growling vibration in front left side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yukontruck17, Oct 31, 2024.
  1. Oct 31, 2024 at 11:14 AM
    yukontruck17
    yukontruck17 [OP] New Member
    Douglas
    2017 Tacoma
    Blistein 5100 shocks
    I have a growling vibration with some slight steering wheel shake. It's as if the transfer case is engaged but it's not. The growling vibe is constant whether its in normal 2wd, 4wd, and neutral.
    the noise goes up and down with the speed of the truck. (I put it in neutral and coast the noise slows down with the truck). I replaced the tires, rebalanced 4 times then the tire shop replaced the tires with a different style. Took to a local reputible shop, they said they can't figure it out but the cv joints and bearings are all good. Told me to take it to Toyota to see if they can pin point it. I read it could possible be the needle bearing but other threads say it will go away in 4wd if it is. My issue is there all the time no matter gear, 2wd, 4wd or neutral. I put Blistein 5100 shocks on the truck 3 yrs ago and the setting for the front is set for 1" lift as I put tires on that were 1" higher than stock. Also had a western plow on the front for couple of winters.
    Can any one chime in that had this exact experiance ?
  2. Oct 31, 2024 at 11:27 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    How were the bearings checked? Mine were deafening loud and you couldn't tell, even off the truck. I could still spin the wheel by hand with the truck lifted off the ground, and there was zero movement when I was pushing and pulling on the wheel. Trying to turn the new one and the old one by hand off the truck were both relatively hard, i couldn't have noticed a difference. The new bearings was silent in comparison.
  3. Oct 31, 2024 at 11:54 AM
    yukontruck17
    Douglas
    2017 Tacoma
    They tested bearings like you did plus put it on the lift ran it in 4wd while listening with a stethoscope, also drove it
  4. Dec 17, 2024 at 7:41 AM
    FranksGotTacos
    FranksGotTacos donkey
    SB
    Denver
    16 DCSB. Geared, Dual Locked, 35s, Topperlift, wet AF
    5.29 gears, ARB locked, Lil Bs front bumper, Hooligan sliders and roof rack, cab and bed cap, Outgear solutions rear bumper, custom swingout. 35's. Icon rebound pros x 5, OME BP-51s. Topper ez lift. Decked. Full RCI full skids, misting system with 4 gal plumbed into 270 ironman awning, air plumbed to all 4 corners + decked, DK upper shear kit, Marlin LCA brace kit, 10 pc rock light kit, scene pods, u bolt flip, stage 3 deavers, poly bushings all around, archive garage hammer hangars, sumo springs rears, TC gusseted spindles, spiker hood struts, aux beam 8 gang, 50 watt solar on top of 2x pelican cases, Cascadia 4x4 mppt solar charge controller, jackery 1000, alpicool 45L fridge. Rear seat delete with fridge slide on passenger side (by me). Meso overhead rack, Meso cab, dome, rear interior lights, Meso x morrimoto tail lights. CVJ high angle boots,
    I have a similar noise on my taco I have been chasing for the last few months. Rotational noise that is constant and sounds like a metal on metal skim. I replaced my front wheel bearings, balanced my DS, checked dust shields, ect but I still cannot figure out what the sound is. Did you even figure yours out OP?
  5. Dec 17, 2024 at 9:27 AM
    yukontruck17
    Douglas
    2017 Tacoma
    I replaced the driver side wheel bearing and resolved the growling and the shimmy in the steering wheel. Sounds like the only thing left to check on yours is the needle bearing on the driver side in the transfer case where the cv joint goes in
  6. Dec 17, 2024 at 9:32 AM
    YF_Ryan
    Kent, WA
    Front Differential, not Transfer Case (prolly just a brain fart, no big deal). But yeah, the ECGS bushing is a possible upgrade/solution.
  7. Dec 17, 2024 at 9:36 AM
    yukontruck17
    Douglas
    2017 Tacoma
    Yup, brain fart while multi tasking lol sorry about that but yet front diff. Good luck to ya
    YF_Ryan likes this.
  8. Dec 17, 2024 at 11:41 AM
    FranksGotTacos
    SB
    Denver
    needle bearing was taken care of ages ago when I regeared and double locked the truck. I did bend my front axle extension tube this summer and replaced it with another extension from a used parts dealer. (see my post: tough day on the trails 2x cv) I am worried it is either my t-case or the other needle bearing that is on the pass side inside that extension tube. I had my RCI t-case crossmember skid fail at the welds, crash into the t-case and push the case into my tunnel. There is a small witness mark on the tunnel where the case hit the tunnel, but it isnt touching the sheet metal, it sprung back. It could be a few degrees out, causing the drive line angles or the output shaft and bearing to be pissed off. I have tried to get a recording of the sound but it doesnt show up on video.
  9. Dec 18, 2024 at 2:07 PM
    Taco Paige
    Taco Paige Well-Known Member
    21 Trd Sport
    Lift, wheels, rack, storage, air bags
    Probably bearings but I would also check the cv joint
