GTABurnouts Radiant Red CCSB TRD OR
Discussion in '2nd Gen. Builds (2005-2015)' started by GTABurnout, Oct 9, 2011.
  1. Aug 28, 2012 at 7:35 AM
    #41
    GTABurnout
    GTABurnout [OP] Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    Mid travel Icon Kit on order. Then a set of 16inch methods hopfully later in September. Finally some mods....
  2. Sep 22, 2012 at 9:19 AM
    #42
    GTABurnout
    Tucson AZ
    Mid travel is on the Truck....
    Heres the pre install pics....
    Going to do a shake down run tomorrow with a buddy who just put the same kit on his 2011.
    Now for some 285's and some wheels....
  3. Sep 23, 2012 at 6:26 PM
    #43
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    :worthless:of the new set up
  4. Oct 5, 2012 at 3:58 PM
    #44
    GTABurnout
    Tucson AZ
    Mid Travel is on, tested and awesome. Now time for some wheels and tires...
  5. Oct 28, 2012 at 7:45 PM
    #45
    GTABurnout
    Tucson AZ
    Wheels are in. Pairing them with some 285/75R16 MTR's Trying to get some custom wrapping done on them before install
    Sprocket and Method
  6. Nov 17, 2012 at 12:14 PM
    #46
    GTABurnout
    Tucson AZ
    Wheels are on. Cutting was required. Method Double Standards With Goodyear MTR 285/75R16's. Had to do the cab mount chop and cut some of the fender. Not sure if she will rub off road yet.
    Sprocket and I took a few pics...
    J'sBeasTRD likes this.
  7. Nov 17, 2012 at 12:15 PM
    #47
    GTABurnout
    Tucson AZ
    And I just got a GoPro 3 Silver so I took a picture with it to mess around.... This thing is sweet. Completely controllable from my phone.
  8. Dec 1, 2012 at 2:57 PM
    #48
    GTABurnout
    Tucson AZ
    I ordered a light thru the okledlightbars.com GB. I went with a 20" because at the time I was planning on running a light bar. After some thinking I decided I would rather save the light bar money and mount it in the grill some how. I have no desire to change my actual grill so the next best spot is the lower Grill.
    So last night I pulled the grill and took a few measurements. And test fitted the light to see where i could mount it. I was hoping I could just mount it to the aluminum crash beam but the feet for the light would have made that too tall.
    The light:
    I noticed that the crash cans sit slightly below the crash beam. Unfortunately since I had a 20" light the feet would not span the 35" inches between the two. I decided to get a piece of angle iron and span the gap and then just mount the light to that.
    The angle iron would need to be 35" or more. I found a piece of 36" long 2"X1" L bracket.
    It would just need to be notched so the bracket would fit between the crash cans....
    Removing the bumper cover to get access to everything...
    Testing fitting the L bracket after cutting.
    Perfect....
    Now to see if the light will fit ok...
    And now to test fit the bumper to make sure my measurements where correct...
    Light fits correctly and is pretty much centered in the lower grill....
    Now I can not really access the locations where I want to bolt the L bracket to the crash beam. So Off it comes....
    Crash beam...
    Black painted Bracket...
    So the beam is pretty much a long piece of extrusion. So its hard to get bolts in and then get nuts on to those bolts. So I went with a few self tapping fasteners.
    I over did it. 4 on each side of the crash can and about 8 holding the loer part of the L to the crash beam.
    Center punches
    Bolted down and back on the truck.
    And bumper back on....
    With the bumper on I will need to remove the grill to gain access to the light but still I can re-aim if required.
    And all wired up.....
  9. Dec 1, 2012 at 2:59 PM
    #49
    GTABurnout
    Tucson AZ
    And Installed some wheeler's Bumpstops....
  10. Dec 1, 2012 at 3:08 PM
    #50
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    I like your wheel and tire combo, have you had a chance to hit dirt with the mt/r's yet? i'm considering them for my next tire.
  11. Dec 1, 2012 at 3:24 PM
    #51
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    This truck looks clean as all hell. :thumbsup:
    Nice build man!
  12. Dec 1, 2012 at 3:56 PM
    #52
    IndianTaco
    IndianTaco Well-Known Member
    nice truck and dog too
  13. Dec 1, 2012 at 4:06 PM
    #53
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Nice truck man! Good looking setup you have.
  14. Dec 1, 2012 at 4:34 PM
    #54
    rawdog
    rawdog Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    Im curious of your trailer plug relocate, was that pretty easy or what.. too lazy to go look at mine right now haha
  15. Dec 1, 2012 at 5:01 PM
    #55
    GTABurnout
    Tucson AZ
    I hit a little dirt with them. I plan to hit more tomorrow. Coming from a 17 the 16 wheel and tire combo floats much better on the wash board stuff. I don't go as fast as you LT guys but I think the tires do pretty well in the arizona desert....
  16. Dec 1, 2012 at 5:03 PM
    #56
    GTABurnout
    Tucson AZ
    Ieah it was pretty simple. I kinda went out to look at it and ended up just doing it right there. its not the best looking but it works. Now I need to see if I can mount a 285 down there with the plug like that.
  17. Dec 1, 2012 at 8:01 PM
    #57
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
  18. Dec 1, 2012 at 8:07 PM
    #58
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Truck looks sick man....so clean! We need to wheel next time I'm in Tucson (still have family there)!
  19. Dec 2, 2012 at 10:26 AM
    #59
    GTABurnout
    Tucson AZ
    Night time Light Pics
    All pics taken with a D7000. Settings where manual and all pics taken with same settings. No photoshop except to resize.
    LED Bar Only
    Low Beams
    High Beams
    Highs and LED Bar
  20. Dec 2, 2012 at 10:29 AM
    #60
    GTABurnout
    Tucson AZ
    #60
