Group Buy (Extended): WeBoost and Wilson Pro Cell Boosters - Current discount valid til Feb 28, 2021
Discussion in 'Non-automotive Group Buys' started by CowboyTaco, Oct 14, 2020.
  1. Nov 8, 2020 at 3:57 PM
    #61
    TWTaco
    TWTaco Well-Known Member
    Dave
    Can i get PM for the code or pricing on the
    Drive Reach OTR Fleet?
  2. Nov 9, 2020 at 4:41 AM
    #62
    CowboyTaco
    CowboyTaco [OP] $20 is $20
    North Georgia
    11 TRD Sport
    I totally understand that. I was in the exact same boat. I do a couple of drives to visit family on a pretty regular basis where I go through some areas where I'm pretty sure there is signal (cause Pandora will usually work) but it isn't good enough to make a phone call. That's great if all I'm doing is listening to music, but even that doesn't work 100% of the time. If I were to have any kind of need, I don't have confidence that I'd be able to make a call. So my hope is that I can get a solid signal in those areas.
    One thing that I think could be better....once the unit is mounted, it's pretty much a permanent mount. Unlike the coax cable that goes between a CB radio and the antenna, the OTR antenna is permanently attached to the cable. This isn't a big deal if you plan to run it full time, but you can't remove just the antenna. Ideally, you would have this mounted on a roof rack with a folding bracket so that it can lay flat. I don't have a roof rack, so that isn't an option. I'm planning on using a CB antenna mount at the back of the bed, but it will be some work to move the antenna if I decide I need to locate it somewhere else.
    My first thought was that I would order the unit and get all the cables run inside the cab and have everything connected. Then just add the antenna whenever I'm ready to use it. Unless I can find an easy way to run and conceal the cable, that won't be happening.
    PM Replied.
  3. Nov 9, 2020 at 9:52 AM
    #63
    JIMMEISTER
    JIMMEISTER LIFTd Customs
    Hawaii
    2018 Tacoma DCLB TRD 4X4 OR
    PM sent!
  4. Nov 10, 2020 at 4:37 AM
    #64
    Aldizzle13
    Aldizzle13 Well-Known Member
    Bay Area
    2012 Tacoma TRD Sport 4x4
    Thanks again @CowboyTaco for setting this up:cheers: just bought mine a yesterday.
    CowboyTaco[OP] likes this.
  5. Nov 10, 2020 at 4:46 AM
    #65
    CowboyTaco
    North Georgia
    11 TRD Sport
    I need to get off my lazy tail and install mine.
  6. Nov 10, 2020 at 8:07 AM
    #66
    beardy
    beardy Active Member
    Thanks @CowboyTaco for arranging this group buy! Their chat support helped me with a few questions and squared me away with the code last night. Looking forward to getting it installed and put to the test in the wild.
  7. Nov 10, 2020 at 8:13 AM
    #67
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    I would like to get a coupon code for this too please.
    Thank you
  8. Nov 10, 2020 at 10:06 AM
    #68
    AWD_Jeff
    AWD_Jeff Well-Known Member
    2018 OR DCSB
  9. Nov 10, 2020 at 12:15 PM
    #69
    CowboyTaco
    North Georgia
    11 TRD Sport
    So for the laymans, like myself, you got 2 more bars!
    For the more technical, the last 4 numbers improved. Though, I have no clue what those numbers mean.
  10. Nov 11, 2020 at 11:39 PM
    #70
    Flat wheel
    Flat wheel New Member
    2019 OR
    Would you send the code my way, please?
  11. Nov 12, 2020 at 4:24 AM
    #71
    CowboyTaco
    North Georgia
    11 TRD Sport
    PM replied
  12. Nov 12, 2020 at 7:05 PM
    #72
    Rintho
    Rintho Active Member
    2017 Tacoma TRD 4x4 Sport
    My OCD is acting up. I see the rubber plugs under the driver's side of the cab will probably be just fine to run the antenna wire. Under the passenger side is a rubber ... tubular grommet ... (if that makes sense) where several wires run into the cab. Does anyone know a part number or proper name for that rubber thingee? I've tried searching on-line parts ordering systems with no luck. Thanks.
