GROUP BUY '96-2004 Tacoma Rear plate bumper
Discussion in 'Relentless Fabrication' started by Hawk_tx, Oct 31, 2019.
  1. Oct 31, 2019 at 8:02 PM
    Hawk_tx
    Hawk_tx [OP] Well-Known Member
    Texas
    2001 Burgundy Tacoma Trd
    Here is the information for the bumper.
    Base price includes Standard or High clearance hitch (customer will need to specify which one when ordering) Flush mount cutouts for Rigid D series will be standard on all bumpers.
    Bare: $849 (price does not include shipping, shipping is extra)
    Powder Coating adds $175
    Key features:
    - Made from 3/16”, ¼”, and ¾” thick steel, CNC cut and bent, and MIG welded for unbeatable quality and rugged good looks with the strength to back them up.
    - Improved clearance over low hanging factory bumper and hitch.
    - Mounts through 1/4" steel mounting brackets, and uses 4 mounting points per side of frame. Compare this to our competitors using only 1-2 bolts per frame rail being held in shear!
    - Standard integrated 3/4" steel recovery points are through welded directly to the mounting plates for strength to handle all recovery situations! No surface welded 'recovery' points here!
    - Standard hi-lift jack lifting notches on every bumper
    - Standard cutouts for factory license plate lights to be reused
    - Each bumper is hand made to order to your exact specifications.
    - Approximately 75lbs base bumper weight.
    - Modified mounting for trucks with body lift is available. If a body lift is installed, please specify how much body lift is on your truck when ordering otherwise a bumper for a standard truck will be sent (0" body lift).
    Installation:
    No vehicle modification is necessary to install. Simply remove the factory rear bumper and bolt the beefier Relentless rear plate bumper up with basic hand tools!
    **Factory tow hitch will NOT work with this bumper. I can integrate a hitch into the bumper, but since I cannot get it officially tested like the factory hitch, it comes unrated for capacity and full responsibility and liability is on you if you decide to tow with it. I'm sure you can understand where i am coming from, theres just a lot of liability there that I can't claim for on-road use. These are off-road bumpers.
    Please allow time for your bumper to be expertly crafted to your specs. We build as quick as possible, but quality like this takes some time. Great looks, unbeatable quality and solid design is found in every Relentless product. Complete customer satisfaction in our product is my goal!
    Sample pictures:
    Pictured is base bumper for a 3" body lifted application.
    Jason's rear with: 3" body lift mod, receiver hitch, custom backup light cutouts, and swing-out tire carrier option.
  2. Nov 3, 2019 at 6:05 AM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    I’m in.
  3. Dec 5, 2019 at 1:05 PM
    TheMTBtacoGuy
    TheMTBtacoGuy Well-Known Member
    carsen
    Sandy, UT
    01 trd Supercharged 5spd, grandma Lexus
    • 3in old man emu lift • jba ucas • 34in bfg at on 16in method wheels • 2nd gen TRD supercharger (PO) • ARB front bumper • black metalic flake paint job (PO) • All pro off-road bead rack • smittybilt rtt • Borla exhaust (PO)
  4. Mar 18, 2020 at 1:56 PM
    Garwood
    Garwood Well-Known Member
    Pensacola, FL
    2002 TRDOR Xtra Cab 5spd MT
    Did this group buy ever get off the ground? It's such a cool bumper, I'd totally be in.
  5. Mar 19, 2020 at 12:57 AM
    Hawk_tx
    Texas
    No it never did :(
  6. Mar 19, 2020 at 1:07 AM
    Flare side Taco Lover
    Flare side Taco Lover I'm gettin hitched...to my truck!
    Mudder Trucker
    Hicktown Ohio
    03 Taco, 98 Ram, 00 Ranger, 85 Ranger, 03 Ranger, 00 Sonoma
    put truck nuts on my 2000 Ranger
    I wish I could get one like that for a stepside.
  7. May 3, 2020 at 12:06 AM
    owl0990
    owl0990 Well-Known Member
    Is there any way to get this group buy off the ground?
  8. May 4, 2020 at 12:58 AM
    Hawk_tx
    Texas
    I don’t think there is enough interest but I’m still down
  9. Aug 16, 2020 at 6:40 AM
    Sinkalip
    Sinkalip Member
    04 DC 04 RC
    I'm in, I should've bought one a couple years ago when I got my front bumper :mad:
  10. Aug 16, 2020 at 9:24 AM
    RelentlessFabrication
    RelentlessFabrication relentlessfabrication.com Vendor
    Sparks, NV
  11. Oct 1, 2020 at 4:11 PM
    DK117
    DK117 Well-Known Member
    DK
    2003 TRD
    will factory hitch work with the wrap around? I like everything you guys do, but don't want to lose my factory hitch.
  12. Oct 4, 2020 at 7:25 PM
    Sparks, NV
    DK117 likes this.
