Gun range target
Discussion in 'Guns & Hunting' started by TacoDell, Mar 23, 2013.
  1. Mar 23, 2013 at 4:47 PM
    TacoDell
    TacoDell [OP] Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Let's see yer homebrew targets here :)
    NO ! ...not the tv or beer bottles U sucked down :rolleyes:
    decided to whip something up
    that was better then a paper target.
    primarily for .22
    is only 1/4" mild plate
    will break down easy, lay flat
    'bout 4' wide and 20" tall to the horizontal rod.
    ^ I've yet to complete the upper rod mounts
    rod ends will be secured using collars (drill depth stops)
    guess I need to test it... see if it can handle some abuse :dunno:
  2. Mar 23, 2013 at 4:59 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You did a great job on that!
  3. Mar 23, 2013 at 5:07 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    Thanks brother...
    can't wait to to test it out :)
    probably build another of different design
    beats shooting at paper targets or junk laying around ;)
  4. Mar 23, 2013 at 5:12 PM
    lowcountrytj
    lowcountrytj Third Member
    Phillip
    Probably at Work
    2012 DCLB TRD SPORT "BLACKOUT"
    Looks great! Should be perfect for 22.
    I have something similar but I have shot the mess out of it with 40 and 45 ...now I have to re-build lol.
    P.S.-- What is even more fun is if you take that LP tank in 2nd or 3 rd pic and put a red dot on it with a fire behind it and send some lead through it !!!OOOps did I say that outloud
  5. Mar 23, 2013 at 5:15 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya, paper is a pain.
    Unfortunately, during fire season we can't have any steel at all on the range at Burro.
    I understand no steel core ammo, but copper and lead is not going to spark hitting steel any more than it will rock.
    Last 4 or 5 years, "fire season" is defined as any time the weather is good enough to get out of your truck.
  6. Mar 23, 2013 at 5:17 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I bought one from Turner's for $100.
    Plate spinner with 5 segments... Bullseye and 4 quarter-circle plates around it.
    Bent the crap out of it with my 45 at 20 yards.
    Then my buddy put a hole through it with his SKS at 150 yards.
  7. Mar 23, 2013 at 5:19 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Looks good! Can it broken down to take up less space when transporting to the range?
  8. Mar 23, 2013 at 5:21 PM
    lowcountrytj
    Phillip
    Probably at Work
    Lol,yeah mine has had to much frag damage to even try to slide the hangers off. I could probably grind it down and go from there but it gives me an excuse to do some welding:D
  9. Mar 23, 2013 at 5:23 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    looks good… is it going to have a reset plate?
  10. Mar 23, 2013 at 5:29 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    ^ funny... 'cause I know I won't be able to resist shooting at it with muh 30/30
    but if I made it... guess I could fix most any of muh boogers
    I've shot a few propane tanks... they just go phssssss :rolleyes: boring
    maybe less boring if there's a fire behind the LP tank :notsure:
  11. Mar 23, 2013 at 5:32 PM
    lowcountrytj
    Phillip
    Probably at Work
    Well,it adds a little eeww and awww factor when done properly. Thats what they told me anyways lol:cool::cool:
  12. Mar 23, 2013 at 5:35 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Nice! Are the target plates 4x4"?
  13. Mar 23, 2013 at 5:40 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    during fire alerts/conditions where I go...
    no shooting is allowed period... when posted.
    yes, the side stands are removable.
    so it lays flat when stowed
    what's a reset plate ? and should I need one ?
    the lower target plates are fairly heavy...
    it should settle down fairly quick I'd think ? :notsure:
    appreciate the compliments and comments, thanks :)
  14. Mar 23, 2013 at 5:44 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No need for a reset plate on a standard spinner.
    That would be used if, say you're doing an informal competition...
    As the targets are hit, they lock in a "hit" position that takes them out of view. When all of the targets have been hit, you shoot the reset plate to release the spinners.
    Premature release can count against you... It's a way of not only providing a fun, resettable target, but also in forcing the shooter to actually aim at a specific plate, rather than just "anywhere".
  15. Mar 23, 2013 at 7:34 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    oh ok…. I seen some of those that stay up as you hit them and then there is one last target that resets them back down!
    kinda like in this video i found…… but like you said… if they are heavy enough you wont need it….
    http://www.youtube.com/watch?v=XnjKfZfwyrA
  16. Mar 23, 2013 at 8:52 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    no, they're 3X3... mostly because muh scrap pile dictated that
  17. Mar 24, 2013 at 11:18 AM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    08 Prerunner Texas Edition
    That is a good job OP. We use the signs left around from people selling houses. They make good target stands and are a.) metal/aluminum b.) plentiful. We must have 30 or 40 of them at the place I shoot. ReMax makes the best ones. :D
  18. Mar 24, 2013 at 2:43 PM
    lowcountrytj
    Phillip
    Probably at Work
    These are some of my replacements...Different sizes and angles. The little 1x1 is the deal breaker:D
  19. Mar 25, 2013 at 12:43 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    ^ nice...
    I was going to use tube for the spinner mounts...
    then I thought... naw... the welder's heat will just distort them.
    maybe not tho' ...you don't have any issue with that ?
    What is the thickness of that tube ?
    Those plates ballistic ?
    And muh final question...
    When the plates are hit with .22
    does that cause the spinner rods to twist (turn) ?
    Just curious if that ^ could occur...
    using light ammo.
    I know my rods are harder steel then std. mild plate
    'cause muh cut off saw was slow to cut
  20. Mar 25, 2013 at 3:37 PM
    lowcountrytj
    Phillip
    Probably at Work
    Honestly, I'm not sure of thickness, but no distortion. My plates are 1/4 mild steel.
    My rods are 1/4 cold roll and I haven't seen any of them twist even when I fired 40 into em at about 50 feet( jhp).
    I went to take a pic of my setup, but it has walked off somewhere...:notsure:
