Sep 15, 2011 at 7:06 PM
    98tacoma27
    Ben
    Not Beech Creek
  3. Sep 16, 2011 at 5:00 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Not improper installation. But if the boot already had a tear, the lift could have caused the tear to open up more, splattering essential grease all over and letting dirt in. Is the oil on the inside joint or outside joint? Could also be front diff oil that you're seeing.
  4. Nov 7, 2017 at 1:29 PM
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    Having exact same problem with exact same OME lift. There were no issues before hand. Besides this is appears to operate flawlessly
    Only happens on left hand side and sharp wheel angle just shy of full turn.
    No tears in boots or anything. 2015 off road.
  5. Feb 23, 2022 at 4:22 PM
    Mt133677
    Mt133677 Well-Known Member
    SoCal
    2020 DCSB TRD OR
    All the things
    Did you guys ever figure this out?
