Guide me Thru!
Discussion in 'Wheels & Tires' started by manrdz01, Dec 16, 2008.
  1. Dec 16, 2008 at 2:37 PM
    manrdz01
    manrdz01 [OP] Member
    South Tx
    Tacoma
    Hello guys, I am looking for a direction on how to replace my frt hub bearings on my 2005 Tacoma? And if I need any special tools to get me there! I am getting a humming noise at about 30mph+! Tanx for your help!
  2. Dec 16, 2008 at 2:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i havent done it on a 2nd gen tacoma before, but i think you basically gotta take off the brakes and rotor, then the spindle nut and you should be in there then. as far as special tools....not really sure, but i think either a 35mm or 36mm socket for the spindle nut. someone else will be along to correct that if im wrong.:)
    by the way.......welcome to tw!!
  3. Dec 16, 2008 at 2:47 PM
    manrdz01
    South Tx
    Tacoma
    Any help will do! One more thing is this a press in bearing that u have to use a Manual Hydrualic press?
  4. Dec 16, 2008 at 2:49 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Welcome to TW! ^^^^ That sounds about right not sure of the nut size either.
  5. Dec 16, 2008 at 2:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no.......those bearings should just slide out after you have everything loose.
  6. Dec 16, 2008 at 2:53 PM
    manrdz01
    South Tx
    Tacoma
    Just getting ready to tackle down on this repair within this week! Looks like its a job!
  7. Dec 16, 2008 at 2:54 PM
    manrdz01
    South Tx
    Tacoma
    Really! They should just slide out? Makes my life even easier Damn I sure appreciate the note!
  8. Dec 16, 2008 at 3:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    like i said....i could be wrong, but im pretty sure thats how it goes anyway. good luck with it man....shouldnt be too bad.
  9. Dec 16, 2008 at 3:12 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Take pictures along the way and post when you can. Contributions to the technical articles are always welcome around here! :thumbsup:
