ground clearance
Discussion in 'Suspension' started by thirteen, Nov 9, 2009.
  1. Nov 9, 2009 at 12:27 AM
    thirteen
    thirteen [OP] New Member
    I've search but could not find any info, my question is would i get more ground clearance with a 3" lift and 33" tire or 6" lift with 35" tire thanks in advance
  2. Nov 9, 2009 at 12:30 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Well with the 6" and 35 you'll get more ground clearance but the amount of travel will stay the same.
  3. Nov 9, 2009 at 12:30 AM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    Larger tires = more clearance
  4. Nov 9, 2009 at 12:31 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    ^ he's right, also in order to have larger tires you need a taller lift.
  5. Nov 9, 2009 at 12:33 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    if you are 2wd you can get spindles and run them along with you coilover lift and 33's
  6. Nov 9, 2009 at 2:55 AM
    thirteen
    truck is a 06 4x4, i did more search and alot of people say that with the 6"in kit youll lose ground clearance because of the drop bracket so im a little confused :confused:
  7. Nov 9, 2009 at 4:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Ground clearance is all based on the TIRE SIZE.
    I'm not familiar with the 6" lifts...but it appears the drop brackets are what support the lower control arms/etc.... The relation to the axle/hub is still the same in terms of ground clearance. The distance from the wheel/tire mounting location and the size of the tire - is the ground clearance.
  8. Nov 9, 2009 at 11:39 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    With the drop bracket. The differential and lower control arms are supported by a bracket. With this style lift the bracket is still going to hang low not giving you any clearance. your best bet is getting some coilovers, upper control arms, and going to 33 inch tires.
    This is a drop bracket lift. notice the part that says fabtech its also a 6 inch lift.
  9. Dec 8, 2009 at 12:52 AM
    hpi
    hpi New Member
    any body have measurements from ground to diff with
    3" and 33
    6" and 33
    6" and 35
  10. Dec 12, 2009 at 9:11 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    bump
    i want to know this to and with 4.5" with 33's
  11. Dec 13, 2009 at 8:33 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I don't know exact measurements but think of it this way - lets say stock rear diff clearance is 10" as a base. A 3" lift raises the truck, not the rear axle and diff. So the rear diff clearance will still be 10". Add a 33" inch tire to replace the stock 31" tire and you've raise the truck and the diff in this case by 1". Now your rear diff clearance will be 11". Same deal with a 6" lift. Still only 10" clearance until you add 35" tires and now you've added 2" larger radius tires to give 2" more ground cleanance.
    The front diff is a slightly different story. Since it's not a solid axle but IFS. The front diff will be raised with spacers or coilover lifts. A 3" lift will raise the front diff 3" (front stock 10" to 13") since it would be raised along with the truck it's bolted to. The 6" drop bracket lift on the fabtech lowers the front diff by 4" while raising the truck 6" so you only gain 2" additional front diff ground clearance. Again tires will raise the truck and diff by the additional radius.