  13. Nov 13, 2020 at 4:41 AM
    #73
    CowboyTaco
    North Georgia
    11 TRD Sport
    I ran my CB coax through the grommet under the driver seat. Probably 7 years ago and have never had an issue with it...even going through deep water crossings.
    Rintho likes this.
  14. Nov 13, 2020 at 12:34 PM
    #74
    Rintho
    With respect, sir. I'll keep your advice as plan B. I realize perfect is the enemy of good enough. I have plans to run other wires into the cab in that neighborhood and was looking for a more purpose-built solution.
  15. Nov 13, 2020 at 12:58 PM
    #75
    CowboyTaco
    North Georgia
    11 TRD Sport
    :thumbsup:.
    No disrespect taken. Everyone should do what works best for their situation. I was simply providing info on what has worked for me.
    CttAznRanger likes this.
  16. Nov 14, 2020 at 6:44 PM
    #76
    prettydarngood
    prettydarngood Member
    Nate
    Clovis, NM
    2016 Inferno Orange TRD OR 4WD DCSB
    Basics - 2016 Tacoma - 61,000 miles Double Cab Short Bed Inferno Orange Black Interior with Orange Stitching 3.5L V6, Auto, 4WD TRD Off-Road Package - Rear Diff Lock and CRAWL control Tech Package - LED DRLs, Dual Climate Control, Heated Seats, Parking Sensors, Color Matched Rear Bumper, etc Sunroof Auto Dim Rear View Mirror Towing Package Weather Tech floor mats “Tacoma” Bed Mat Every option but JBL Upgrades - TRD Pro Grill Insert TRD Mountain Scene Logos Black Tacoma Door Logos Fox 2.5" Extended Travel Adjustable Coilovers Camburg Ball Joint UCAs Old Man Emu HD Rear Leaf Spring Packs Fox 2.0" Rear Extended Travel Shocks SumoSprings custom rear bump stops Body Armor 4x4 HD Steps Bars TRD Pro SEMA 17" Matte Black Wheels 285/70r17 BFG KO2s KB Voodoo Fabrications Modular Bed Rack System 3 Rotopax Mounts Fork Mount Bike Racks on either side Rhino Rack HD Load Bars Gobi Stealth Roof Rack 32" Curved LED Light Bar Odyssey Group 35 Battery Marine Grade DC 12v/USB plug in Bed Storage pocket to run fridge and charge cell phones etc. Overland Accessories - Tepui Grand Sabana Roof Top Tent - Siberian Camo w/Changing Room ARB 4ft Rear Mount Awning Rotopax Water Cans (2) Rotopax Gas Can
    I'd also like a PM for the code or pricing on the
    "Drive Reach OTR Fleet" please. Thanks!
  17. Nov 14, 2020 at 7:08 PM
    #77
    CowboyTaco
    North Georgia
    11 TRD Sport
    You'll have to submit for a quote on their website. Just mention the Tacomaworld group buy to get the discount.
    Seems as though Wilson changed up some of their policy and are requiring vendors to provide quotes on certain models. I'll post more info tomorrow after I clarify a few things.
  18. Nov 14, 2020 at 7:53 PM
    #78
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Thank you @CowboyTaco for setting it up. I will gladly give business to someone with a soul instead of Amazon.
    I am fine with requesting quotes if they are responding to us, so I will give that a shot in the morning.
  19. Nov 14, 2020 at 8:28 PM
    #79
    prettydarngood
    Nate
    Clovis, NM
    That was super easy! Got a quote and already ordered their Reach OTR kit just now. Thanks again for the excellent price!
  20. Nov 15, 2020 at 4:55 PM
    #80
    ptothegdotcom
    ptothegdotcom Well-Known Member
    P
    SOCAL
    2020 TRD OR PREM DCSB
    I would love a coupon code as well. Thanks!!!
